  • 3826阅读
  • 10回复
Canadian Geotechnical Journal审稿后要求修改 [复制链接]
离线qbzhang666
只看楼主 倒序阅读 使用道具 楼主  发表于: 2009-09-25
应该可以接受吧,看审稿人的意见都挺好,只是稍微增加或减少些文字和图表,不管了,先自己庆祝,哈哈
Dear ###
The manuscript contains novel material of significant value, and the two expert reviewers and AE both recommend publication after changes have been made.
The paper, though very long, is well organized and presented. There are many editorial changes to be made in the manuscript. The authors should avoid unnecessary use of colours in the drawings, e.g. dimension lines, captions, etc. Black prints much better.
Click on Author in your work area. Select Revised Manuscript and follow the steps.
Please return
(1) a cover letter that describes the steps you have taken to satisfy the current review comments or your rebuttal of those with which you disagree. [NOTE: This should be in a 2-column table format with the comments made by the reviewers in one column and the respective reply in the second column.]
(2) a separate marked manuscript showing changes made (track changes). Attach this as "supplementary data"
The file on the manuscript will remain open for three months, at which time it will be automatically withdrawn unless we are advised that you will require additional time.
共1条评分
roc0324 土币 +5 鼓励支持 2009-09-28
离线acamus
只看该作者 1楼 发表于: 2009-09-25
养生之道,支持一下!!
离线qbzhang666
只看该作者 2楼 发表于: 2009-09-25
引用第1楼acamus于2009-09-25 17:21发表的  :
养生之道,支持一下!!
thx
离线lmm
只看该作者 3楼 发表于: 2009-09-26
修改后可以录用了
我的以前也是这样的
祝贺祝贺
共鲜花(qbzhang666) 呵呵,多谢你的帮忙条评分
离线luckprince
只看该作者 4楼 发表于: 2009-09-26
恭喜楼主!向你和LMM们学习!
离线lovekk
只看该作者 5楼 发表于: 2009-10-23
同贺啊!!!
共鲜花(qbzhang666) 呵呵 同贺条评分
临峰山庄
http://www.slope.com.cn
边坡岩土土木工程专业网站
离线igsyu
只看该作者 6楼 发表于: 2009-11-11
牛人啊,现在国内岩土届牛人辈出,
离线smilefeng
只看该作者 7楼 发表于: 2010-11-17
楼主很牛啊
离线hugeluke
只看该作者 8楼 发表于: 2010-11-20
国外的期刊怎么发呢?通过什么渠道联系?
离线潘华1983
只看该作者 9楼 发表于: 2010-11-23
楼主强啊,好羡慕啊
天空没有留下我的痕迹,但我已飞过!
离线lilongqi1986
只看该作者 10楼 发表于: 2010-11-25
见贤思齐啊
