new Q6fPqEX=
;gen zon radcyl p0 19.5 0.4 12.49 p1 19.5 0 12.49 p2 25.5 0.4 12.49 p3 19.5 0.4 12.89 size 1 12 2 1 fill
u{|^5%)
;gen zon reflect dip 90 dd 0 orig 19.5 0.4 12.49
QVWUm!
;gen zon reflect dip 0 dd 0 ori 19.5 0.4 12.49 d&%}u1 .
gen zon brick p0 19.5 0 12.09 p1 25.5 0 12.09 p2 19.5 1.6 12.09 p3 19.5 0 12.89 size 12 1 1 G_6!w//
gen zon brick p0 25.5 0 12.09 p1 30 0 12.09 p2 25.5 1.6 12.09 p3 25.5 0 12.89 size 9 1 1 42wZy|oqp
gen zon brick p0 15 0 12.09 p1 19.5 0 12.09 p2 15 1.6 12.09 p3 15 0 12.89 size 9 1 1 i{k v$ir!
gen zon brick p0 0 0 12.09 p1 15 0 12.09 p2 0 1.6 12.09 p3 0 0 12.89 size 15 1 1 ;>jOB>b{h
gen zon reflect dip 90 dd 0 orig 0 1.6 12.09 .$ 5*v
gen zon reflect dip 90 dd 0 orig 0 3.2 12.09 ~{[,0,lWU
gen zon reflect dip 90 dd 0 orig 0 6.4 12.09 saR9_
ux
gen zon reflect dip 90 dd 0 orig 0 12.8 12.09 tflUy\H>
gen zon reflect dip 90 dd 0 orig 0 25.6 12.09 g715+5z[
els71t -
gen zone brick p0 0 0 10.89 p1 15 0 10.89 p2 0 51.2 10.89 p3 0 0 12.09 size 15 32 1 p.!p6ve){
gen zone brick p0 0 0 12.89 p1 15 0 12.89 p2 0 51.2 12.89 p3 0 0 14.09 size 15 32 1 \w2X.2b.F
gen zone brick p0 0 0 14.09 p1 15 0 14.09 p2 0 51.2 14.09 p3 0 0 18.33 size 15 32 2 ilFS9A3P
gen zone brick p0 0 0 18.33 p1 15 0 18.33 p2 0 51.2 18.33 p3 0 0 25.8 size 15 32 3 rqhRrG{L|&
gen zone brick p0 0 0 25.8 p1 15 0 25.8 p2 0 51.2 25.8 p3 0 0 31 size 15 32 2 2yA+zJ
46B
gen zone brick p0 0 0 6.66 p1 15 0 6.66 p2 0 51.2 6.66 p3 0 0 10.89 size 15 32 2 ;ZR^9%+y9
gen zone brick p0 0 0 0 p1 15 0 0 p2 0 51.2 0 p3 0 0 6.66 size 15 32 3 0]l9x}
ybpU?n
gen zone brick p0 15 0 10.89 p1 30 0 10.89 p2 15 51.2 10.89 p3 15 0 12.09 size 30 32 1 Z^GXKOeq
gen zone brick p0 15 0 12.89 p1 30 0 12.89 p2 15 51.2 12.89 p3 15 0 14.09 size 30 32 1 Lq{/r+tt/
gen zone brick p0 15 0 14.09 p1 30 0 14.09 p2 15 51.2 14.09 p3 15 0 18.33 size 30 32 2 _"- ,ia[D
gen zone brick p0 15 0 18.33 p1 30 0 18.33 p2 15 51.2 18.33 p3 15 0 25.8 size 30 32 3 _sIr'sR~
gen zone brick p0 15 0 25.8 p1 30 0 25.8 p2 15 51.2 25.8 p3 15 0 31 size 30 32 2 wyv%c/WlS
gen zone brick p0 15 0 6.66 p1 30 0 6.66 p2 15 51.2 6.66 p3 15 0 10.89 size 30 32 2 e)]DFP[n
gen zone brick p0 15 0 0 p1 30 0 0 p2 15 51.2 0 p3 15 0 6.66 size 30 32 3 ?^{Ey[)'(
_kQOax{c/
;右边 [P%'p-Hg_
gen zone brick p0 30 0 0 p1 70 0 0 p2 30 51.2 0 p3 30 0 6.66 size 20 32 3 Z/b,aZhB
gen zone brick p0 30 0 6.66 p1 70 0 6.66 p2 30 51.2 6.66 p3 30 0 10.89 size 20 32 2 2G}@s.iE
gen zone brick p0 30 0 10.89 p1 70 0 10.89 p2 30 51.2 10.89 p3 30 0 12.09 size 20 32 1 @jD#Tn-*
gen zone brick p0 30 0 12.09 p1 70 0 12.09 p2 30 51.2 12.09 p3 30 0 12.89 size 20 32 1 x!A5j
$k0
gen zone brick p0 30 0 12.89 p1 70 0 12.89 p2 30 51.2 12.89 p3 30 0 14.09 size 20 32 1 E# *`u
gen zone brick p0 30 0 14.09 p1 70 0 14.09 p2 30 51.2 14.09 p3 30 0 18.33 size 20 32 2 $"`e^J9!!
gen zone brick p0 30 0 18.33 p1 70 0 18.33 p2 30 51.2 18.33 p3 30 0 25.8 size 20 32 3 TV(%e4U=
gen zone brick p0 30 0 25.8 p1 70 0 25.8 p2 30 51.2 25.8 p3 30 0 31 size 20 32 2 !9EbG
;左边 PpR
eqmo
gen zone brick p0 -20 0 0 p1 0 0 0 p2 -20 51.2 0 p3 -20 0 6.66 size 10 32 3 +!"7=?}
gen zone brick p0 -20 0 6.66 p1 0 0 6.66 p2 -20 51.2 6.66 p3 -20 0 10.89 size 10 32 2 TXfG@4~kC
gen zone brick p0 -20 0 10.89 p1 0 0 10.89 p2 -20 51.2 10.89 p3 -20 0 12.09 size 10 32 1 n2&M?MGX
gen zone brick p0 -20 0 12.09 p1 0 0 12.09 p2 -20 51.2 12.09 p3 -20 0 12.89 size 10 32 1 WmZ,c_
gen zone brick p0 -20 0 12.89 p1 0 0 12.89 p2 -20 51.2 12.89 p3 -20 0 14.09 size 10 32 1 ]VK9d;0D
gen zone brick p0 -20 0 14.09 p1 0 0 14.09 p2 -20 51.2 14.09 p3 -20 0 18.33 size 10 32 2 o^<W3Z
gen zone brick p0 -20 0 18.33 p1 0 0 18.33 p2 -20 51.2 18.33 p3 -20 0 25.8 size 10 32 3 )|<g\>/
gen zone brick p0 -20 0 25.8 p1 0 0 25.8 p2 -20 51.2 25.8 p3 -20 0 31 size 10 32 2 =<z~OE'lV
gen zone brick p0 -20 0 31 p1 70 0 31 p2 -20 51.2 31 p3 -20 0 61 size 45 32 10 PF:E{_~
SW=%>XKkh
attach face yb'v*B]
save modelbb.sav A]m_&A#
;定义卸压孔 v#$}3+KVC
;group main1 range cyl end1 19.5 0.4 12.49 end2 25.8 0.4 12.49 rad 0.08 )Tad]Hd"W
;group main1 range cyl end1 19.5 1.2 12.49 end2 25.8 1.2 12.49 rad 0.08 c/`Rv{*'o
;group main1 range cyl end1 19.5 2.0 12.49 end2 25.8 2.0 12.49 rad 0.08 :c0 |w
;group main1 range cyl end1 19.5 2.8 12.49 end2 25.8 2.8 12.49 rad 0.08 QjyJmW("Z
;group main1 range cyl end1 19.5 3.6 12.49 end2 25.8 3.6 12.49 rad 0.08 jN2Xoh9
;group main1 range cyl end1 19.5 4.4 12.49 end2 25.8 4.4 12.49 rad 0.08 bk4G+wGw
;group main1 range cyl end1 19.5 5.2 12.49 end2 25.8 5.2 12.49 rad 0.08 P:c'W?
;group main1 range cyl end1 19.5 6.0 12.49 end2 25.8 6.0 12.49 rad 0.08 /{nZI_v#
;group main1 range cyl end1 19.5 6.8 12.49 end2 25.8 6.8 12.49 rad 0.08 *ZF:LOnU
;group main1 range cyl end1 19.5 7.6 12.49 end2 25.8 7.6 12.49 rad 0.08 k 1;Jkq~
;group main1 range cyl end1 19.5 8.4 12.49 end2 25.8 8.4 12.49 rad 0.08 Ct}rj-L<i
;group main1 range cyl end1 19.5 9.2 12.49 end2 25.8 9.2 12.49 rad 0.08 8YkCTJfBGu
;group main1 range cyl end1 19.5 10.0 12.49 end2 25.8 10.0 12.49 rad 0.08 #5_pE1
;group main1 range cyl end1 19.5 10.8 12.49 end2 25.8 10.8 12.49 rad 0.08 7kQ,D,c'
;group main1 range cyl end1 19.5 11.6 12.49 end2 25.8 11.6 12.49 rad 0.08 8 Tm/gzx
;group main1 range cyl end1 19.5 12.4 12.49 end2 25.8 12.4 12.49 rad 0.08 7dXh,sD
zM<yd#`yt8
m m
Ox+}JB
;pro bulk 8.3e8 she 4.0e8 fric 35 coh 2.3e6 ten 1.46e6 den 2600 range z 0 6.66 ;中砂岩 ^j]"5@f
;pro bulk 1.7e9 she 0.7e9 fric 31 coh 2.5e6 ten 1.2e6 den 2390 range z 6.66 10.89 ;泥岩 Q?-u J1J
;pro bulk 0.83e9 she 0.38e9 fric 36 coh 0.6e6 ten 0.43e6 den 1400 range z 10.89 18.33 ;3下煤 |~YhN'OJ
;pro bulk 1.7e9 she 0.7e9 fric 31 coh 2.5e6 ten 1.2e6 den 2390 range z 18.33 25.8 ;泥岩 ]8EkZC
;pro bulk 4.6e9 she 2.1e9 fric 38 coh 2.6e6 ten 1.51e6 den 2660 range z 25.8 31 ;细砂岩 hV"2L4/E
;pro bulk 3.3e9 she 1.5e9 fric 38 coh 2.3e6 ten 1.46e6 den 2640 range z 31 61 ;粉砂岩 dhI+_z
wm/>_
pro bulk 8.6e8 she 4.0e8 fric 32 coh 26.5e5 ten 1.86e6 den 2600 range z 0 6.66 ;中砂岩 "gq_^&
pro bulk 7.5e8 she 4.0e8 fric 30 coh 32.0e5 ten 1.2e6 den 2000 range z 6.66 10.89 ;泥岩 L'}^Av_+
pro bulk 1.2e8 she 0.3e8 fric 20 coh 3.1e5 ten 0.26e6 den 1400 range z 10.89 18.33 ;3下煤 k1M?6TW&
pro bulk 7.5e8 she 4.0e8 fric 30 coh 32.0e5 ten 1.2e6 den 2000 range z 18.33 25.8 ;泥岩 j'&a)-Wx_
pro bulk 9.1e8 she 4.2e8 fric 27 coh 27.2e5 ten 1.03e6 den 2660 range z 25.8 31 ;细砂岩 5C"A*Fg?;
pro bulk 3.3e8 she 1.5e8 fric 32 coh 2.3e6 ten 1.46e6 den 2640 range z 31 61 ;粉砂岩 ~Ec@hz]js
;%xG bg!lg
;pro bulk 3.3e9 she 1.5e9 fric 28 coh 27.2e5 ten 0.91e6 den 2640 range z 31 81 ;粉砂岩 Z n]e2
Ui;PmwQc&
;interface 1 prop kn 2e9 ks 2e9 ten 1e3 fric 15 a1A3uP
a: [m;
fix x range x -19.9 -20.1 LrnE6U9
fix x range x 69.9 70.1 jp+#N
pH
fix y range y -.1 .1 D }EH9d
fix y range y 51.1 51.3 <^B!.zQ
fix z range z -.1 .1 v{TISgZ
W^dRA xVX
set grav 0 0 -10 o@:u:n+.
T( sEk
apply szz -4e6 range z 60.9 61.1 dF0:'y
ini szz -4e6 5fud:k
ini sxx -2e6 Kw,ln<)2
ini syy -2e6 gPr&
