  • 3223阅读
[图书馆]求一篇人工合成多点地震动的文章 [复制链接]
离线pigeongeo
只看楼主 倒序阅读 使用道具 楼主  发表于: 2009-04-19
关键词: 地震
急求以下这篇文章: @P'("qb~
Hao,H., Oliviera,C,S., and Penzien,J.(1989)."Multiple-station ground motion processing and simulation based on SMART-1 array date".Nuclear I:l/U-b7h
Engineering and Design.,111:293-310 C6 PlO
有哪位有这篇文章的请共享一下,谢谢!
离线johnme
只看该作者 1楼 发表于: 2009-10-05
doi:10.1016/0029-5493(89)90241-0
Good luck
离线johnme
只看该作者 2楼 发表于: 2009-10-05
Multiple-station ground motion processing and simulation based on smart-1 array data xQ]^wT.Q
This article is not included in your organization's subscription. However, you may be able to access this article under your organization's agreement with Elsevier. _u] S/X-
x%`.L6rj
H. Hao1, 1, C.S. Oliveira2, 2 and J. Penzien3, 4, 3 g[%iVZ
!vY5X2?tr,
1University of California, Berkeley, USA N E/_
us,~<e0
2Laboratório Nacional de Engenharia Civil, Av. Brasil, 1799, Lisboa, Portugal |eu:qn8
E*W|>2nx]
3University of California, Berkeley, USA JYesk
9aa cW
4Eastern International Engineers, Inc., Lafayette, California, USA aCZ7G % Y
j@guB:0
!RPPwvNk4
Received 21 March 1988.  Available online 25 February 2003. h!!7LPxt
Kqn{q4L
Abstract d%(4s~y
This paper presents a method of generating multiple-support inputs for any given set of n surface locations having space coordinates xi and yi (i = 1, 2,…, n) which are compatible with the main wave propagation properties observed in the Strong Motion Array Taiwan (SMART-1). Based on data collected in this array during two different earthquakes, a coherency function yij(dijL, dijT, ƒ) is developed for pairs of stations, i and j, as a continuous function of frequency ƒ and projected separation distances dijL and dijT in the longitudinal direction of preferential wave propagation and in the transverse direction, respectively. Using three different time windows, changes in apparent wave velocity and power spectral density are determined as functions of frequency by averaging such functions over the entire array. Finally, an average shape function for the entire time-history is obtained. This entire process was repeated for each of the three components of motion. Coherency between EW and NS components at each station was also investigated. The results presented herein are essentially valid for station separations up to 400m. An algorithm and procedures for generating spatially correlated ground motions which incorporate all of the above mentioned features are presented.
Good luck
离线lixib_2005
只看该作者 3楼 发表于: 2010-12-28
看看拉,哈哈!
每天一小步,未来一大步
离线funhhu
只看该作者 4楼 发表于: 2010-12-29
丹尼,估计这上面找这个文章是找不到的
