@*SA$9/l %uua_) 我在这受益不小,我就来作个小贡献,把土模型来个小小总结( 只能凭记忆,可能会有错误).我用英文(敲英文更快点).
l:)S 3 ?&6Q%IUW1 1 Elastic model (advantage: simple, limitation: path-independent,reversible)
bfhz?,b J]dW1boT@ it can be divided into: linear elastic,cauthy elastic,hyperelastic and hypoelastic;
T!(sZf it can also be divided into: isotropic, anisotropic;
~?CS_B * it can also be divided into total formulation, incremental formulation
TywK\hH {d,?bs) BR3wX4i\ 2 plastic model (advantage and limitation are very diverse, more accurate than elastic model)
pD[pTMG@$ it can be divided into perfect-plasticity(more for limit analysis) and hardening plasticity
-n-Z/5~ X it (hardening type)can be divided into associate (based on Druck's postulate) or nonassociate depending on whether f=g
QhsVIta it (hardening type)can be divided into isotropic hardening, kinematic and mixed hardening
$D}"k!H }YRO'Q{ I list some famous model below:
G~(&3 Tresca, Mises,MC, DP,Lade and Duncan (1975) , Lade (1977) , cam-clay (the most famous elastic-plastic cap model), Bounding surface, hypo-plasticity, Shen zhujiang model, Yu Maohong Model, Qinghua Model (?), Hehai model? Tongji Model (?), Zheda model (?).
FJ}gUs{m 'aZASPn[ I am not sure about those (?), but I do know there is MIT model (clay and sand).
