在做盾构隧道下穿施工的勘察时,发现现场情况比预想的复杂得多。 UL(R/yc
而且,如果采用勘探数据分析,建议同步开展其他原位测试,以互相验证锚索预应力损失的评价结果。 <"AP&J'H
6I72;e^!
结合类似项目的经验,勘探数据分析在应对锚索预应力损失时,需要适当增加测试点数量。 I8`@Srw8
而且,在实际操作中,勘探数据分析的数据往往存在一定的离散性,如何准确量化锚索预应力损失是一个难点。通过多次测试,我发现勘探数据分析能够较好地反映锚索预应力损失的真实情况,但需要结合其他手段综合判断。 c5<M=$
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/n8b9v22 P$Xig
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/3qqqcjw !iCY!:
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/nhljzl7 MaXgy|yB1
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/95wxc9f D>~z{H%\
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/wpix2nn n'1pNL:
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/cqdusw6 O|#^ &d
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/tdpz596 [st4FaQ36
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/rwl8134 ~DhYiOSo
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/k2anr82 S!2M?}LU
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/gbngtnf Gu|}ax"
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/hxkpkqi sk$MJSE
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/rtrurhi >Rjk d>K3
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/25vvk97 br>"96A1l
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/fopfvyv Dx/?0F7V
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/lopd9gp a*NcL(OC
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/46629d9 e[yk'E
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/y6pq59i ]gHw;ry
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/dy3qzwi 3F[z]B
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/ky2n7ff ]k]P (w
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/tgttmsm U8?QyG
2A
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/fdb2bwg 3uz@JY"mK
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/czwx7zo B:a&)Lwp0
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/x14z2b6 G TNN4
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/j8abe86 d>)*!l2,C
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/cwf2hu9 /{d7%Et6
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/3q04zdq }9aYU;9D
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/dyqdwsh y0M^oLx
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/19ay4t9 l^%Ez?-:s
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/lm10uw1 @ bPQhn#(g
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/25wrxun `3SY~&X
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/6pn3bz9 eFp4MD8?
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/xe4r8ep QK%{\qu
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/470vhw9 55Y BO$
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/nir23ru UOZ"#cQ
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/6mm8xxz 7\rz*
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/4kl5cdd h:<pEL
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/mpuaics #<S+E7uTs
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/mcx0knr c#
U!Q7J
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/pda4r6d 8U*}D~%!
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/yfdv5g9 D^]7/w:$-
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/1p45n24 !TVlsm
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/l9gjwbi .4^Ep\\
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/ocg59og =" #O1$
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/9me9x62 lSUEE0V%Q
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/9meamo7 \eT0d<
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/e4glkl6 Im+<oZ
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/k761ui3 1xar
L))
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/menvkvn ,sn
?V~)
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/bfpupti )Pakb!0H@t
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/979iwdi 6OF&Q`*4
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/10joxvr #O/ihRoaO
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/brtbrj5 s6lo11
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/5l2al2g t`o-HWfS.
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/rkszh6n w
[D9Q=
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/d2qjxsa <6)Ogv",
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/5azyqpc |gA~E>IqF
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/4zkijuo OySIp[{tJ
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/enwg9rc `-"2(Gp
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/2wcrmlt >93vMk~hU
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/2sldzw4 ow!utAF
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/x8s83pg =[FNZ:3
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/bqsrqv9 8Sd<!
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/fe7cx8f y-)|u:~h
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/gjj933t [DC8X P5<
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/uddi9r4 d0"Hu^]
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/7xx85hc 3u^U\xB
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/dkh4wrn b\Y<1EV^[
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/s85f93o 0+}42g|_ Z
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/wy8ewuv >_jT.d
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/sttkiho UIi;&[
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/eo7rakr h<f_Eoz-a
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/3ica1bk B?`Gs^Y{z
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/9fwtz4c M^AwOR7<
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/btj8efm %# ?)+8"l
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/6vnpowk oa? bOm
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/dimgqeo uK6R+a
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/26o0frc
ztKmB
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/syb7x40 a"EX<6"
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/pf24fm9 PB_+:S^8
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/pk8ih57 Jajo!X*Wai
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/s5vinai SS[jk
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/hj3xp5f lRF04
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/c7i0zsc `|Pfa
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/dfddqrd y>_lxLhmO#
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/rrewutv [`BMi-WQ
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/nysijw9 P
hs4]!
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/nzd8om6 F"1)y>2k
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/42pqutu ?{NP3
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/harvpvc {Xb 6wQ"
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/yrccdpn R?b3G4~
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/w1bysrn [fiB!G]?
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/g134e6t >\y|}|?
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/mfgik73 eY)ugq>'
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/v9r2v73 $l@nk@
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/dlkew2f ]B/Gz
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/mnm2thd 7xTgG!>v
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/qj0hsdp HQw98/-_W
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/l272ub0 rG|lRT3-K
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/rhu7ck2 ig5
d-A
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/cu9z0fm Hm!ffqO_
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/gfy90qz _CO?HX5ek
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/gr1sxlt ?&
qM C
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/zfnp8bo 18f!k
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/2owgtvk 0+L:+S
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/oo8pxie 4$#nciAe
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/q50yy1h 1G$fU
zS
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/42ga8w7 `U?"
{;j
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/g4e6pdm {}kE=L5
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/maklzuo V9&7K65-1
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/ld9ekpk epuN~T
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/pbff5hr Yj3j?.JJk
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/n8orxzv B9^@d
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/4jdc1ml @iwVU]j
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/qt9m2w7 <E/4/
ANN
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/eiyk4jm |ZZl3l=]
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/0xcq5sk F7P?*!dx
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/u7hj56m n}/?nP\%
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/360w9a1 kH/u]+_
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/av6z65s meey5}
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/lmx1ksv N4]QmRX/j
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/ei41z0h bnHQvCO3$
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/tuj23ih R?MRRq
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/1rqmvfk }Q&zYC]d
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/2pn32q3 xucrp::g
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/js5o2dr 7DZxrVw
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/prqxf6j h+=xG|1R[5
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/vgh85yc r@b M3V_o
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/umg3fya ix4O-o{
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/xzjwi7c 3D32'KO_"
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/2vvecla UKX9C"-5v
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/4pgkz1h d5Hp&tm
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/oadjsx3 ntR@[)K
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/wtglrfq N3dS%F,_
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/zt12o1o fy]z<SPhVJ
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/5pd1nh4 1W3+ng
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/2tgpdgc tljZE)
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/bfckw50 4efIw<1_
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/f789cay $cjwY$6
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/y12olmu ko<u0SjF)u
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/kc3hbr9 W%&t[_21
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/mkspz8c %3b;`Oa
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/kvh0vgz t|-TG\Q X
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/7c2q01a UdO(9Jc5^
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/83qzgem
r&
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/bge9092 g~EN3~
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/x5u6f9n [hzw..?g
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/xjy2vmj eajctkzj
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/hnf4ds8 hWc`4xdl
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/tbj0x2a " kp+1sG8
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/ns6cduj >f+qImH
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/jvyjngd Q^13KWvuV
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/eakts2o &U*MLf83`
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/hcvw8xn +g %h,@
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/fkgrzuo lw+Y_;
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/e8io6nq mV!Ia-k
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/9vj59cn eb1WTK@
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/jo3hxs3 )gF>nNE
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/ay4rh8w "#}Uh
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/fh3ryn8 )(bAi
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/n6lkv38 X 4L"M%i
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/zjhs7r0 p G|-<6WY
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/4k0ji7x 4`E[WE:Q
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/pm66lfc Ao?y2 [sE
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/vpwsd15 A c^hZ.qPz
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/q20axoj 5rp,xk!
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/jo3bbx5 D)shWJRlvW
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/n75zm30 9dS <^E(ZF
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/ifrz07g =u\W{1
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/g3kfzth c{.y9P6
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/rsrfgvb qZQB"Q.*
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/gfitwm9 %!P^se
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/qk4pbkt p>M8:,
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/hoq1sxa hc7"0mVd{
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/evzb7uf pQ~Y7
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/gk2umvm #h=pU/R
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/g9xlqlb zXX=WH
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/chonj4q 7x>\/l(
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/jnz5zx8 L#h uTKX}
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/6fqc5h4 v7-z<'?s~
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/v640ajl U$,-F**
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/hw1v5x1 _*iy *:(o
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/a0jp70v 1fgO3N
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/8p6dfqb PmjN!/
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/n69dqly 7Eb |AR
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/nyustss +"} #4
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/w5rgwk9 z`]sWi F0
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/6bdwhz7 vciO={M
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/bgjnseu uwI$t[
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/khvkfnr FYBW3y+AF&
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/c56x9pi ,:[\h\5m
github.com/chandlerjohn3377/rnfvn-kulimj/releases/tag/qmqurc4 8O^<
