  • 3643阅读
求助翻译 [复制链接]
离线104072005
只看楼主 倒序阅读 使用道具 楼主  发表于: 2008-09-18
请问高手帮帮忙忙哦!小妹有一句中文不知道怎么翻成英文好,小妹先谢谢大家了!
竹节桩的荷载变形曲线相对平缓,表现得更有后劲,极限承载力比等直径光滑圆管桩提高50%以上
离线twtw
只看该作者 1楼 发表于: 2008-09-19
load-deformation curve for bamboo-shaped pile shows relatively flat than same sized smooth tubular pile,its ultimate bearing capacity is more 50 percent higher than the latter.
圣人不死,大盗不止
离线z402429283
只看该作者 2楼 发表于: 2008-09-20
引用第1楼twtw于2008-09-19 00:22发表的  :
Sorry for interrupt some aspects:
Load-deformation curve for bamboo-shaped pile test shows some relatively flat comparing with the same sized smooth tubular pile's machanics characteristic in this aspect --the later's ultimate bearing capacity  is more 50% lower than the former one.
离线104072005
只看该作者 3楼 发表于: 2008-09-25
非常谢谢大家帮忙哦
离线funhhu
只看该作者 4楼 发表于: 2008-10-06
离线charmbo
只看该作者 5楼 发表于: 2008-11-26
Load-deformation curve of bamboo-shape pile shows
comparatively flat than smooth tubular pile with same diameter, and its ultimate bearing capacity is over 50 percent higher than the latter.
离线caicai
只看该作者 6楼 发表于: 2008-11-26
"表现得更有后劲", 是不是太中文了,不需要翻啊?
