  • 2349阅读
  • 8回复
[国外文献]Predicting the Shear Strength Envelope of Unsaturated Soils [复制链接]
离线wangjianping
只看楼主 倒序阅读 使用道具 楼主  发表于: 2009-05-13
ABSTRACT: Determining the shear strength envelope of an unsaturated
soil involves a sophisticated and time-consuming testing
program. Hence, it is advantageous to minimize the number of tests
required to establish the envelope. In this paper, a power additive
function is adopted to predict the shear strength envelope of unsaturated
soils from knowledge of the unsaturated shear strength at
residual suction, the effective stress friction angle for saturated conditions,
and the soil-water characteristic curve. Two boundary conditions
are required to quantify the two fitting parameters of the
function. The first is b  0 at residual suction, and the second is
the contribution of matric suction to the shear strength at residual
suction, which should be experimentally evaluated. The validity of
the method is tested for a number of unsaturated shear strength data
covering a wide range of suctions. Good agreement was found to
exist between the predicted envelopes and the experimental data.
The method requires only one experimental evaluation of the unsaturated
shear strength and is most suitable for coarse- to mediumgrained
soils where the residual suction may be achieved reliably in
the laboratory.
附件: GTJ2520215.pdf (124 K) 下载次数:46
离线ljg52
只看该作者 1楼 发表于: 2009-05-14
谢谢,下了看看,
离线werty5891
只看该作者 2楼 发表于: 2009-06-13
谢谢~!
离线geojg
只看该作者 3楼 发表于: 2009-08-15
谢谢,下了看看,
离线zong2006
只看该作者 4楼 发表于: 2009-09-19
谢谢,下了看看,
离线a276534238
只看该作者 5楼 发表于: 2010-01-11
谢谢啦,呵呵,,,,。。。。。
岩土,我爱岩土
离线kjj0501
只看该作者 6楼 发表于: 2010-01-11
天行健,君子以自强不息
地势坤,君子以厚德载物
离线lilytyy
只看该作者 7楼 发表于: 2010-01-18
学习英文,感谢分享
离线chn_008
只看该作者 8楼 发表于: 2010-04-05
下了就要顶啊!
酒逢知己饮,诗向会人吟!
