  • 3730阅读
  • 13回复
关于数值模拟与工程监测 [复制链接]
离线马语者
只看楼主 倒序阅读 使用道具 楼主  发表于: 2008-10-15
不知大家如何看待数值模拟在工程中应用?其模拟的结果与实际监测成果能吻合到什么程度?可信度有多高?
因为本人对数值模拟知之甚少,因此前来请教
共1条评分
yuanap 土币 +30 2008-10-15
离线yuanap
只看该作者 1楼 发表于: 2008-10-15
互相验证
数值模拟作为比较有效和直观的一种计算机方法技术,
监测则直接反映工程结构的变化
二者互相验证和解释
隧道、岩土工程、灾害地质、构造地质、煤田地质
离线xbin962
只看该作者 2楼 发表于: 2008-10-16
有一些在实际工程很难测到的,或是要花费很多经费的,可以用数值模拟探索一下.
离线liuwj
只看该作者 3楼 发表于: 2008-10-16
定性分析还是可以的
定量分析,目前还不现实,强制吻合需要高超的“调参数和本构模型的知识”
离线woody007
只看该作者 4楼 发表于: 2008-10-21
这东西只能检验设计值,检验本构关系,对以后设计提供支持,但实际能用到的了是很少的。目前大多以检查安全状况为主,可以说数值模拟是呼声高,应用少,实际效果不大。只是做为写报告、论文的材料而已。
离线future2003
只看该作者 5楼 发表于: 2008-10-22
we all know that the the numbers from the numerical anlaysis may not be so reliable. it is true that it provides some reference information. But fully reling on it aslo causes problem. currenly I doing a deep excavation project just next to the existing MRT station. the requirement for this deep excavavation is the movement on the MRT station should be less than 15mm. It is a very small movement in consideration of such 40m deep excavation. You have to provide the evidence to show the movement is really less than 15mm, which of course can be provided only by numerical analysis.
离线future2003
只看该作者 6楼 发表于: 2008-10-22
I believe the relationship between monitoring and numerical analysis should be interactive.
First, you provide the numerical analysis based on the available SI data and numerical models.
Second, site monitoring should provide necessary information to support or verify the numerical analysis results. the effect of the site monitoring should be two fold. When the site movmenet is larger than the predication, it looks like the site conditions is worse than the assumption in the numerical models. we should reexamine our numerical model to see anything wrong with parameters. we can adjust the parameters when necessary. we can even propose more site invesitgation works to verify the site conditions. On site, we also have to have contigency plan to tack the unpredicted situation.
when the site movement is much less than the prediction, it may help to cut some construction materials to save some cost.
离线马语者
只看该作者 7楼 发表于: 2008-10-24
感谢各位的回复,期待更精彩的发言
离线lyf1260
只看该作者 8楼 发表于: 2008-10-24
大体规律能体现,但数值并不会很接近
离线gjj2001616
只看该作者 9楼 发表于: 2008-10-24
本构关系是关键,搞得明白,才能做得准确计算,要不数值计算也不会这么热了!!
离线红色高粱
只看该作者 10楼 发表于: 2008-10-27
就想问下数值模拟监测都用什么软件,是说实用,不是理想化的研究软件的.
离线0401020622
只看该作者 11楼 发表于: 2008-11-01
好书 谢谢分享
