  • 1983阅读
Hoek和Brown之间的关系 [复制链接]
离线xyjroy
只看楼主 倒序阅读 使用道具 楼主  发表于: 2009-05-18
岩土界两位大师Hoek和Brown之间是什么关系?大家还有知道其他国内外岩土界大师们之间的关系的不?发上来大家让大家知道下啊
无时无刻都记住掌声响遍天
离线xyjroy
只看该作者 1楼 发表于: 2009-05-18
先发一篇国外的关于泊松比的综述性文章大家看下,对大家对关于泊松比的认识有所提高!
无时无刻都记住掌声响遍天
离线xyjroy
只看该作者 2楼 发表于: 2009-05-18
泊松比泊松比泊松比泊松比泊松比泊松比泊松比泊松比泊松比泊松比泊松比泊松比泊松比泊松比泊松比泊松比泊松比泊松比泊松比泊松比泊松比泊松比泊松比泊松比泊松比泊松比
描述:泊松比
附件: 综述Poisson’s ratio values for rocks.pdf (334 K) 下载次数:25
共2条评分
yuanap 土币 +20 - 2009-05-23
roc0324 土币 +5 鼓励发帖 2009-05-19
无时无刻都记住掌声响遍天
离线roc0324
只看该作者 3楼 发表于: 2009-05-19
摘要: ?&bVe__
Abstract EYj2h .k
Compared to other basic mechanical properties of rocks, Poisson’s ratio is an elastic constant of which the significance is generally Q\th8/ /
underrated. Yet, in rock mechanics, there is a considerable number of diverse areas which require a prior knowledge or estimation of the "r(pK@h
value of Poisson’s ratio. This paper examines the values and applications of Poisson’s ratio in rock mechanics. Following an historical 'm.XmVZL%
account of the initial controversy, whether it was a material constant or not, the effects of Poisson’s ratio in the elastic deformation of p!5JO4F$
materials, intact rocks, and rock masses are briefly reviewed. Also, the reported values of Poisson’s ratio for some elements, materials, 2SCf]&
and minerals are compiled while typical ranges of values are presented for some rocks and granular soils. Finally, Poisson’s ratio OKH~Y-%<
classifications are recommended for isotropic intact rocks.
离线roc0324
只看该作者 4楼 发表于: 2009-05-19
内容如上,需要的再下载
离线xyjroy
只看该作者 5楼 发表于: 2009-05-19
回 4楼(roc0324) 的帖子
我觉得该篇综述性文章还是很有意思……
无时无刻都记住掌声响遍天
离线lange506
只看该作者 6楼 发表于: 2011-02-24
下来看看呵呵呵
