  • 9426阅读
spginer里面提交论文不成功的提示,这是为什么啊! [复制链接]
离线luohui5151
只看楼主 倒序阅读 使用道具 楼主  发表于: 2009-09-20
提交论文不成功的提示,这是为什么啊!
PLEASE NOTE: Your submission has not yet been sent to the editorial office.
Your submission is being created. Editorial Manager is taking the files you submitted and creating a PDF.
Please go to the Submissions Waiting for Author's Approval page, where a link to the PDF will appear after it has been built. You must view the PDF and approve your submission. Please read the instructions below.
On the Submissions Waiting for Author's Approval page, you can View your PDF, Edit the Submission, Approve the Submission, or Remove the Submission. Once you have Approved the Submission, the PDF will be sent to the editorial office.
If you have designated a different Corresponding Author on the Add/Edit/Remove Author step, then this paper will not be available on your Submissions Waiting for Author's Approval page. The new Corresponding Author will have access to the PDF and must login to the system to approve the PDF before the submission can be sent to the editorial office.
Please do not click the Back button
Back to Main Menu
You have no Submissions awaiting approval. Please click the 'Author Main Menu' button to return to the Main Menu.
离线lmm
只看该作者 1楼 发表于: 2009-09-20
你多等一会
系统正在把你的文章转化为pdf格式文件
这个过程比较长
耐心等
然后回到操作页面
看呈现approve了点击既可
离线luohui5151
只看该作者 2楼 发表于: 2009-09-20
我大概等了1分钟,后点了这个链接:
结果得过一个这样的提示,
然后我再点击Author Main Menu这个按钮,结果又回答了以前的开始投稿的界面状态了,我不知道我的稿件到底保存了吗?
请大家帮忙解答啊!!!
离线lmm
只看该作者 3楼 发表于: 2009-09-20
一分钟肯定不够
你不用管
他转化好了会自动跳转页面的
和网速与电脑有关
估计等10分钟左右吧
离线luohui5151
只看该作者 4楼 发表于: 2009-09-23
回 3楼(lmm) 的帖子
今天收到这个通知了,不知道是什么意思啊
Please complete the review within 30 days of receipt of this mail. You may submit your comments online at the above URL.  There you will find spaces for confidential comments to the editor, comments for the author and a report form to be completed. Your prompt assistance will be most appreciated to expedite our review process. The author(s) will be notified of your recommendations; however, the identity of the reviewer will be kept anonymous.
离线lmm
只看该作者 5楼 发表于: 2009-09-23
这是给审稿人的
你是不是搞错了
你投稿是要进入author那个板块
