  • 1682阅读
[国外文献]A Semi-Active Variable Stiffness and Damping System [复制链接]
离线wangjianping
只看楼主 倒序阅读 使用道具 楼主  发表于: 2009-06-09
This paper proposes a new semi-active variable stiffness and damping system (AVSD) for
vibration control of civil engineering structures. The AVSD system can alter rigidity and damping
of the controlled structure at each control interval to attenuate the structural responses. The
composition of two hydraulic cylinder-piston systems of the AVSD system is capable of
amplifying the interstory drift and velocity and make dampers dissipate more energy. In this study,
the control law of the AVSD system is established based on an instantaneous perform index. To
optimally utilizing the poposed control devices and economically improve the control performance,
a genetic algorithms is used to design the device location. Numerical results indicate the AVSD
system is a quite economical, reliable and effective semi-active control system
附件: tan_p_eertc.pdf (256 K) 下载次数:13
离线werty5891
只看该作者 1楼 发表于: 2009-06-12
谢谢楼主分享~!
离线hanwu
只看该作者 2楼 发表于: 2009-06-13
好东西!顶!
离线panqiang
只看该作者 3楼 发表于: 2009-08-01
顶啊
