  • 3646阅读
  • 1回复
[热点探讨]请问Springer 里面提交论文生产PDF格式文档最后一步为什么始终不能成功了,出现这样的提示是为什么啊? [复制链接]
离线luohui5151
只看楼主 倒序阅读 使用道具 楼主  发表于: 2009-09-20
PLEASE NOTE: Your submission has not yet been sent to the editorial office.
Your submission is being created. Editorial Manager is taking the files you submitted and creating a PDF.
Please go to the Submissions Waiting for Author's Approval page, where a link to the PDF will appear after it has been built. You must view the PDF and approve your submission. Please read the instructions below.
On the Submissions Waiting for Author's Approval page, you can View your PDF, Edit the Submission, Approve the Submission, or Remove the Submission. Once you have Approved the Submission, the PDF will be sent to the editorial office.
If you have designated a different Corresponding Author on the Add/Edit/Remove Author step, then this paper will not be available on your Submissions Waiting for Author's Approval page. The new Corresponding Author will have access to the PDF and must login to the system to approve the PDF before the submission can be sent to the editorial office.
Please do not click the Back button
Back to Main Menu
You have no Submissions awaiting approval. Please click the 'Author Main Menu' button to return to the Main Menu.
离线swallow
只看该作者 1楼 发表于: 2009-09-23
Re:请问Springer 里面提交论文生产PDF格式文档最后一步为什么始终不能成功了,出现这样的提示是为什么啊 ..
好像是要去这个页面 the Submissions Waiting for Author's Approval ,打开PDF,点同意提交就OK了。
