  • 2036阅读
[建筑地基]Rotational Restraint of Pile Caps during Lateral Loading [复制链接]
离线wangjianping
只看楼主 倒序阅读 使用道具 楼主  发表于: 2009-04-27
Abstract: A pure fixed-head ~zero-rotation! condition at the top of a group of laterally loaded piles is seldom achievable in the field, = j)5kY`
even when piles are installed in a group that is ‘‘rigidly’’ constrained by a stiff concrete pile cap. Assuming complete fixity during design "}*5'e.*
~zero rotation at the pile head! can result in underestimated values of pile-head deflection, and incorrect estimates of the magnitude and u]0{#wu;g
the location of maximum bending moments. A simple and practical approach is presented for estimating the moment restraint that is ]WFr5
provided by the pile cap at the top of a pile group. The moment restraint, represented by the rotational restraint coefficient (KMu), serves Z#uxa
as a boundary condition for analyzing groups of laterally loaded piles. Full-scale field tests performed on two pile groups with concrete ~xPU#m<
pile caps show that the proposed method for estimating rotational restraint provides results that are in good agreement with measured field HV21=W
performance.
离线wangjianping
只看该作者 1楼 发表于: 2009-04-27
离线viviansnow
只看该作者 2楼 发表于: 2009-04-28
楼主,你发的附件和前面的Determining the Resistance Distribution in Piles附件一样!
离线xjywgy
只看该作者 3楼 发表于: 2010-01-27
-资源共享是美德,请下载的朋友也发扬一下美德,自觉顶贴!
