您在提高工作效率一贴中提到这个程序: NfND@m{/
用以下这段Lisp程序就可以快速地将图中的坐标标注在图中指定的位置. 9v?rNJs
(DEFUN C:zb() IubzHf
(command "dimzin" "0") y/;DA=
(command "layer" "new" "zb_1" "") _71&".A
(setvar "clayer" "zb_1" ) 3*#$:waGd
(command "color" 1) hQwUwfoe@
(command "style" "zb" "complex.shx" "0" "0.75" "0" "n" "n" "n") 0.0r?T
(command "osnap" "int") qflOi8
(command "osnap" "end") 6 jU?~
(command "osmode" 1) |>Pz#DCy
(SETQ P1 (GETPOINT"Pick the zb point:")) 8f>v[SQ"
(command "osmode" 0) ZDx1v_xr
(SETQ P2 (GETPOINT P1)) <['ucp
(SETQ X1 (LIST (CAR P2)(+ (CADR P2) 2))) DqA$%b
yyE
(SETQ Y1 (LIST (CAR P2)(- (CADR P2) 7))) He1~27+99
(SETQ X2 (LIST (+ (CAR P2) 6)(CADR X1))) UL]zuW/
(SETQ Y2 (LIST (+ (CAR P2) 6)(CADR Y1))) F0ylJ
/E
(SETQ XX (RTOS (CAR P1) 2 3)) }gKY_e3
(SETQ YY (RTOS (CADR P1) 2 3)) Wn&9R
j
(SETQ L1 (STRLEN XX)) Xa_:B\ic
(SETQ L2 (STRLEN YY)) =kjD ]+l
(IF (>= L1 L2)(SETQ L (* L1 5))(SETQ L (* L2 5)))
3 EOuJ
(COMMAND"LINE" P1 P2"") g"v6UZ\
(command "layer" "new" "zb_2" "") T$1(6<:+.
(setvar "clayer" "zb_2" ) D*t[5,~j
(IF (>= (CAR P2)(CAR P1)) )0zg1z
(PROGN 58t~? 2E
(SETQ P3 (LIST (+ (CAR P2) ( * L 0.85))(CADR P2))) gf70 O>E
(setq p4 (list (+ (car p3) 5)(cadr p2)))
+Ou<-EQV
(COMMAND"LINE" P2 P3"") )WsR
8tk
(setq p5 (list (+ (car p3) 2.5)(- (cadr p3) 2.5))) g1I8_!}~
(COMMAND"TEXT" X2 5 0 YY) -%TwtO<$']
(COMMAND"TEXT" Y2 5 0 XX) gUH|?@f
(COMMAND"TEXT" X1 5 0 "N") -q&7q
(COMMAND"TEXT" Y1 5 0 "E") }fL
) d#|%h]
(PROGN H
$mZ?
(SETQ P3 (LIST (- (CAR P2) ( * L 0.85))(CADR P2))) qAi:F=> X
(setq p4 (list (- (car p3) 5)(cadr p2)))
Y}e3:\
(SETQ XX1 (LIST (+ (CAR P3) 1)(+ (CADR P3) 2))) 4"#F=f0
(SETQ YY1 (LIST (+(CAR P3) 1)(- (CADR P3) 7))) dpcU`$kt
(SETQ X22 (LIST (+ (CAR P3) 6)(CADR XX1))) z?W kHQ9
(SETQ Y22 (LIST (+ (CAR P3) 6)(CADR YY1))) \d-9Ndp
nf
(COMMAND"LINE" P2 P3"") \0.!al0
(setq p5 (list (- (car p3) 8)(- (cadr p3) 2.5))) *Rgl(Ba
(COMMAND"TEXT" X22 5 0 YY) 't+'rG6x
(COMMAND"TEXT" Y22 5 0 XX) ]T._TZ"
(COMMAND"TEXT" XX1 5 0 "N") =Y*zF>#lP
(COMMAND"TEXT" YY1 5 0 "E") &neB$m3y
) 5h6-aQU[
) {m/KD 'b_
) ^+x ,211f
(DEFUN C:zb3() ce7$#
# f
(command "dimzin" "0") ]-jaIvM
(command "layer" "new" "zb_1" "") 6\USeZh
(setvar "clayer" "zb_1" ) 5?*Iaw
(command "color" 1) @?5pY^>DK
(command "style" "zb" "complex.shx" "0" "0.75" "0" "n" "n" "n") TGuCIc0B{
(command "osnap" "int") @./@"mR<
(command "osnap" "end") t(1gJZs>kX
(command "osmode" 1) W4"1H0s`l
(SETQ P1 (GETPOINT"Pick the zb point:")) S^{tRPF%d
(command "osmode" 0) )!=fy']
(SETQ P2 (GETPOINT P1)) c3(0BSv
(SETQ X1 (LIST (CAR P2)(+ (CADR P2) 1))) EpK7VW
(SETQ Y1 (LIST (CAR P2)(- (CADR P2) 4))) s:ojlmPb
(SETQ X2 (LIST (+ (CAR P2) 5)(CADR X1))) m O"Rq5
(SETQ Y2 (LIST (+ (CAR P2) 5)(CADR Y1))) /$^SiE+N
(SETQ XX (RTOS (CAR P1) 2 3)) =yZ6 $ hK
(SETQ YY (RTOS (CADR P1) 2 3)) {v*X}`.h
(SETQ L1 (STRLEN XX)) y=zs6HaS
(SETQ L2 (STRLEN YY)) H/l,;/q]b
(IF (>= L1 L2)(SETQ L (* L1 2.4))(SETQ L (* L2 2.4))) .t.4y.
97
(COMMAND"LINE" P1 P2"") Sobp;OZ5
(command "layer" "new" "zb_2" "") j-zWckT{
(setvar "clayer" "zb_2" ) 3:bP>l!
(IF (>= (CAR P2)(CAR P1)) 'j;i4ie>*x
(PROGN WF-^pfRq~
(SETQ P3 (LIST (+ (CAR P2) L)(CADR P2))) SK5__Ix
(setq p4 (list (+ (car p3) 3)(cadr p2))) I].ddR%
(COMMAND"LINE" P2 P3"") zvwv7JtB
(COMMAND"TEXT" X2 2.5 0 YY) BO0Y#fs
(COMMAND"TEXT" Y2 2.5 0 XX) }ISR +./+
(COMMAND"TEXT" X1 2.5 0 "N=") K0Lc~n/
(COMMAND"TEXT" Y1 2.5 0 "E=") ~h$
H@&5
) `d4;T|f+=
(PROGN .F3~eas
(SETQ P3 (LIST (- (CAR P2) L)(CADR P2))) nPhREn!
(setq p4 (list (- (car p3) 3)(cadr p2))) [nLd> 2P
(SETQ XX1 (LIST (CAR P3)(+ (CADR P3) 1))) *i V#_
(SETQ YY1 (LIST (CAR P3)(- (CADR P3) 4))) 6kO+E5;X
(SETQ X22 (LIST (+ (CAR P3) 4)(CADR XX1))) ,.AXQ#~&`
(SETQ Y22 (LIST (+ (CAR P3) 4)(CADR YY1))) rges`&0
(COMMAND"LINE" P2 P3"") 4iY
<7l8
(COMMAND"TEXT" X22 2.5 0 YY) K~+x@O*
(COMMAND"TEXT" Y22 2.5 0 XX) _ME?o
(COMMAND"TEXT" XX1 2.5 0 "N=") A>6_h1
(COMMAND"TEXT" YY1 2.5 0 "E=") s8SCEpz
) I5E+=.T*ar
) 74a k|(!
) et<@3wyd]
(DEFUN C:zb2() *
yGlX[
(command "dimzin" "0") e#@u&+K/f
(command "layer" "new" "zb_1" "") #M<u^$Jz
(setvar "clayer" "zb_1" ) irMBd8WG
(command "color" 1) !}q@O-}j
(command "style" "zb" "complex.shx" "0" "0.75" "0" "n" "n" "n") mh35S!I3I^
(command "osnap" "int") 0%qM`KZC
(command "osnap" "end") `HILsU=|
(command "osmode" 1) |-xKH.'n
(SETQ P1 (GETPOINT"Pick the zb point:")) oI"gQFGu`u
(command "osmode" 0) $]MOAj"LH
(SETQ P2 (GETPOINT P1)) .}Hs'co
(SETQ X1 (LIST (CAR P2)(+ (CADR P2) 1))) Q}uh`?t
(SETQ Y1 (LIST (CAR P2)(- (CADR P2) 2))) \zzPsnFIg
(SETQ X2 (LIST (+ (CAR P2) 2.5)(CADR X1))) wsgT`M'J[
(SETQ Y2 (LIST (+ (CAR P2) 2.5)(CADR Y1))) ~*L@|?
(SETQ XX (RTOS (CAR P1) 2 3)) Yu:($//w
(SETQ YY (RTOS (CADR P1) 2 3)) l"%WXi"X
(SETQ L1 (STRLEN XX)) w:2yFC
(SETQ L2 (STRLEN YY)) V o%GO9b;
(IF (>= L1 L2)(SETQ L (* L1 1))(SETQ L (* L2 1))) ]W7&ZpF
(COMMAND"LINE" P1 P2"") = Q"(9[Az
(command "layer" "new" "zb_2" "") eBqF@'DQ
(setvar "clayer" "zb_2" ) O^IS:\JX&
(IF (>= (CAR P2)(CAR P1)) 3935cxT1U
(PROGN Hk?E0.
(SETQ P3 (LIST (+ (CAR P2) L)(CADR P2))) aT8A+=K6
(setq p4 (list (+ (car p3) 3)(cadr p2))) y1#QP3'Z1
(COMMAND"LINE" P2 P3"") 3iw.yR
(COMMAND"TEXT" X2 1.25 0 YY) 5uU{!JuSa
(COMMAND"TEXT" Y2 1.25 0 XX) g_)i)V
(COMMAND"TEXT" X1 1.25 0 "N=") E//*bmww
(COMMAND"TEXT" Y1 1.25 0 "E=") |;R-q8
) X/H2c"!t
(PROGN NN~PWy1opa
(setq l (* l 1.1)) `+(4t4@ew
(SETQ P3 (LIST (- (CAR P2) L)(CADR P2))) $'KhA6u
(setq p4 (list (- (car p3) 3)(cadr p2))) \wV ?QH
(SETQ XX1 (LIST (CAR P3)(+ (CADR P3) 1))) 0oo_m6ie&
(SETQ YY1 (LIST (CAR P3)(- (CADR P3) 2))) tD])&0"(
(SETQ X22 (LIST (+ (CAR P3) 2.5)(CADR XX1))) m}+_z^@j9
(SETQ Y22 (LIST (+ (CAR P3) 2.5)(CADR YY1))) 1-PFM-
(COMMAND"LINE" P2 P3"") lM.k*`$
(COMMAND"TEXT" X22 1.25 0 YY) W=4|ahk$
(COMMAND"TEXT" Y22 1.25 0 XX) hA+;eXy/
(COMMAND"TEXT" XX1 1.25 0 "N=") {'cdi`
(COMMAND"TEXT" YY1 1.25 0 "E=") M1I4Ot
) %:y"o_X_
) r@ba1*y0
) d.k'\1o
(DEFUN C:zb5() BJjx y0+
(setq cc 1) :|Bzbn=N2
(setq cc (getint "输入点编号<1>:")) Pt7C/
qM/
(repeat 1000 t![972.&
(command "style" "zb" "complex.shx" "0" "0.75" "0" "n" "n" "n") -v=tM6
(command "dimzin" "0") n6{nx[%7N7
(command "layer" "new" "zb_1" "") |T{ZDJ+
(setvar "clayer" "zb_1" ) B RtT 7
(command "color" 1) lr$,=P`
(command "osnap" "int") xLw[
aYy4
(command "osnap" "end") )6
K)UA
(command "osmode" 1) 7eG@)5Uy
(SETQ P1 (GETPOINT"Pick the zb point:")) <Ys7`e6eY
(command "osmode" 0) TSj)XU {W
(SETQ P2 (GETPOINT P1)) 4Y d$RP
(SETQ X1 (LIST (CAR P2)(+ (CADR P2) 2))) \3whM6tK
(SETQ Y1 (LIST (CAR P2)(- (CADR P2) 7))) |UN#utw{^Y
(SETQ X2 (LIST (+ (CAR P2) 6)(CADR X1))) 0gr#<(
(SETQ Y2 (LIST (+ (CAR P2) 6)(CADR Y1))) 8KWhXF
(SETQ XX (RTOS (CAR P1) 2 3)) c[EG
cY={
(SETQ YY (RTOS (CADR P1) 2 3)) |`Be(
(SETQ L1 (STRLEN XX)) l#a*w
(SETQ L2 (STRLEN YY)) %3T:W\h
(IF (>= L1 L2)(SETQ L (* L1 5))(SETQ L (* L2 5))) Pz-=Eq
(COMMAND"LINE" P1 P2"") GuQ#
(command "layer" "new" "zb_2" "") wD SSgk
(setvar "clayer" "zb_2" ) Y{L|ja%9?
(IF (>= (CAR P2)(CAR P1)) Y^gIvX
(PROGN LP) IL~
(SETQ P3 (LIST (+ (CAR P2) ( * L 0.85))(CADR P2))) j&0t!f.Rv
(setq p4 (list (+ (car p3) 7)(cadr p2))) QY$4D;M`g6
(command"circle" p4 7"") d4o_/[
(COMMAND"LINE" P2 P3"") a]4|XJ_
(setq bb 2.5) fa,;Sw
(IF (<= cc 9 )(setq bb 5)) j2 jUrl
(setq p5 (list (+ (car p3) bb)(- (cadr p3) 2.5))) EHm:&w
(COMMAND"TEXT" X2 5 0 YY) JB HnJm
(COMMAND"TEXT" Y2 5 0 XX) Z$S0X$q}
PRK*7-(
(COMMAND"TEXT" Y1 5 0 "E") B|S X?X
(IF (>= cc 10)(command "style" "zb" "complex.shx" "0" "0.9" "0" "n" "n" "n")) EC?U#!kv
(IF (>= cc 100)(command "style" "zb" "complex.shx" "0" "0.65" "0" "n" "n" "n")) =h}PL22
(IF (>= cc 1000)(command "style" "zb" "complex.shx" "0" "0.5" "0" "n" "n" "n")) cyWDtq
(command"text" p5 6 0 cc) '>>@I~<\
) m^4O jik
(PROGN n;k
B_i*l
(SETQ P3 (LIST (- (CAR P2) ( * L 0.85))(CADR P2))) Ps~)l#gue
(setq p4 (list (- (car p3) 7)(cadr p2))) -;$jo-
(SETQ XX1 (LIST (+ (CAR P3) 1)(+ (CADR P3) 2))) bjFND]p?w
(SETQ YY1 (LIST (+(CAR P3) 1)(- (CADR P3) 7))) ~HXZ-*
(SETQ X22 (LIST (+ (CAR P3) 6)(CADR XX1))) $B`bsJ
sVP2$?
(COMMAND"LINE" P2 P3"") t_Ul;HVPS
(command"circle" p4 7) CN7qqd
(setq bb 12) +Q!Kj7EU/
(IF (<= cc 9 )(setq bb 8)) BA_l*h%=Cc
(setq p5 (list (- (car p3) bb)(- (cadr p3) 2.5))) (ewcj\l4*
(COMMAND"TEXT" X22 5 0 YY) }tedh
(COMMAND"TEXT" Y22 5 0 XX) IXsOTBM
(COMMAND"TEXT" XX1 5 0 "N") 7G_OFD
(COMMAND"TEXT" YY1 5 0 "E") 8\[qR_LV
(IF (>= cc 10)(command "style" "zb" "complex.shx" "0" "0.9" "0" "n" "n" "n")) ?{>5IjL)en
(IF (>= cc 100)(command "style" "zb" "complex.shx" "0" "0.65" "0" "n" "n" "n")) C12y_E8Un
(IF (>= cc 1000)(command "style" "zb" "complex.shx" "0" "0.5" "0" "n" "n" "n")) @@|H8mP}H
(command"text" p5 6 0 cc) N~B'gJJDx
) =GLMdhD]
) v [>8<z8
(setq cc (+ cc 1)) `(8RK
%Z(lTvqG
) uQkQ#'e|
) B9oB5E
这个LISP程序怎么创建,怎么运行,请指教
