  • 2109阅读
  • 1回复
Concrete Buildings and Progressive Collapse Resistance [复制链接]
离线wangjianping
只看楼主 倒序阅读 使用道具 楼主  发表于: 2009-04-27
Progressive collapse is defined as a situation where local
failure of a primary structural component(s) leads to the
collapse of adjoining members, which in turn leads to
additional collapse. Hence, the extent of total damage is
disproportionate to the original cause. Another way of
describing progressive collapse is a chain reaction or
propagation of failures following damage to a relatively
small portion of a structure.
附件: IS545.PDF (468 K) 下载次数:7
离线lilytyy
只看该作者 1楼 发表于: 2009-10-22
好资料,希望有更多的朋友支持
