  • 2784阅读
[求助]各位大侠帮忙看看程序到底出了什么问题flac3d [复制链接]
离线fangyang139
只看楼主 倒序阅读 使用道具 楼主  发表于: 2009-03-10
这个程序用来模拟盾构隧道的开挖,得到地面的最终沉降值太小,不知道是什么原因,请各位大侠看看出了什么问题
开挖的过程如下:
new
gen zone cyl p1 3 0 0 p2 0 36 0 p3 0 0 3 size 3 30 6
gen zone cyl p1 0 0 -3 p2 0 36 0 p3 3 0 0 size 3 30 6
group tunnel
gen zone radcyl size 4 30 6 2 p1 4 0 0 p2 0 36 0 p3 0 0 4 dim 3 3 3 ratio 1 1 1 1.2
gen zone radcyl size 4 30 6 2 p1  0 0 -4 p2 0 36 0 p3 4 0 0 dim 3 3 3 ratio 1 1 1 1.2
gen zone brick p0 0 0 4 p1 add 4 0 0 p2 add 0 36 0 p3 add 0 0 14 size 3 30 8 ratio 1 1 1.1
gen zone brick p0 0 0 -4 p1 add 0 0 -9 p2 add 0 36 0 p3 add 4 0 0 size 6 30 3 ratio 1.1 1 1
gen zone brick p0 4 0 4 p1 add 20 0 0 p2 add 0 36 0 p3 add 0 0 14 size 10 30 8 ratio 1.1 1 1.1
gen zone brick p0 4 0 -13 p1 24 0 -13 p2 4 36 -13 p3 4 0 -4 p4 24 36 -13 p8 4 36 -4 p6 24 0 -4 p7 24 36 -4  size 10 30 6 ratio 1.1 1 0.909090909091
gen zone brick p0 4 0 0 p1 add 20 0 0 p2 add 0 36 0 p3 add 0 0 4 size 10 30 3 ratio 1.1 1 1
gen zone brick p0 4 0 -4 p1 24 0 -4 p2 4 36 -4 p3 4 0 0 p4 24 36 -4 p8 4 36 0 p6 24 0 0 p7 24 36 0 size 10 30 3 ratio 1.1 1 1
group rock range  group tunnel not
mo mohr
pro bulk 8.3e6 she 3.85e6 fric 20 coh 18e3 ten 0 dil 0 range z -13 18
fix x range x -.1 .1
fix x range x 23.9 24.1
fix z range z -13.1 -12.9
fix y range y -.1 .1
fix y range y 35.9 36.1
set grav 0 0 -10
ini density 1800
ini szz -324e3 grad 0 0 18000
ini sxx -220e3 grad 0 0 12240
ini syy -220e3 grad 0 0 12240
hist unbal
hist id 2 gp zdisp 0 15 18
hist id 3 gp zdisp 2 15 18
hist id 4 gp zdisp 4 15 18
hist id 5 gp zdisp 6 15 18
hist id 6 gp zdisp 8 15 18
hist id 7 gp zdisp 10 15 18
hist id 8 gp zdisp 12 15 18
hist id 9 gp zdisp 14 15 18
hist id 10 gp zdisp 16 15 18
hist id 11 gp zdisp 18 15 18
hist id 12 gp zdisp 20 15 18
hist id 13 gp zdisp 22 15 18
hist id 14 gp zdisp 24 15 18
def sup_stress
lumda=0.9
o_press=-220000
o_grad=12240
s_press=o_press*lumda
s_grad=o_grad*lumda
end
sup_stress
plot contour zdisp
plot add sel geom scale=0.005 shrink=0.3 black black
plot set rotation 0 0 60
def excav
   y0=-1.2
   y0=y0+1.2
   cut_i=y0/1.2+1
   loop cut(cut_i,31)
     y0=1.2*(cut-1)
     y1=y0+1.2
     yp0=1.2*cut-0.01
     yp1=1.2*cut+0.01
     yc0=y0-1.21
     yc1=y0+0.01
      command
       mod null range group tunnel y y0 y1
     end_command
     command
       apply nstress s_press grad 0 0 s_grad range cyl end1 0 yp0 0 end2 0 yp1 0 rad 3.0
     end_command
      if cut>1 then
        command
         sel shell id y0 range group rock cyl end1 0 yc0 0 end2 0 yc1 0 rad 3.0
         sel node local xdir 1 0 0 ydir 0 -1 0             range x -0.1 0.1
         sel node fix lsys                                 range x -0.1 0.1
         sel node fix x yr zr                              range x -0.1 0.1
         sel node local xdir 0 0 -1 ydir 0 -1 0            range y -0.1 0.1
         sel node fix lsys                                 range y -0.1 0.1
         sel node fix y xr zr                              range y -0.1 0.1
         sel shell id y0 prop iso=(2.61e9,0.25) thick=0.3 density 2400
        end_command
     end_if
     command
       solve
     end_command
      if cut=5 then
        command
          save m1_6.sav
        end_command
     end_if
     if cut=31 then
         command
          save m1_36.sav
         end_command
     end_if
     end_loop
end
excav
ret
学习中。
离线li2005
只看该作者 1楼 发表于: 2009-03-25
没有释放应力吧
离线jxl_888
只看该作者 2楼 发表于: 2009-03-26
是啊,是不是初始应力没有进行平衡运算啊
离线zong2006
只看该作者 3楼 发表于: 2009-03-27
没有释放应力吧
离线zxszr
只看该作者 4楼 发表于: 2009-10-16
好东西啊
