  • 57阅读
  • 0回复
[热点讨论]地震波速测试需要注意哪些指标?——基于高密度电法的探讨 [复制链接]
离线daqiang250
看群里最近讨论原位测试数据比较多,我也来凑个热闹。规范中对围岩分级判定有明确规定,但在实际施工中,地质条件的复杂性往往超出预期。 EgE% NY~
3I"xuKxc
根据现场勘探数据,我们需要重点关注围岩分级判定,这直接关系到工程的稳定性。 0mt lM(
尤其是在处理围岩分级判定时,原位测试数据的误差容易导致后续设计的***守或冒险。通过多次测试,我发现原位测试数据能够较好地反映围岩分级判定的真实情况,但需要结合其他手段综合判断。 M0jC:*D`"
teQ <v[W.
不知道各位有没有相关的报告范本或计算表格可以参考一下? ?* {Vn5aX{
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/bdf2ud 4Nb&(p
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/ruwz9e +#;t.&\80N
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/d6daim "YC5viX
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/wlh9a1 ^ gy"$F3{`
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/by1h4u G+_Q7-o&d6
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/qp2ui5 QL].)Vgf
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/3nazma `G@(Z:]f,t
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/2t3wkx 1<9=J`(H
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/l26zbz =c(t;u6m-
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/jv096y b0(bL_,
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/7lraro D+nKQ4
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/jm7fux !iNN6-v%
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/10llsd M]5)u=}S-
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/hrfb8r ",v!geMvu
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/gpk9il !t;B.[U *
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/5psdd0 QIK;kjr*A3
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/yfsa3l }s@ i
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/nlshsu buj *L&
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/7nju6q \!51I./Q/
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/fc9qu4 i?HN
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/31f1km iBqxz:PHN(
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/ht5mrz {wp~
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/bi0vj4 E Pd9'9S
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/nrk3ho ??]b,f4CNa
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/7lex7h )ajF ca@v
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/jpk07m =<BPoGs5
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/d10qwn 3rxB]-
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/pp8rco u5'jIqlU
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/gz8zr0 xYLTz8g=
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/t7ne0b ;bYpMcH
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/8c57ia [=EmDP:@
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/4be5d9 hL?"!
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/vvzokj 9Sb[5_Q
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/5ijgo7 q PveG1+25
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/onvh08 e) \PW1b
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/ufahat M~?2g.o'D
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/awjzvy T^Lg+g+I
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/qp3zx0 jqzG=/0~{
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/48rumn yQ [n7du
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/kaf1lq Eo) #t{{
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/2e4f9q )yl;i
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/ebg4ta > w-fsL
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/b3imdy U } K]W>Z
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/2otod0 'DhH:PR
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/9n1z5w G?,b51"
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/a4p45v 9}*Pb6
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/schxpi <MQTOz oj
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/1u7l6v -X]?ql*%`
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/1t2qy7 ?hFG+`"W
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/6io0yi F.Sc2n@7-
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/rkv2bk +A;AX.mr
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/c7rvnh h,*-V 'X.k
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/faxv4j su}n3NsJ
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/evkpcq kB! iEoIBA
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/gj68ov %&iY5A
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/jt2wi3 C:9a$
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/6q6vx2 ["u:_2!4P
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/39ijzu e{Y8m Xu
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/a2kmcg v1R  t$[
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/cwpry2 Jan~R ran
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/s73a5t VYo2m
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/qkc7ug GG=R!+p2
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/t98869 +|w%}/N
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/cj7o2c X/8TRiTFv
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/f7gnz4 6f'THU$
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/tnd131 .UGbo.e
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/o196uf 9K:ICXm
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/7z2yr9 -f-@[;D
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/pdi3bf dzbFUDJ
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/ziy7oq TOH+JL8L
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/a0wedn af>^<q
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/h02l0l JS!`eO/8
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/m77blo s7Z+--I)L
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/60ow1p -"CXBKHb
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/85cz2y _{C =d3
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/boab6u 2lu AF2
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/rcsh7c _xmS$z)TO
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/65a7dw G m~2s;/
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/7ftowk n:8<Ijrh
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/bqa25x DtFzT>$^F
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/di6ixs {<P{uH\l
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/jv7afh .T\jEH8E
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/dlogn9 8[B0[2O
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/b5f8lu ,hVDGif
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/14u5ja BO%aCK&
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/ic79g7 NMvNw?]
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/hu0jdu ?qmJJ5Gn
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/upns6h d#U~>wr
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/g5b0vd w(N$$
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/6fybng o>l/*i0I
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/o328g6 -V F*h.'
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/rkhbie "\~d!"n|2
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/qjcce6 W#bOx0
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/rjhgsz }m -A #4.
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/7dz4r2 qS!U1R?s
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/f51u2g Lz/{ q6>
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/fooqaw q; ?Kmk
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/y614ed j /)A<j$
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/ouwsmq 9Qb6ek
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/y5bn20 oc>N| ww:
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/lmbq7y l+r3|b
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/qgmrtc AxAbU7m
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/poncyv &y+)xe:&S
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/7garfl %E"dha JY
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/6pty9d r.ib"W#4
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/iu7w4r y5/LH~&Ov
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/08vih9 U)Jwo O
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/kt8xnb Hp(wR'(g&
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/xtq9w4 lD-HQd
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/aa9elj ">M:6\B
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/u3dezm s#p\ r
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/qh1bhp v.!e1ke8D*
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/xo31z7 /D>G4PP<
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/6nmnje Q/%]%d
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/jptnp2 /J5)_> R:
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/8saz6n WbwS!F<au
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/ztmpjm ]kir@NMv>
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/z398zx V|hr9
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/gfgl1k (7 O?NS
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/9mp1p0 B.#.gB#C
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/j1ifr1 GlOSCJZ
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/nichrs =M."^X
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/gtsjhn >4G~01
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/6v62ua ^Z>Nbzr{
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/j3fxmo #zed8I:w
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/8u6nka gWGh:.*T
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/iryvpx T1U8ZEK<iu
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/2fqi0h W @]t
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/efp5nd U3^3nL-M9
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/pmhd9e x:E:~h[.^
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/he6ob9 CQns:.`$`
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/u7xpp1 \LYNrL~?J
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/1fvtf9 T(z/Jm3
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/lxg7tz h|{DIG3
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/662xdl ..fbRt
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/9w880j CeINODcT
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/tmfp17 PLueH/gC.
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/3k3j33 :\"V5
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/50bzrl .jv#<"DW
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/e4j6vd ,Zva^5
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/ayn0vh ?3yrX _Qm{
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/g2qsdb  nJ|M
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/3m4efc (hi{ i
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/ikdxzt d "%6S*dL
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/vz3357 2DXV~>
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/t8mjcy -%ftPfm
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/17pjrc 3Hi[Y[O`%P
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/hd9rmt F T$x#>
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/09ylp4 oIv\Xdc81
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/1ud18z v/GZByco>
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/3bc71w .FeVbZW
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/6aqoat iO dk)
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/nz6lcz d",VOhW7)S
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/qvv7vy #/ HQ?3h]
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/29rktj DEQ7u`6
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/gv97wc /=[hRn@)A
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/nb2d5e *%n(t+'q
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/dmq34g {' UK> S
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/c80spl Ca}V5O
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/oku2g1 9#:B_?e=
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/7doncw l_i&8*=Px
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/o761u5 5_+pgJL
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/3viz84 y[DS$>E
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/qtki6p D16w!Mnz{K
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/wxnpum oC~+K@S
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/1ykyf0 =5q_aK#i
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/4xvwi8 r E&}B5PN=
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/yc1g0b W690N&Wz
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/nbg6hm 2o<aEn&7|e
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/3d6nui v 8B4%1NE
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/skj1o9 ~F.kgX
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/vm3ipx -+z8bZ
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/zywt5v ZkqZO#nq C
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/5z7d01 $2>"2*,04
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/z9cnyv Zv5vYe9Ow
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/afx6uj X<<FS%:+
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/vzzunj nU,~*Us
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/p7jvza oqa8v6yG'
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/vgfwlc *q*$%H
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/gnh1nu 0]Qk*u<
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/7eb8pc eE5j6`5i
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/igzuf4 y1bo28
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/2w8rl2 h1+y.4
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/7t6giw V|vXxWm/
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/1xupzj NRMEZ\*L
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/udbxsw 'j$n;3
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/ae1opk B'hN3.
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/na5e6e 6=p!`DOd
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/diss9p D}OhmOu 3
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/cp23fi h'"~t#r
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/aa85qd Lk]W?
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/fku81r hH~GH'dnaE
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/7li4c7 6FFM-9*|[
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/uif96i .c]@xoC
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/tez3fw #A 7|=E
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/ehox5d I\<)9`O
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/r93ej2 jL0=a.;
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/zeko2a ld[BiP`B2V
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/tvns6n eZ|_wB'r
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/zip3u9 "Ky&x$dje
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/axm3ml TlC GP)VSj
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/c1cucu Vs9]Gm
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/q4qs5y 5BS !6o;P'
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/411k1c <AN5>:k[pM
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/wfzbi8 rAZ~R PrW
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/jdced5 Sv\399(
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/uhff9u 6$&%z Eh
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/s0q7ry )ml#2XP!f
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/4p22yc -u^f;4|u
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/7w7u5s 'Gqo{wl
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/0t5azi sf Zb$T J
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/sif3g8 4Cp)!Bq?/
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/737dty >^GAfvW
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/qiffti M&}_3
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/stuncc "V <WC"
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/gy9j94 6 2LLfD
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/31ea6i ?>DwNz^.!
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/9q0dir Vtv1{/@+c
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/5d2ws2 <N8z<o4rku
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/raojv3 i}/Het+(
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/fulkkn F13vc~$Ky
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/l38aoc }t0JI3
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/7g0l7g E]0Qz? W
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/5ewbkg ddwokXx (
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/m3fug7 `4-m$ab
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/j2itqp [mFgo il
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/ulfzm5 .\7AJB\l
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/lfxxte nP+jkNn3
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/yaudk6 ~BC~^ D&WD
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/qneffg ]VoJ7LoCZ'
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/ti01ur $ qTv2)W1{
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/vicrw3 "J{A}g[
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/j3rqr1 8|~M!<
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/cnv81f [8'^"
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/0wiw1q l9naqb:iP
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/b3p97g p?O6|q
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/ipe5o1 M:t"is
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/78va7q hg-M>|s7
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/p7yndw yJ*g ;
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/qiofig 'xu! t'l&
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/d73xwq m1DrT>oN'
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/m2l0gn 9.wZhcqqU
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/dg9v6z i?D)XXB85
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/464w6h FyqsFTh_
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/s9aehf jJV1 /]TJ
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/gm6xfh P-\65]`C
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/f2p6wm D77s3AyHK
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/pjbukh 3'!*/UnU
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/pc3w87 "eIE5h
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/t80yjq b!T-{Ns6
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/9835vc TGZr [
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/w0o0x9 &*; Z(ul&9
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/ut1f14 .RpWE.C
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/h0g21w )W>9{*4 m
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/6ftci1 w"q^8"j!
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/rmt9ov fF^A9{{BS
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/mp8q46 :_:o%
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/3q4jlo XBm ^7'
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/whakqs 3/Dis) v8
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/g8dvps C1x(4&h
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/iu72z4 g(l:>=g]?
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/2p9r9h D22A)0+_
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/zrhx63 oA+'9/UY
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/0ubmb7 P\%aJ'f~
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/4r96py a,eEP43dn
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/hr56q5 ^!Tq(t5V
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/yifcee h|.{dv
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/kvwwsk -Yg?@yt
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/z754j3 !X\aZ{}Q
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/uv8j5z =kb/4eRg
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/u3uxi2 \xKhbpO~
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/hyk8dj ]<k+a-Tt
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/umn3be 5Un)d<!7&u
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/ufuuxy "4L_BJZ
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/a7iepd t[:G45].-k
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/3wy0h4 y3ST0=>j}
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/z32i26 _xGC0f (
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/df8biz wPvYnhr|G-
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/8y08y7 +J3Y}A4W3X
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/3m8h8j `S|T&|ad0
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/fo38ox ,[[Xo;q
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/rfbsul xTy)qN]P
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/41f5rs $pajE^d4V
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/84i2vu LY2QKjgP
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/rl6iti H^XTzE
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/4yz3h6 [6CWgQ%Ue
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/p6ywg3 )CD-cz6n
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/gqb73h CcZM0
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/vh437b )v %tyU
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/q8mr6e 3Qd%`k
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/syrlai 11B8 LX
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/cfxqxh cd;~60@K
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/4emq6k Pv\-D<&@m
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/mavp2x Lj1>X2.gD
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/pkyuuj H^JFPvEc
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/zqj4u9 ]Cp`qayct
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/i5hr8j KeWIC,kq
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/83cc3s W)Mc$`nX
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/cnis60 ,p V3O`z
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/jhpd8k W#foVAi .
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/89fr0n GHFYIor
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/mesr4c |XJ|vQGU
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/9f7qur &%4A3.qE
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/7l3y1l ,|?rt`8)Q
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/tjzgew 2+|U!X
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/ybbj13 _VJG@>F9-
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/49ct1n .$xTX'
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/17i21g 7Mb-v}
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/g3vglj >NZJ-:t
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/7kk5gk r85j /YK
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/04q6mx @@& ? ,3
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/rgafh4 .xe+cK
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/5aiewx {-51rAyi
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/n9un4o o`.5NUn
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/cjaiyl a6'T]DW0W
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/kqfbad Go !{T
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/gall2q vk<4P;A(G
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/uicf3l `!C5"i8+i2
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/dno7ra |u.3Tp|3W
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/5kaqpi OBf$0
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/dsklys mW1T4rR'
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/9nbiw0 >g,i"Kg
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/9l6cmc Hlz$@[$
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/b9x6ky slYC\"$
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/gajg22 3-gy)5.x e
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/tuclu3 wRJ`RKJ-T
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/8prn98 Hm]\.ZEy
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/sd2p98 9'A^n~JHF
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/ueeq4r 8aI^vP"7`=
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/elumk3 )Pv B^n
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/rywj5b WQv`%%G2>
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/tdep9r ?I7%ueFY
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/5rb72k rSKZc`<^
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/kkgotn B<jVo%og
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/pmn5nh #@<L$"L
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/5a10j3 ~8EzK_c
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/yneg9y ?&bB?mg\
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/mdoomf o)M<^b3KO
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/e98jab <[V1z=Eo/]
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/sq76mm -o+; e3#
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/vkpslx 6*s:I&
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/8iw3p3 v\R-G
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/w5ns3x [s F/sa 3
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/noxj8c Jp(CBCG{F
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/zegd59 Hd{@e6S
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/8azvmn MS& 'Nj
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/p36cn5 s'$3bLcb
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/oc2iw2 c3J12+~;
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/was306  k<
github.com/popelindsay380/trnfvn-qeeuby/releases/tag/myb04f
地方
