  • 7569阅读
  • 9回复
[国外标准]ASTM D4833-2007 土工织物、土工膜及有关产品剌破强度测试方法 [复制链接]
离线mcyang
只看楼主 倒序阅读 使用道具 楼主  发表于: 2009-05-05
ASTM D 4833.pdf (119 K) 下载次数:64
离线moyuan
只看该作者 1楼 发表于: 2009-06-05
感谢推荐!
支持一下!
离线nudent
只看该作者 2楼 发表于: 2009-07-28
感谢贡献。。。。。。
离线migrant02
只看该作者 3楼 发表于: 2009-11-22
多谢楼主的赏赐
离线mcyang
只看该作者 4楼 发表于: 2009-11-23
回 3楼(migrant02) 的帖子
对你有用就好。
离线jczzz
只看该作者 5楼 发表于: 2009-12-17
离线qsdgc
只看该作者 6楼 发表于: 2009-12-20
我找地下连续墙设计规范
离线ckywsx
只看该作者 7楼 发表于: 2009-12-22
原来是英文版的美国标准,谢谢!
离线香雪海
只看该作者 8楼 发表于: 2010-06-03
Standard Test Method for
Index Puncture Resistance of Geomembranes and Related
Products1
This standard is issued under the fixed designation D 4833; the number immediately following the designation indicates the year of
original adoption or, in the case of revision, the year of last revision. A number in parentheses indicates the year of last reapproval. A
superscript epsilon (e) indicates an editorial change since the last revision or reapproval.
1. Scope
1.1 This test method is used to measure the index puncture
resistance of geomembranes and related products.
1.2 The use of Test Method D 4833 may be inappropriate
for testing some woven geotextiles or related products which
have large openings, such as geonets and geogrids.
1.3 It is recommended that geotextile and geotextile related
products be tested using Test Method D 6241.
1.4 The values stated in SI units are to be regarded as the
standard. The values provided in inch-pound units are for
information only.
1.5 This standard does not purport to address all of the
safety concerns, if any, associated with its use. It is the
responsibility of the user of this standard to establish appropriate
safety and health practices and determine the applicability
of regulatory limitations prior to use.
2. Referenced Documents
2.1 ASTM Standards: 2
D 76 Specification for Tensile Testing Machines for Textiles
D 123 Terminology Relating to Textiles
D 1776 Practice for Conditioning and Testing Textiles
D 2905 Practice for Statements on Number of Specimens
for Textiles
D 4354 Practice for Sampling of Geosynthetics for Testing
D 4439 Terminology for Geosynthetics
D 6241 Test Method for the Static Puncture Strength of
Geotextiles and Geotextile-Related Products Using a
50-mm Probe
3. Terminology
3.1 Definitions:
3.1.1 atmosphere for testing geotextiles, n— air maintained
at a relative humidity of 65 6 5 % and a temperature of 21 6
2°C (70 6 4°F).
3.1.2 geomembrane, n—very low permeability synthetic
membrane liners or barriers used with any geotechnical engineering
related material so as to control fluid migration in a
man-made project, structure, or system.
3.1.3 index test, n—a test procedure which may contain a
known bias but which may be used to establish an order for a
set of specimens with respect to the property of interest.
3.1.4 puncture resistance (F), n—the inherent resisting
mechanism of the test specimen to the failure by a penetrating
or puncturing object.
3.2 For definitions of other terms relating to geosynthetics
used in this standard, refer to Terminology D 4439.
路尽隐香处,翩然雪海间,梅花仍尤在,雪海何处寻。
离线lilytyy
只看该作者 9楼 发表于: 2010-06-25
感谢分享,下载支持
