Two topics of practical significance are discussed : (a) The widely-held perception, reflected in E8#aE\'t
most seismic codes, that soil-structure interaction (SSI) plays invariably a beneficial role ( and thus /"k [T
can be ignored in design to be on the safe side) is shown to be the result of a misconception LkzA_|8:D
stemming from the shape of current design response acceleration spectra for soft/deep soil uQdy
conditions. Properly normalising the structural period by a dominant period of motion before .4"BN<9
statistically processing recorded response spectral values, produces completely different shape and I9+h-t
size of spectral ordinates ; thus an increased period due to SSI may lead to higher response. "xTVu57Z[
(b) Analytical, experimental and field evidence in recent years has started revealing that seismic :fL7"\
pf~
design of shallow foundations could overcome the strict limitations of the so-called “capacity >}~[ew
design”, by allowing significant sliding, uplifting, and even mobilisation of bearing–capacity <2 [vR|Q*
failure mechanisms to occur. It is shown that under seismic conditions such dynamic inelastic– Hqs-q4G$
nonlinear response may merely lead to acceptable permanent horizontal and rotational Fs4shrt
deformations.
