  • 2614阅读
zsoil核心技术--------zsoil非饱和介质流固耦合分析稳定性保证 [复制链接]
离线geofem
只看楼主 倒序阅读 使用道具 楼主  发表于: 2009-09-27
Stabilized Mixed Finite Element Formulations for Materially Nonlinear Partially Saturated Media (2006)
Truty, A., Zimmermann, Th.
Abstract
Standard and enhanced (BBAR or EAS) low order finite elements applied to the problem of consolidation of two-phase nonlinear continua do not satisfy the LBB condition when the same interpolation functions are used for both displacement and pore pressure fields. Strong spatial pressure oscillations are the main consequence of the LBB condition violation. The class of direct stabilized methods, widely used in the field of fluid mechanics, is a powerful tool to circumvent violation of the aforementioned condition. Three stabilized formulations, designed for the problem of consolidation of fully or partially saturated media are presented: Galerkin/least-squares (GLS) with the least-squares term construction based on the residuum of the local fluid mass conservation equation; the pressure stabilized formulation (FPL) in which the rate of the pore pressure Laplacian (residual free in the incompressibility limit) is added to the fluid mass conservation equation; and, finally, a stabilized formulation in which the stabilization term is constructed based on the rate of the residuum of the local momentum equation. An h-convergence study and test problems for the three stabilized schemes are discussed.
大家在享用成果之余,可以找出来看看。
ZSOIL2D/3D QQ群:68722113
岩土工程数值分析开发平台,共享、开放、合作、提高。
离线roc0324
只看该作者 1楼 发表于: 2009-09-28
???????where?
离线geofem
只看该作者 2楼 发表于: 2009-09-29
只有摘要,全文可以到图书馆下载。
离线spmhpu
只看该作者 3楼 发表于: 2009-11-04
                   哪里能下载呀
12123
离线spmhpu
只看该作者 4楼 发表于: 2009-11-04
不会用呀
12123
离线土大师
只看该作者 5楼 发表于: 2009-12-29
从事土工试验、安全鉴定、数值分析、设计、监理和质量检测。QQ:416566120
