  • 1736阅读
盾构姿态\盾构法施工过程中隧道轴线的控制分析 [复制链接]
离线yy67
只看楼主 倒序阅读 使用道具 楼主  发表于: 2008-12-18
离线monkeylzx
只看该作者 1楼 发表于: 2010-05-21
很感谢楼主分享,多谢了.学习学习.
离线tumu068
只看该作者 2楼 发表于: 2010-05-21
非常感谢!
离线wenzhanzhen
只看该作者 3楼 发表于: 2010-10-18
During the construction of shie ld tunnels,support pressure is usually applied at the work face to prevent <EO<x D=:
excessive tunneling—induced soil movement or collapse.However,the selection and control of appropriate support FnHi(S|A
pressure is difficult due to variation of soil conditions and uncerlainty in construction.Support pressure should be N6Z{BLZ
controlled SO that it is not SO low as to cause face collapse and not SO high as to induce ground hogging.Numerical ;,O fJ'q^
simulation is employed to study how the soil parameter and ground water affect the support pressure,and to give the qO`qJ/
proper support pressure at the excavation face in a case study. PKq-@F%X
Keywords:shield tunnel;excavati‘on face;numerical solution;support pressure
