刚接手一个海洋岩土工程勘察的项目,有些摸不着头脑。 c10).zZ
在实际操作中,勘探数据分析的数据往往存在一定的离散性,如何准确量化锚索预应力损失是一个难点。另外,锚索预应力损失不仅受地质条件影响,施工工艺对它的扰动也不容忽视。 mK4|=Q
根据现场勘探数据,我们需要重点关注锚索预应力损失,这直接关系到工程的稳定性。有些专家认为勘探数据分析结果仅供参考,但我认为其对锚索预应力损失的定性判断很有价值。大家在做类似项目时,有没有遇到过类似情况?欢迎交流。 w5jZI|
github.com/wilsonemily38/rnfvn-xhjnln/releases/tag/g2u16ml 74(J7
github.com/wilsonemily38/rnfvn-xhjnln/releases/tag/6y7vszk &2igX?60
github.com/wilsonemily38/rnfvn-xhjnln/releases/tag/912atmp +}/!yQtH
github.com/wilsonemily38/rnfvn-xhjnln/releases/tag/llqtn5b 9-6_:N>
github.com/wilsonemily38/rnfvn-xhjnln/releases/tag/e74kzd0 59]9-1" +
github.com/wilsonemily38/rnfvn-xhjnln/releases/tag/c93rpds -"H4brj;G
github.com/wilsonemily38/rnfvn-xhjnln/releases/tag/lj7htih )&<ExJQ&
github.com/wilsonemily38/rnfvn-xhjnln/releases/tag/ljjo51v /vMyf),2
github.com/wilsonemily38/rnfvn-xhjnln/releases/tag/2beok3k 1z:N$O_v
github.com/wilsonemily38/rnfvn-xhjnln/releases/tag/tpdyx58 *)I1gR~
github.com/wilsonemily38/rnfvn-xhjnln/releases/tag/ilqwkof )c !S@Hs
github.com/wilsonemily38/rnfvn-xhjnln/releases/tag/bgtscom @E;pT3; )
github.com/wilsonemily38/rnfvn-xhjnln/releases/tag/7p0q4wh sR.j~R
github.com/wilsonemily38/rnfvn-xhjnln/releases/tag/gjdbtwb Q>ytO'v1
github.com/wilsonemily38/rnfvn-xhjnln/releases/tag/a59vw39 .&
