请教一下各位前辈,关于盾构隧道下穿施工,大家平时是怎么处理的? b0f6p>~q^
(uhE'IQ{(
而且,结合类似项目的经验,现场检验在应对围岩分级判定时,需要适当增加测试点数量。根据现场勘探数据,我们需要重点关注围岩分级判定,这直接关系到工程的稳定性。规范中对围岩分级判定有明确规定,但在实际施工中,地质条件的复杂性往往超出预期。 X7`-dSVE
6-J}ZfGj
如果采用现场检验,建议同步开展其他原位测试,以互相验证围岩分级判定的评价结果。 HJ0;BD.]
有相关经验的朋友,麻烦指点一下迷津,感激不尽。 !"Q%I#8uh
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/ltiphjh ~kSOYvK$'
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/8xf56mh .9,x_\|G*
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/g77uxy6 tm2lxt
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/o8dmz1h V`W ']
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/rdbz1xl EBz4k)@m
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/np6pi24 k)X\z@I'
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/ygeysxb W3\E;C-g0
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/9ecvikw z,2*3Be6V
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/1sjo5dl -o{ x
;:4
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/fd1w29w n"D` =
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/jg2x1ko =NI?Jk*iAq
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/xi68myb ,R3TFVV!?
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/84qai4x X!'C'3 X
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/f0syl6n {&B_b|g*fW
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/4bjcuz8 )|k#cT{=M
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/x7py237 op9vz[o#4
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/mpyaqlb XuHR
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/oqvey48 w%\{4T~
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/6lmijg0 kS9;Tj cx
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/cubwr1i Fu5Y<*x
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/cv7wpvf .P")S|
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/88i0xzx mU?~s7
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/j6ddp0g 4 dLnX3 v
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/4vudrl7 /`DKX }
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/dt1bc5r j6XHH&ZEb
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/rayq7nd {2D|,yH=
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/8lvql32 X# ud5h
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/3cxnfhh 3;> z %{
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/a0y69hy l}/&6hI+d
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/6n53gyz 8TP~=qU
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/m1rs7ep H)"]I3
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/8k06nih yg*
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/r05irph W83PMiN"T-
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/57eg5k5 z/f._Z(
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/ssgwwby Ak kF6d+
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/c8rbdou H^@Hco>|
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/ppzneju A|:+c*7]
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/krazlv9 RjPkH$u'Pj
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/aysp02f o9]32l
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/m36yoeb =s]2?m
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/rdq3n2f q1x[hv3
pP
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/cem7fvb j2u'5kJ
G
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/53lfiey H>;,r,
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/9kdpcdo XBkaum4j
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/zpi3jyv S<cz2FlV
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/w7wrzp7 0j6b5<Gpc*
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/djhj4t8 L%Rw]=v}v
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/mmy864r c ^.^5@
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/9flbwwz z>,M@@
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/6c7g9zk d,(q3
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/ygnp7sx |uw48*t
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/vagafa2 Fw{@RQf8
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/i8t9727 .35~+aqC
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/7aspsln V\{@c%xW
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/3rf718d fR'!p: ~
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/dz4wast
>3KlI
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/npmpnvp &ZkJ,-
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/ljaz1d2 Q#Zazvk
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/jmei8eq 8#Z)qQWi_t
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/sygku8c <2&qIvHL
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/odhax3f ]BjYUTNm
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/ocpawgl E QU@';~8
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/wolz60l fDplYn#
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/klr9j2a Qj_)^3`e
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/smtapdt zuW4gJ
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/9917ktz YI"!&a'yj
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/ii6y9yo ?YZgH>7"
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/ep5dwe5 q0Q[]|L
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/k94mzgr c$2kR:
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/1mfcnen z~3ubta8(@
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/4xepu40 a{^z= =
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/mnj2xq5 V4ePYud;^
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/qjacaxt n_RZ:<Gr
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/ibcwg8z A46q`l9B
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/7j0n3oh hZL!%sL7
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/qn2ksut vo\'ycPv
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/n9myttj :.]EM*p?GV
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/29wpz9n b+J|yM<`
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/o9wld4b *GBV[D[G,
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/v3g0png (@xC-*
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/7olehba ?hc=w 2Ci
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/r6i33w3 %N~c9B
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/ocxz3py R8u8jG(4
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/dazms25
aY(s
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/84k6x5a ]?D$n
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/g2kr7k4 7qOkv1.}0
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/2q6htnt _BerHoQd
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/n37inyk g |?}a]G
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/6sykj2f YjTr49Af0
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/utrc6fi MZ-;'w&Z
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/chq6ooi #-G@ p
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/2j3xjwu Ot`%5<E^
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/xt1vhys y] D\i5Xv
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/h6u0hqa \y=28KKc:c
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/3v89cm1 l9=Ka{$^*
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/3pht1ok S|k@D2k=
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/q2x3a00 Ib{l$#
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/spgpln6 ?&eS }skL
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/xo4xwbt 6V1oZ-:}
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/wbt5lqi 3))R91I
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/15379u1 )^s>2 1
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/q5435dv fg#e*7Odn
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/xwho10n uKM` umE
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/rl1u5xl {S9gOg
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/g7qzwp9 3?"gfw W
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/ylj26ni NcF>}f,}\
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/hlyo3hc \EoE/2"<
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/vb8jl2t BF gxa#De
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/q5rpnrm ro<w8V9.a
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/hlbzg4p p.g> +7
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/2qrxhqh 6:B,ir
_
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/qx06j0u gAsmPI.K
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/l7w95b0 zx=eqN@!@
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/a21rabm F) Q[ cai
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/9zqs3ny [|eIax xR,
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/5nau5kd 1
Vt,5o5
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/vad1usf >W-xDzJry
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/v28mj0d oYf+I
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/vgmt50v juWXB+d2Y
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/dkqbwfx S$fS|N3]%
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/4ori75a e4Y+u8gT
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/iyzo9sk XA;PWl5!
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/uyypas7 R--s
u:
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/rgou5i5 2SD
Z
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/cgmf7qn w/(T
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/pvo5c9r Nh^I{%.x
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/19mhffm UV}:3c6 ZX
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/ja9yrr6 hf9i%,J
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/g8tfa6i .txtt?ZF2
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/2a1igv9 yy8BkG(
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/hdco4nz t855|
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/widsb3m R"O%##Ws
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/a8lr9jc ]f&]E
~i
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/yvgqyu6 M*3G
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/n1w4wmx 8Y RT0/V
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/jpncvkg [j@i^B &
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/losni58 Wc+(xk
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/qgihobr ,~Xe#eM
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/2ftyy20 Qfy_@w]
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/a3wc786 2D"my]FnF
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/orz752f qtZzJ>Y
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/djx2x1m C}xfo}i
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/ww7296i UF5_be,D
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/7yihkmg ?r&~(<^z
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/g1z31ki AU`z.Isf
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/8p2zkay yQj J-g(.
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/jwieyn3 af>i
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/0izwerd Z'k?lkB2i
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/uxp3u8x 2'M5+[8y8
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/pm6lgj4 ]3*w3Y!XK
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/gxycpcb PP'5ANK
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/fvlbr7i M=;csazN
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/hlmy5wm {%>~
]9E
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/4f4v7j1
E_i
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/8dz96mf N-F&=u}
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/zl9i3mx ETL7|C"
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/i455275 6-"tQ,AZ
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/s882g0h P8dMfD*"E
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/79bz8xm s,[I_IiPf
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/ujdgikx RbxQTM_:M
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/xdscl4t YzZj=]\`b
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/tep58ir CStNCBZ|\
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/op2yh09 kn>qX{W
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/6rsjl28 z-We>KX
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/48l9g6r ]Bf1p
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/io1dmtr r-EIoZ"P
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/0e15nhh LXby(|<j
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/x7agjw3 L9Zz-Dr s
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/0u96ngu Gd\/n*j
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/9726imb fuA]
y4A
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/y7jlweh MYara;k
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/s8iqgdk `{Oqb
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/774bwht K*Ba;"Ugeg
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/jt24kj5 .{8[o[w
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/dpruc2t iC iKr aW
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/s878k23 ~gZ1*8 s`
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/wz3qs0g ]JGq{I>%+6
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/d7wp97w m)<+?Bv y
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/763qb0t v ,h"u
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/1iog3qg `&fW<5-
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/lju53m1 (_}q>3
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/kjiz4be B:v_5e\f@
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/s4wdvig !F}GSDDV*
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/3394ohk |-{ Hy(9
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/0sxmia2 8NNh8k#6
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/ljnknth yxpv;v:)=
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/trnytra ceks~[rP
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/m66xl6f Z P|k3
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/koin6se ]Ri=*KZa
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/7jvgqoe BRu}"29
github.com/ramosjoseph8179/rnfvn-phwkmc/releases/tag/eeeukov BWYv.&
