  • 3020阅读
[书籍]Computational Differential Geometry Approach to Grid Generation [复制链接]
离线hetang
只看楼主 倒序阅读 使用道具 楼主  发表于: 2009-09-07
Springer - Computational Differential Geometry Approach to Grid Generation - 2nd Edition - 2007 w *oeK
'7+4`E
V.D. Liseikin Zy o[(`y
A Computational bsB*533
Differential c17_2 @N
Geometry Approach 9\/xOwR
to Grid Generation _tBTE%sO
Second Edition f7=((5N
With 81 Figures S<4c r
Including 3 Color Figures NMa} <
pgOQIzu
Preface to the Second Edition Olh<,p+x
This second edition of A Computational Differential Geometry Approach to AQ_|:
Grid Generation is significantly expanded by new material that centers on /4g1zrU
the recent advances in grid generation technology based on the numerical solution 73xAG1D$r
of Beltrami and diffusion equations in monitor metrics. It gives a more "br,/Dk>MX
detailed and practice-oriented description of the monitor metrics for providing }HY-uQ%@g
the generation of adaptive, field-aligned, and balanced numerical grids. pL{U `5S
New finite-difference codes are described for generating both structured and w+yC)Rmz
unstructured surface and domain grids. Numerous applications of the codes JKGc3j,+#
for the generation of numerical grids with individual and balanced properties BsEF'h'Owh
in surfaces and domains, in particular, in the tokamak-edge region are Wzw7tLY._
demonstrated. The new edition also boasts examples of the implementations hS)'a^FV
of the grid generation codes in the codes for the numerical investigations of jg.QRny^
gas-dynamics and magnetized plasmas problems. +xrr? g
Grid technology, which has had a significant impact on the efficiency of '=Rs/EDME
numerical codes, remains a rapidly advancing field of computational physics :P<]+\m
and applied mathematics. New achievements are being added by the creation z"0I>gl
of more sophisticated techniques, modification of the available methods, and KU8J bl*
implementation of more subtle tools as well as the results of the theories of Z/t+8;TMR,
differential equations, calculus of variations, and Riemannian geometry in the cUvz2TK
formulation of grid models and analysis of grid properties.  #`o2Z
The development of comprehensive differential and variational grid generation `-3O w[
techniques reviewed in the monographs of J.F. Thompson, Z.U.A.Warsi, qNYN-f~@,
and C.W. Mastin, P. Knupp, and S. Steinberg, and V.D. Liseikin has been hnDBFQ{
largely based on a popular concept in accordance with which a grid model =>M^02"
realizing the required grid properties should be formulated through a linear [/Rf\T(,jn
combination of basic and control grid operators with weights. A typical, r7b1-
basic grid operator is the operator responsible for the well-posedness of the #wV8X`g
grid model and construction of unfolding grids, e.g., the Laplace equations 5*1D$mxD"
(generalized Laplace equations referred also to as second-order Beltrami equations) a'2$nbp}
or the function of grid smoothness, which produces fixed non-folding fZ*+2T>
grids while grid clustering is controlled by source terms in differential grid @}@Z8$G^
formulations or by an adaptation function in variational models. However, vJ'2@f$
such a formulation does not obey the fundamental invariance laws with respect O*0l+mop
to parameterizations of physical geometries and frequently results in cUY`97bn
VI Preface to the Second Edition YhDtUt}?
cumbersome governing grid equations. Besides this, the choice of the weight <Dwar>}
and control functions for providing well-posedness, grid non-degeneracy, and 6"~P/\jP
adaptation is largely based on unreliable theoretical assumptions borrowed ^R# E:3e
from one-dimensional models. 8P1=[i]
The current book revises this popular concept and pursues a more updated K2J \awX
and somewhat revolutionary one based on the general fact that an B]uc<`f
arbitrary one-to-one, smooth multidimensional coordinate transformation deriving zxC#0@qX07
a numerical grid in a domain or on a surface is realized by a solution of CE/Xfh'44
a system of the Beltrami equations in a suitable monitor metric specified in K#pNe c
the physical geometry. The system can be interpreted as the multidimensional mT.u0KUIy
equidistribution principle in which the monitor metric tensor is an extension \=6l9Lrj>h
of a scalar-valued weight function. With this interpretation for a mathematical 9D7+[`r(-
model for generating grids in domains or on surfaces, one need only choose . koYHq
the Beltrami equations, without any complementary control operators that 1(|'WyD
worsen the model, while the required grid properties are realized through the \'|> p/5I
specification of suitable metric tensors. 1`a5C.v
Thus the single Beltrami mathematical model provides a real foundation 8xccp4
for the solution of the challenging problem of the development of comprehensive C!fMW+C@
grid generators. Consequently the efforts of research should be directed 3?1`D/
towards implementing this model into grid technology by developing ie2WL\tR4
approaches for formulating metrics in physical geometries and establishing 22.8PO0
necessary relations between them and the required grid properties for the _i20|v
purpose of setting up an adequate control of the grid quality by the choice Bs O+NP
of the suitable metric. D^=J|7e
One natural approach for formulating metric tensors and corresponding paKSr|O
tensor-valued weight functions is based on the notion of a monitor surface Pmh8sw
over the physical geometry that undergoes a gridding process. The monitor k} |
surface is defined as the graph of some (in general vector-valued) function }Q=!Y>Tc
that takes into account the behavior of the physical solution. This monitor #MRMNL@
surface, having an inherent metric tensor that can be considered as the very dvt9u9Vg=
tensor-valued weight function, is suitable for generating adaptive grids with {&\jW!&n
the use of a smoothness functional (which is the functional of energy) whose T`5bZu^c
Euler–Lagrange equations are, in fact, equivalent to the Beltrami equations =5kY6%E7c
in the metric of the monitor surface. The resulting grid derived by this metric kzt(i Y_6
tends to cluster its nodes in the zones of the large gradient of the function. The X{\F;Cb*
approach for formulating the adaptive metric is readily extended to define 8C67{^`::
more general monitor metrics in domains or on surfaces, thus turning them #6+@M
into Riemannian manifolds whose implementation in grid technology allows 9Hf9VC3
one to generate grids satisfying the most broad mesh quality requirements. b/C`J p
In order to control the required grid properties by the monitor metrics, 5 N#3a0)
one needs a knowledge of geometric characteristics of the monitor geometries {= F /C,-
and their relations to the resulting grid behavior. This knowledge can be attained cVv;Jn
with the aid of the theory of multidimensional differential geometry of @Ub"5Fl4
Riemannian manifolds adjusted to the features of grid technology. The theory YgUvOyaQXf
Preface to the Second Edition VII (=* cK-3
of multidimensional differential geometry is really one of the most promising %?p1d!
branches of the pure mathematical field of science, capable of pushing grid R,pX:H&#+
technology to a more advanced level in its development. Indeed, many notions ~v6OsH%vx
and characteristics of common surfaces, such as metric tensors, their invariants, H;YP8MoQ
first and second fundamental forms, curvatures and torsions of lines, the =Ur}~w&H8
mean and Gauss curvatures, and Christoffel symbols, have already been used i*#-I3
by many authors as natural elements in defining grid quality measures and aB7+Tb
formulating appropriate variational and differential grid techniques in a unified Yy)tmq
manner regardless of the geometry of the physical domains and surfaces. EUN81F?
A theory of more general geometric objects, such as regular multidimensional `/EGyN6X
surfaces and Riemannian manifolds implemented for generating grids $shoasSuI
with necessary properties, is expected to become a highly beneficial tool for [3{W^WSOz
boosting grid technology. The known relations and techniques of differential ]Bjyi[#bg
geometry also present an efficient means for transforming and modernizing P] UJ0b
the physical and grid equations into a suitable form. It is presumable that a{ ?`t|
the science of differential geometry will play in numerical grid technology "4uS3h2r
the same role played by the science of matrices in the theory of difference {TX]\ufG
approximations of boundary value problems. wid;8%m
Therefore, there is a need for a monograph that is essentially aimed at 0@H|n^Md#
providing deep and balanced insight into the fields of grid science, multidimensional %F-ZN^R
geometry adjusted to grid technology, and up-to-date achievements &NH$nY.r
of the applications of geometric tools to the creation of advanced grid techniques. K95p>E`9e
With this background the reader will be able to formulate and develop m]5Cq6
well-posed grid models and algorithms and analyze grid properties with geometry ">y%iE
related tools, thus taking part in the solution of the very challenging J"=vE=
problem of the development of advanced comprehensive grid generators. 2vAQ
This monograph gives an account of the geometrization of popular comprehensive ^yyC [Mz
grid methods and presents an important extension to the methods =o&>fw
related to the application of the technique of Riemannian manifolds to the  Kfh|
formulation of grid equations by developing some procedures for the construction K':K{ee>
of monitor metric tensors. Contrary to classical geometric studies, :'~ Y
which center on geometric features and characteristics of specified Riemannian YKO){f5
manifolds, the problem of finding appropriate monitor metrics for producing f;1K5Y
grid systems with the required properties is somewhat an inverse *=+td)S/1
problem of the creation of Riemannian manifolds with desirable geometric @I_8T$N=
characteristics. In accordance with the concept of the inverse problem, the *#tJM.Z
author of the monograph discusses rather thoroughly some new techniques w*oQ["SL
aimed at the construction of special monitor metrics in physical geometries. ;|vpwB@B
The techniques are designed by generalizing the projection approach in which 9983aFam
the monitor metric in an n-dimensional physical geometry is borrowed from !f&Kf,#b`
a natural metric of the n-dimensional surface derived by a height monitor ?e,pN,4
function over the geometry. This technology allows the required metric to :=wT vz
be defined through the original metric of the physical geometry and certain Il= W,/y
vector-valued functions. }j*KcB_
VIII Preface to the Second Edition 7z!tKs"TMT
The book establishes and reviews some of the relations of the Riemannian r=X}%~_8X
geometry for the purpose of obtaining new equations with implemented metric wnM9('\
characteristics aimed at facilitating the control of the generation of grids qoj$]
with the required properties. Taking advantage of the relations established, A-T]9f9
the author has converted the equations into a compact form convenient for rL+!tH
numerical treatment via the available algorithms. 2JJ"O|Ibz
The technique of multidimensional differential geometry is also applied ]3KhgK%c8
to study the qualitative effect of a general class of monitor metrics on the Z|5?7v;h5
resulting mesh. For this purpose a new characteristic of grid clustering is >rJnayLF
formulated. Certain relations between this measurement and some geometric }M3fmAP}
characteristics of grid hypersurfaces and the monitor functions forming the S$Q8>u6Wk
monitor metrics are established. The well-known results for grids generated Z;:u'=
by inverted Laplace equations about node-clustering near concave boundary v?& -xH-S
segments of domains and node-rarefaction near convex boundary segments w8Sp <6*
are, using these relations, extended to arbitrary boundary segments and to eC[$B99\
more general Beltrami equations in monitor metrics. On the basis of the = c>Qx"Sw
established formulas, the monitor functions are readily estimated in the inverted kH]yl 2
diffusion and Beltrami grid equations to provide grid clustering or, if it *:L?#Bw
is reasonable, grid rarefaction near arbitrary segments of physical geometries. fO0XA"=
Some relations of the mean curvature of the monitor surfaces to the Beltrami 9Hc$G{[a
equations for grid generation are exhibited. The book also includes $!8-? ?ML
a chapter devoted to the implementation of the comprehensive grid equations dt`{!lts'
and the energy functional into numerical codes and to the application P DrZY.-
of the codes to the numerical solution of some gas-dynamics and plasmarelated V&Xe!S
problems. [&&1j@LQ*
Since grid technology has widespread applications to nearly all field problems, -3;*K4z$/
this monograph will be useful for a broad range of readers, including m0cP(
teachers, students, and researchers as well as practitioners in applied mathematics, ReM=eS
mechanics, biology, medicine, and physics interested in the numerical :k.NbN$i\
analysis of multidimensional field problems with complicated geometries and S5G6Rj@W
complex solutions. ML( E o
The book is divided into two parts. Part I of the book gives a geometric #m{UrTC
background needed for the development of grid generators. The grid equations, ~~SwCXZ+b^
codes, and applications are described in Part II. |aT| l^2R@
Part I of the monograph includes Chaps. 1–4. Chapter 1 gives a general introduction >i5acuth
to the subject of numerical grids and methods of their generation. t4-pM1]1_
Chapters 2–4 introduce the reader to multidimensional differential geometry ]8 f ms(
for the purpose of better understanding those of its techniques that are suitable f"u%J/e&
for the implementation into advanced grid generation technologies. The +(C6#R<LI
geometric implementation in grid technology pursued in the book assumes the @> E2?CV
development of robust techniques for producing appropriate monitor metrics B, TB3 {
over both physical domains and surfaces thus converting them into Riemannian 2ioQb`=
manifolds. The metrics should guarantee generation of grids with the 6y6<JR-V2k
necessary properties through popular mathematical models. 8;Yx<woR
Preface to the Second Edition IX 2Fq<*pxAY
Part II of the book is devoted to the implementation of geometric tools fp[|M
into the development of grid techniques and codes. It contains Chaps. 5–7. BPdfYu ,il
Chapter 5 deals with fundamental elliptic grid models formulated through 'J6 M*vO
the operators of Beltrami and diffusion and establishes compact formulas of kX>f^U{j
monitor metrics. Two-dimensional Beltrami equations in the natural metric of {a4z2"\A
a physical surface were originally proposed byWarsi for generating fixed grids Y0_),OaY
on the surface. The ordinary Laplace equations that are the Beltrami equations )0Me?BRp
in the Euclidean metric were applied to generate fixed grids in domains Z(Bp 0a
by Crowley and Winslow. One justification of the Beltramian operator is =y/8 ^^
demonstrated in Chap. 5 by the proof of the statement that an arbitrary nondegenerate ~[\_N\rm
smooth transformation of a physical domain or surface is realized i1>- QDYnJ
as a solution of the Dirichlet boundary value problem for the system of Beltrami XI22+@d6
grid equations in some appropriate metric. The chapter also discusses a^=-Mp
some variational and harmonic interpretations of the Beltrami equations, in ]K/DY Do-
particular, a variational approach for generating harmonic maps through the 3WUTI(
minimization of energy functionals, which was suggested by Dvinsky. ? P( ZA
With the help of the geometric relations, established in Chap. 4, the grid ($}`R xj1@
equations introduced in Chap. 5 are transformed in Chap. 6 to equations in BI $
invariant forms with respect to independent logical variables. Special monitor uoXAQ6k
metrics over two-dimensional surfaces are designed that result in simpler m3mp/g.>
transformed equations, even in comparison with the equations that have L7V G`h;
been used for generating fixed grids. The chapter also establishes relations >|twyb
between the monitor functions and geometric characteristics of the Riemannian \>7^f 3m
manifolds produced and the coordinate lines and surfaces generated by " QWq_R
a corresponding mathematical model, for the purpose of realization of grid {|1Y:&M?
control through a suitable specification of the monitor functions. r9 !Tug*>m
Chapter 7 gives a description of some computational codes for generating 2UFv9
grids with the numerical solution in the logical domain of the elliptic c2e tc8
equations obtained in Chap. 6 by changing mutually dependent and independent |b|&XB_<]Z
variables in the original Beltrami and diffusion equations. Some [L:o`j
numerical aspects related to the development of grid generation codes are ) *,5"CO
reviewed, in particular, the application of layer-type functions to formulating 1$%V{4bJ
monitor metrics and description of two techniques for generating smooth k[HAkB \{
block-structured grids. Numerical results related to the application of the ^sVX)%
grid technology advocated in the book to some gas-dynamics and plasma >]W)'lnO
problems are also exhibited in this chapter. %oq[,h <X
The book ends with a list of references. p TeOW9
Acknowledgement 1. rj'
The author is very grateful for helpful suggestions in geometry, algebra, and "87ghj_}
numerical techniques made by his colleagues, Professors Borisov, Churkin, L (khAmm
Glasser, Kuzminov, Sharafutdinov, and Shvedov. ~fT_8z
The author is also much obliged to the researchers who responded to his l PK +$f$
requests and sent files of their papers and of pictures for figures, namely pb$~b\s]=
X Preface to the Second Edition 4Qo]n re!
B.S. Azarenok (Figs. 7.10–7.14), A.A. Charakhch’yan (Figs. 7.8–7.9), and Z| V`B `
A.H. Glasser (Figs. 5.11–5.12). Figures 7.10–7.14 were published in Azarenok R +WP0&d'
(2000, 2002), 7.8 in Charakhch’yan and Ivanenko (1997), 7.9 in Lomonosov, EpFQ|.mQ
Frolova and Charakhch’yan (1997), and 5.10–5.11 in Glasser et al. (2005). uwjGDw
The work over the book was partly supported by the US Civilian Research WC|.g,9#
& Development Foundation (CRDF): Award NO RU-M1-2579-NO-04. `kU/NKq
In particular, the efforts related to the development of grid generation codes, *{y K 8
computing figures of grids, and preparing the text of the book in Latex code, \U[ {z&]~
made by I. Kitaeva, Yu. Likhanova, and D. Patrakhin, whom the author {6~l$
thanks very much, were remunerated by payments from the CRDF grant. 4*'pl.rb>
Figures 5.6, 7.29 and 7.37 were published in Glasser, Liseikin and Kitaeva []A%<EI7
(2005), 5.4, 5.8, 7.32 and 7.34 in Glasser et al. (2005). IaT$ 6\>
Novosibirsk, March 2006 Vladimir D. Liseikin
荷塘月色
离线sjzdh01
只看该作者 1楼 发表于: 2009-09-08
下载先学习学习了
离线ymcheng
只看该作者 2楼 发表于: 2009-09-08
thanks a lot
离线dzg1578
只看该作者 3楼 发表于: 2009-09-08
thanks!
离线frank1975
只看该作者 4楼 发表于: 2009-09-08
离线wwhite
只看该作者 5楼 发表于: 2009-09-13
OIRTSH[PDTUK[I8K\-IO\R6809\=0P\=8P=8P-9-=0\=Y78976R9Y8II
离线wwhite
只看该作者 6楼 发表于: 2009-09-13
PORSTY=UO6R7IO-\PI\=PI\-YU==O-=\Y\=RTY=0U0=YT0OU-0RIY0I-YRY6URYU
离线hnzzncwu
只看该作者 7楼 发表于: 2013-05-25
数学方法是基础。
