  • 30796阅读
  • 159回复
[资料转载]几篇英文基坑支护论文 [复制链接]
离线zgjy1992
只看楼主 倒序阅读 使用道具 楼主  发表于: 2008-12-08
Anchored geo-support systems for landslide stabilization.pdf 2C@ui728
Bearing capacity and load-deformation characteristics of vibratory driven piles.pdf RT`jWWh*Lo
behavior of calculated nail head strength in soil-nailed structure.pdf kKFhbHUZa
Centrifuge modeling and analysis of active trapdoor in sand.pdf *_ U=KpZF
Centrifuge Modeling of Geosynthetic Reinforced Clay Liners of Landfills.pdf ;VS\'#{e
comparison of interface shear strength of soil nails measureed by both direct shear box tests and pullout tests.pdf /c&;WlE/n
design charts for piles supporting embankments on soft clay.pdf V-7A80!5
document.pdf ![ce=9@t<
dynamic failure mechanism of soil-nailed excavation models in centrifuge.pdf [ T6MaP?
Fundamental study on single anchor and anchor-reinforced systems.pdf !wU~;sL8C3
Landslide Stabilization Using Soil Nail and Mechanically Stabilized Earth Walls Case Study.pdf <`f~Z|/-_(
model tests of hydraulic performance of pit 6 daMulti-scale finite element modeling of strain localization in geomaterials with strong discontinuity.pdfm stilling basin.pdf _Nx#)(x
new approach to limit equilibrium and reliability analysis of soil nailed walls.pdf oEuV&m|yX
project-specific steel sheet piling applications.pdf o^\L41x3
simplified trial wedge method for soil nailed wall analysis.pdf * NB:"1x
soil-nail pullout interaction in loose fill materials.pdf ,rU>)X
Soil-Nailed Wall Under Piled Bridge Abutment Simulation and Guidelines.pdf G-DvM6T
Three dimensional slope stability analysis and support strategies for conical excavations..pdf ;X z fd
Using the impulse response technique to estimate the length of in-situ soil nails.pdf 4Odf6v,*@
附件: 几篇英文论文.part01.rar (3907 K) 下载次数:3199
共1条评分
glg007 土币 +10 f&e:相当的不错 2008-12-08
fudidi
离线zgjy1992
只看该作者 1楼 发表于: 2008-12-08
Anchored geo-support systems for landslide stabilization.pdf i?+>,r@\p
Bearing capacity and load-deformation characteristics of vibratory driven piles.pdf ] 'B4O1
behavior of calculated nail head strength in soil-nailed structure.pdf (2l?~CaK
Centrifuge modeling and analysis of active trapdoor in sand.pdf O0~Qh0~l
Centrifuge Modeling of Geosynthetic Reinforced Clay Liners of Landfills.pdf KE_GC ;bQ
comparison of interface shear strength of soil nails measureed by both direct shear box tests and pullout tests.pdf &^I2NpT
design charts for piles supporting embankments on soft clay.pdf Lj,!0 25
document.pdf \7d T]VV
dynamic failure mechanism of soil-nailed excavation models in centrifuge.pdf  |4_[wX r
Fundamental study on single anchor and anchor-reinforced systems.pdf ju8DmC5
Landslide Stabilization Using Soil Nail and Mechanically Stabilized Earth Walls Case Study.pdf zz7#g U
model tests of hydraulic performance of pit 6 daMulti-scale finite element modeling of strain localization in geomaterials with strong discontinuity.pdfm stilling basin.pdf Qp5YS
new approach to limit equilibrium and reliability analysis of soil nailed walls.pdf '",+2=JJ
project-specific steel sheet piling applications.pdf *#| lhf'
simplified trial wedge method for soil nailed wall analysis.pdf }#Q?\
soil-nail pullout interaction in loose fill materials.pdf VGVb3@
Soil-Nailed Wall Under Piled Bridge Abutment Simulation and Guidelines.pdf 'KU)]v
Three dimensional slope stability analysis and support strategies for conical excavations..pdf <y!(X"n`
附件: 几篇英文论文.part02.rar (3907 K) 下载次数:1819
fudidi
离线zgjy1992
只看该作者 2楼 发表于: 2008-12-08
Anchored geo-support systems for landslide stabilization.pdf &x#3N=c#
Bearing capacity and load-deformation characteristics of vibratory driven piles.pdf S#|dmg;p
behavior of calculated nail head strength in soil-nailed structure.pdf +vSp+X1E
Centrifuge modeling and analysis of active trapdoor in sand.pdf 8wX|hK!Gz
Centrifuge Modeling of Geosynthetic Reinforced Clay Liners of Landfills.pdf }u `~lw(Z
comparison of interface shear strength of soil nails measureed by both direct shear box tests and pullout tests.pdf  (%\tE
design charts for piles supporting embankments on soft clay.pdf ;+Mee ^E>!
document.pdf N+#lS7
dynamic failure mechanism of soil-nailed excavation models in centrifuge.pdf % k}+t3aF
Fundamental study on single anchor and anchor-reinforced systems.pdf XZew$Om[
Landslide Stabilization Using Soil Nail and Mechanically Stabilized Earth Walls Case Study.pdf 'Cp]Q@]\
model tests of hydraulic performance of pit 6 daMulti-scale finite element modeling of strain localization in geomaterials with strong discontinuity.pdfm stilling basin.pdf )_H>d<di
new approach to limit equilibrium and reliability analysis of soil nailed walls.pdf 's>./Pf
project-specific steel sheet piling applications.pdf -Z<V? SFOK
simplified trial wedge method for soil nailed wall analysis.pdf =9;2(<A
soil-nail pullout interaction in loose fill materials.pdf s~)I1G
Soil-Nailed Wall Under Piled Bridge Abutment Simulation and Guidelines.pdf }TDoQ]P
Three dimensional slope stability analysis and support strategies for conical excavations..pdf <0M 2qt8
附件: 几篇英文论文.part03.rar (3907 K) 下载次数:789
fudidi
离线zgjy1992
只看该作者 3楼 发表于: 2008-12-08
Anchored geo-support systems for landslide stabilization.pdf U'Mxf'q
Bearing capacity and load-deformation characteristics of vibratory driven piles.pdf TEEt]R-y
behavior of calculated nail head strength in soil-nailed structure.pdf )C^@U&h&
Centrifuge modeling and analysis of active trapdoor in sand.pdf ,mY3oyu
Centrifuge Modeling of Geosynthetic Reinforced Clay Liners of Landfills.pdf ol#4AU`
comparison of interface shear strength of soil nails measureed by both direct shear box tests and pullout tests.pdf rF:l+I]
design charts for piles supporting embankments on soft clay.pdf so]p1@K
document.pdf Vgg' 5o&.
dynamic failure mechanism of soil-nailed excavation models in centrifuge.pdf b&_u+g
Fundamental study on single anchor and anchor-reinforced systems.pdf $;Nw_S@
Landslide Stabilization Using Soil Nail and Mechanically Stabilized Earth Walls Case Study.pdf -nL!#R{e
model tests of hydraulic performance of pit 6 daMulti-scale finite element modeling of strain localization in geomaterials with strong discontinuity.pdfm stilling basin.pdf 9u^yEqG`
new approach to limit equilibrium and reliability analysis of soil nailed walls.pdf -h`[w:
project-specific steel sheet piling applications.pdf Y *?hA'
simplified trial wedge method for soil nailed wall analysis.pdf iYR`|PJi
soil-nail pullout interaction in loose fill materials.pdf ySP%i6!au
Soil-Nailed Wall Under Piled Bridge Abutment Simulation and Guidelines.pdf 6z3`*B
Three dimensional slope stability analysis and support strategies for conical excavations..pdf w dpd`
附件: 几篇英文论文.part04.rar (3907 K) 下载次数:644
fudidi
离线zgjy1992
只看该作者 4楼 发表于: 2008-12-08
Anchored geo-support systems for landslide stabilization.pdf )"sJaHx<
Bearing capacity and load-deformation characteristics of vibratory driven piles.pdf Y2&hf6BE
behavior of calculated nail head strength in soil-nailed structure.pdf zAA3bgaa
Centrifuge modeling and analysis of active trapdoor in sand.pdf D:DtP6
Centrifuge Modeling of Geosynthetic Reinforced Clay Liners of Landfills.pdf +j!$88%Z{
comparison of interface shear strength of soil nails measureed by both direct shear box tests and pullout tests.pdf |3K]>Lio
design charts for piles supporting embankments on soft clay.pdf rWS],q=c
document.pdf J*zm*~8\
dynamic failure mechanism of soil-nailed excavation models in centrifuge.pdf }48 o{\
Fundamental study on single anchor and anchor-reinforced systems.pdf '1NZSiv+C?
Landslide Stabilization Using Soil Nail and Mechanically Stabilized Earth Walls Case Study.pdf s<b(@L 1
model tests of hydraulic performance of pit 6 daMulti-scale finite element modeling of strain localization in geomaterials with strong discontinuity.pdfm stilling basin.pdf ~]S%b3>
new approach to limit equilibrium and reliability analysis of soil nailed walls.pdf 9_&N0>OF
project-specific steel sheet piling applications.pdf tg#d.(
simplified trial wedge method for soil nailed wall analysis.pdf U3rpmml
soil-nail pullout interaction in loose fill materials.pdf Y3M"a8e'
Soil-Nailed Wall Under Piled Bridge Abutment Simulation and Guidelines.pdf pY"&=I79tb
Three dimensional slope stability analysis and support strategies for conical excavations..pdf 8v12<ktR`
附件: 几篇英文论文.part05.rar (3907 K) 下载次数:521
附件: 几篇英文论文.part06.rar (3907 K) 下载次数:926
fudidi
离线zgjy1992
只看该作者 5楼 发表于: 2008-12-08
Anchored geo-support systems for landslide stabilization.pdf %&\DCAFk
Bearing capacity and load-deformation characteristics of vibratory driven piles.pdf G$7!/O%#_
behavior of calculated nail head strength in soil-nailed structure.pdf yE=tuHv(0
Centrifuge modeling and analysis of active trapdoor in sand.pdf CWx_9b zk
Centrifuge Modeling of Geosynthetic Reinforced Clay Liners of Landfills.pdf 71wtO
comparison of interface shear strength of soil nails measureed by both direct shear box tests and pullout tests.pdf ^>/] Qi
design charts for piles supporting embankments on soft clay.pdf ;]I~AGH:
document.pdf i^_?C5
dynamic failure mechanism of soil-nailed excavation models in centrifuge.pdf -_p@I+B
Fundamental study on single anchor and anchor-reinforced systems.pdf .'Rz tBv
Landslide Stabilization Using Soil Nail and Mechanically Stabilized Earth Walls Case Study.pdf O@7={)6qc
model tests of hydraulic performance of pit 6 daMulti-scale finite element modeling of strain localization in geomaterials with strong discontinuity.pdfm stilling basin.pdf v_L?n7c
new approach to limit equilibrium and reliability analysis of soil nailed walls.pdf kgGMA 7Jy
project-specific steel sheet piling applications.pdf JM>4m)h#
simplified trial wedge method for soil nailed wall analysis.pdf t}m"rMbt
soil-nail pullout interaction in loose fill materials.pdf >DkRl
Soil-Nailed Wall Under Piled Bridge Abutment Simulation and Guidelines.pdf rd hM#?
Three dimensional slope stability analysis and support strategies for conical excavations..pdf U!D\Vd
附件: 几篇英文论文.part07.rar (3907 K) 下载次数:430
附件: 几篇英文论文.part08.rar (3907 K) 下载次数:578
fudidi
离线zgjy1992
只看该作者 6楼 发表于: 2008-12-08
Fundamental study on single anchor and anchor-reinforced systems.pdf ~z&Ho
Landslide Stabilization Using Soil Nail and Mechanically Stabilized Earth Walls Case Study.pdf Fb^f`UI
model tests of hydraulic performance of pit 6 daMulti-scale finite element modeling of strain localization in geomaterials with strong discontinuity.pdfm stilling basin.pdf w7"&\8a
new approach to limit equilibrium and reliability analysis of soil nailed walls.pdf %YV3-W8S0
project-specific steel sheet piling applications.pdf ~X2 cTG!,
simplified trial wedge method for soil nailed wall analysis.pdf <52)
soil-nail pullout interaction in loose fill materials.pdf _a&Mk
Soil-Nailed Wall Under Piled Bridge Abutment Simulation and Guidelines.pdf -l i71.M
Three dimensional slope stability analysis and support strategies for conical excavations..pdf <v+M~"%V
附件: 几篇英文论文.part09.rar (3907 K) 下载次数:560
附件: 几篇英文论文.part10.rar (3907 K) 下载次数:711
fudidi
离线zgjy1992
只看该作者 7楼 发表于: 2008-12-08
Fundamental study on single anchor and anchor-reinforced systems.pdf F2WMts
Landslide Stabilization Using Soil Nail and Mechanically Stabilized Earth Walls Case Study.pdf ("T8mt[w>
model tests of hydraulic performance of pit 6 daMulti-scale finite element modeling of strain localization in geomaterials with strong discontinuity.pdfm stilling basin.pdf 1WJ%n;
new approach to limit equilibrium and reliability analysis of soil nailed walls.pdf ?I}0[+)V
project-specific steel sheet piling applications.pdf =qy{8MsjA
simplified trial wedge method for soil nailed wall analysis.pdf NWt5)xl
soil-nail pullout interaction in loose fill materials.pdf s3+6Z~g'B
Soil-Nailed Wall Under Piled Bridge Abutment Simulation and Guidelines.pdf MgG_D6tDM
Three dimensional slope stability analysis and support strategies for conical excavations..pdf =!P
附件: 几篇英文论文.part11.rar (3907 K) 下载次数:350
附件: 几篇英文论文.part12.rar (3907 K) 下载次数:331
fudidi
离线zgjy1992
只看该作者 8楼 发表于: 2008-12-08
soil-nail pullout interaction in loose fill materials.pdf g6l&;S40
Soil-Nailed Wall Under Piled Bridge Abutment Simulation and Guidelines.pdf  Zzea
Three dimensional slope stability analysis and support strategies for conical excavations..pdf >X0c:p Pu
附件: 几篇英文论文.part13.rar (3907 K) 下载次数:357
附件: 几篇英文论文.part14.rar (2371 K) 下载次数:348
fudidi
离线308895124
只看该作者 9楼 发表于: 2008-12-08
离线308895124
只看该作者 10楼 发表于: 2008-12-08
离线308895124
只看该作者 11楼 发表于: 2008-12-08
