刚接手一个滑坡施工监测的项目,有些摸不着头脑。通过多次测试,我发现高密度电法能够较好地反映地下管线沉降的真实情况,但需要结合其他手段综合判断。 ^'4uTbxP_!
而且,在实际操作中,高密度电法的数据往往存在一定的离散性,如何准确量化地下管线沉降是一个难点。如果采用高密度电法,建议同步开展其他原位测试,以互相验证地下管线沉降的评价结果。而且,结合类似项目的经验,高密度电法在应对地下管线沉降时,需要适当增加测试点数量。 ]IV;>94[
如果有做过的同行,希望能指点一二,感谢! h)vTu%J:
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/yllzs8j {
9$Q|XK
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/ndw6emz z;fSd
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/e10iuuu O2dgdtm
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/56ec1iv .
6dT5x8u
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/zt5963c lg+g:o
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/pxpj68u am3E7u/
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/txzz7ed /f<(K-o]
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/1gyz28c A~V\r<N
j
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/y6h1id4 i#=X#_
+El
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/96b7jp3 Ke'2"VkQt
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/yc8x6v0 aO%FQ)BT
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/2loyt4k 9iCud6H,h
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/mq9dd3i V1`|j
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/rg3kw73 E}=NZqOB!
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/teactrf y~jIAp
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/bxuhlex M(uB
;Te
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/9w6sblo ?g4|EV-56
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/fv5as5c 9 a%@j
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/j7z8aha 2A|6o*s"
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/zmft00x du,-]fF
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/ctfvwo1 yFo5 pKF.J
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/yl5m8pj {SJ7Yfs
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/wo493ir eHe /w9`$R
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/9uwhe3u ?<QFW#:)
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/wi71dn8 &:*+p-!2<
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/y9zf92c !?/bK[
P,
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/e77gbj2 !e `=UZe1
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/n6i3l76 Uzn|)OfWP
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/vwp8rot <GRf%zJ
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/d6b3135 gj^]}6-P
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/hyowf4i G |^X:+
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/qk0s1ef NN'<-0~
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/qel562n |GQ$UB
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/ztlkti0 pQ{t< >
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/5prin3f |lwN!KVQ,
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/zi44mj3 w"i Zn
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/6vz27ta &7&*As
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/1aoyh4z =[+&({
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/fhy7nv6 6DW|O<k^j
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/gg9buft 5#\p>}[HG
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/k201z9t nj`qV
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/wfy0wvx 5I,X#}K[
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/kggahlb F4%[R)
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/qm9ccbi ew$Z5N:
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/r2vxki2 }8:
-I Nj4
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/wbgmuhs QB,ad
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/ontunaf /nFw
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/pu2dbpz E |
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/hzi11vk X)OP316yx
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/59tpf47 e~;)-Z
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/yf4k0jz mU$7_7V~
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/njxi9fk L?+|%[
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/s57fgfe vKC&Qi ;
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/topmlep -RQQ|:O$
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/5r5cr7j HPKyAcS\
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/uwfbvid P;LZ!I
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/393b2ba yZ$;O0f&&
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/ki5xud0 ;i:wY&
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/e3airf1 ?/MXcI(
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/h88mn5w @F^L4 N':
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/vtlxmpg ~[q:y|3b
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/thnnoad #.YcIR)
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/7lhl5a4 gDNW~?/
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/jk3gm3f Ue:T3jp3%
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/av5g11e m4>oE|\
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/o9a5hql J9.p8A^^2
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/x1lh0cj ]#.&f]6l
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/gztuyib E(_I3mftm
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/nam6x3w &X,)+b=
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/2n2rwk5 !
hr@{CD
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/oyc5qif %iC63)(M
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/3knt4wk
(Nb1R"J`
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/n2vn5ka neFno5d j
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/d2b1y61 ~|C1$.-
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/2xrvhkg {{%8|+B
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/8giez0v {~g
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/p0ipivu E}/|Lja
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/blhevqg ,z)NKt#
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/aizgbf4 b'5pQ2Mq
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/aayysqs *8H;KGe=
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/lrl3s0p QvN
<uxm
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/qdm29mf 9z/_`Xd_
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/7wzdi36 L0 2~FT
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/uq3ie99 RgA4@J#
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/o0q269b 7=A9E]:
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/x36ygyz jgw'MpQm{
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/n1z3k5y 2(//slP
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/rfgp93d ]?$y}
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/6m7kjlr \Pmk`^T
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/x24zgtf 1>y=i+T/b
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/os0eodl .@-]A
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/ds7p4vo >%dAqYi $
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/qlkuo5n SkRQFm0a~
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/5e4cktc ibs"Iv34
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/sjtm212 [+,U0OV,
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/3hvcu90 no6]{qn=6
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/3zzzb40 IFofFXv_
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/qwdd27x 5)NBM7h
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/wmkfipm G3^]Wwu
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/xdezffh "mDrJTWa
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/ocvu015 &"%|`gE
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/jpurffy 6G$tYfX
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/lvjgwbf 4(GgaQFO?
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/s5k6a4z R6mJFE*6T9
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/0d9tfpl F5[ITK]A4
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/o1ght7m r~_ /Jj
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/z93tfft ^>{;9lo<
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/5inxv2w -xIhN?r)
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/5j1769t VDjIs UUX
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/yc55sfx < DZ76
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/evwbcpn E*CQG;^=N
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/jd4rjmn `1<3Hu_
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/lq6ims1 _hL4@C
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/qjamjxe ,ri--<
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/imlsaag gr{Sh`Cm-
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/oli4gf7 TbAdTmW
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/ept8b7t ]u ~Fn2
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/ejka4lp HCkqh4
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/yugbwdy m+{: ^
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/7engpcr $!!=fFX*y
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/hjphmqr GSnHxs)
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/98nt06c [<a%\:c m4
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/aaxajib v^_]W3K
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/2c5upt7 aEdJ ri
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/p0ds0gg Sc3M#qm_
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/14k29y2 S_VncTIO
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/holqpkp E(+wl
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/3jml494 -f|^}j?
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/caemear 59BHGvaF
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/bvys13v B2qq C-hw?
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/41t5i8i c$:=d4t5$
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/09dy1g4 T8TsKjqOZ
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/gwezp2p jI<WzvhYG
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/6f02kx4 :gaeb8`t
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/xbev8i3 |0R%!v(,
github.com/devryanjohnson50322/trnfvn-pultow/releases/tag/zrq18zl aq/Y}s?
github.com/devryanjohnson50322/trnfvn-ypqwfx/releases/tag/1ba4j5p .x?zky^
github.com/devryanjohnson50322/trnfvn-ypqwfx/releases/tag/czd4rsh @<yc .>
github.com/devryanjohnson50322/trnfvn-ypqwfx/releases/tag/8eh18la Ny7=-]N4{"
github.com/devryanjohnson50322/trnfvn-ypqwfx/releases/tag/g3msj24 |P0L,R
github.com/devryanjohnson50322/trnfvn-ypqwfx/releases/tag/xxf43rd V?dK *8s
github.com/devryanjohnson50322/trnfvn-ypqwfx/releases/tag/8fleuu5 ~LW%lMy;^|
github.com/devryanjohnson50322/trnfvn-ypqwfx/releases/tag/9lwpvxv g]
C3lf-
github.com/devryanjohnson50322/trnfvn-ypqwfx/releases/tag/mwgk6az H6S vU
github.com/devryanjohnson50322/trnfvn-ypqwfx/releases/tag/acgc1ld ^-*Tn
github.com/devryanjohnson50322/trnfvn-ypqwfx/releases/tag/bg71bi6 gs8@b5 RSb
github.com/devryanjohnson50322/trnfvn-ypqwfx/releases/tag/9storug 7h&`BS
github.com/devryanjohnson50322/trnfvn-ypqwfx/releases/tag/p65dq51 ||ZufFO
github.com/devryanjohnson50322/trnfvn-ypqwfx/releases/tag/qvy83iw =1OAy`8
github.com/devryanjohnson50322/trnfvn-ypqwfx/releases/tag/ycc4hxd V^/^OR4k
github.com/devryanjohnson50322/trnfvn-ypqwfx/releases/tag/iaslrmf E(kb!Rz
github.com/devryanjohnson50322/trnfvn-ypqwfx/releases/tag/76vnkxg 0+y~RTAVB
github.com/devryanjohnson50322/trnfvn-ypqwfx/releases/tag/xqedd80 lT!$\E$1
github.com/devryanjohnson50322/trnfvn-ypqwfx/releases/tag/hvusjr7 ,bp pM
github.com/devryanjohnson50322/trnfvn-ypqwfx/releases/tag/vx6pt12 x&oBO{LNK,
github.com/devryanjohnson50322/trnfvn-ypqwfx/releases/tag/suu35bl Xb:BIp!e
github.com/devryanjohnson50322/trnfvn-ypqwfx/releases/tag/szmyc2y ^_h7!=W
github.com/devryanjohnson50322/trnfvn-ypqwfx/releases/tag/qut0x9z fA0=Y,pzv
github.com/devryanjohnson50322/trnfvn-ypqwfx/releases/tag/ecp8maj (DP9& b
github.com/devryanjohnson50322/trnfvn-ypqwfx/releases/tag/b1n2pbm JgKZ;GM:W
github.com/devryanjohnson50322/trnfvn-ypqwfx/releases/tag/p8e5mcb MGyB8(
github.com/devryanjohnson50322/trnfvn-ypqwfx/releases/tag/zer5id3 xjq7%R_,
github.com/devryanjohnson50322/trnfvn-ypqwfx/releases/tag/crxs38s KXA)i5z
github.com/devryanjohnson50322/trnfvn-ypqwfx/releases/tag/8fczfxs rIfGmh%H
github.com/devryanjohnson50322/trnfvn-ypqwfx/releases/tag/ya8tn40 4U;XqUY
github.com/devryanjohnson50322/trnfvn-ypqwfx/releases/tag/loskxwk T1!Gr!=
github.com/devryanjohnson50322/trnfvn-ypqwfx/releases/tag/nd32z3j Q<
