  • 2667阅读
[求助]Plaxis 2D中单桩如何模拟? [复制链接]
离线wcddxshfd
只看楼主 倒序阅读 使用道具 楼主  发表于: 2009-01-15
我是plaxis新人,请教各位达人,plaxis中如何模拟一跟单桩呢?是用轴对称模型来模拟,用几何线来划,还是用板单元来模拟,具体该如何进行,界面怎么处理,边界条件怎么处理,有点乱,望能人给予指教。谢谢!
还没想好
离线gcoast
只看该作者 1楼 发表于: 2009-01-15
引用楼主wcddxshfd于2009-01-15 08:06发表的 Plaxis 2D中单桩如何模拟? :
Hi,
Depend what you want from your modelling, There is not excally solution for what your modelling, Engineering judgement is needed. Generally, There is a example in Dynamic manual. it is using axi-symatric model, if you like to get the bending moment for this model, put a plate element in the middle of pile, using Ep/1000 (i.e. reduce you moment 1000 times) as an imput, once you get the calculated Moment from PLAXIS, then time 1000 back you wourl get the realy moment on the pile.
I would have thought that Engineering judgement has a higher priority than phycical modelling. it would give you the solution straight away.
Hope it would help
Cheers,
离线wcddxshfd
只看该作者 2楼 发表于: 2009-01-15
楼上的何意? 我的意思是模拟单桩的承载力,不是求弯矩,比如说模拟扩底桩的单桩承载和变形性状,在plaxis 2D中该如何实现?
还没想好
离线hohai
只看该作者 3楼 发表于: 2009-09-22
http://www.yantubbs.com/read.php?tid=55051
用gts模拟桩的p-s曲线关键讲解
看看
