请回复也是一种美德,我也不容易,呵呵 xiQc\k$
sAs`O@
FLAC3D3.0在某隧道工程开挖支护中的应用 ;9fWxH
隧道建模命令流入下: '43U v
set log on _Gb7n5p
set logfile yang.log W>?aZv
gen zon radcyl p0 0 0 0 p1 9.0 0 0 p2 0 50 0 p3 0 0 8 & ,1!Y!,xy
size 4 20 6 4 dim 6 5 6 5 rat 1 1 1 1 group 围岩 g2}aEfp!H
gen zon cshell p0 0 0 0 p1 6.0 0 0 p2 0 50 0 p3 0 0 5.0 & UUtSme
size 4 20 6 4 dim 5.6 4.6 5.6 4.6 rat 1 1 1 1 group 初期支护 F.(e}EMyNh
gen zon cshell p0 0 0 0 p1 5.6 0 0 p2 0 50 0 p3 0 0 4.6 & .wWf#bB
size 4 20 6 4 dim 5.0 4.0 5.0 4.0 rat 1 1 1 1 group 二次衬砌 fill group 原岩 n!~QC
gen zon radcyl p0 0 0 0 p1 0 0 -8.0 p2 0 50 0 p3 9.0 0 0 & e.(d?/!F_
size 4 20 6 4 dim 3 6 3 6 rat 1 1 1 1 group 围岩2 0R+p\Nc&1
gen zon cshell p0 0 0 0 p1 0 0 -3.0 p2 0 50 0 p3 6.0 0 0 & ygm6(+
size 4 20 6 4 dim 2.6 5.6 2.6 5.6 rat 1 1 1 1 group 仰拱初期支护 KyDd( 'i
gen zon cshell p0 0 0 0 p1 0 0 -2.6 p2 0 50 0 p3 5.6 0 0 & Sx Bo%
size 4 20 6 4 dim 2 5 2 5 rat 1 1 1 1 group 仰拱二次衬砌 fill group 仰拱原岩 q3-cWfU
gen zone reflect normal -1 0 0 ;0$qT$,
gen zone radtun p0 0 0 0 p1 45 0 0 p2 0 50 0 p3 0 0 20 & y,KZp2 j
size 3 20 3 12 dim 9 8 9 8 rat 1 1 1 1.1 group 围岩3 )' ,dP)b
gen zon reflect dip 0 ori 0 0 0 range x 0 9 y 0 50 z 8 20 n>:e8KVM;
gen zon reflect dip 0 ori 0 0 0 range x 9 45 y 0 50 z 0 20 SX =^C
gen zon reflect dip 90 dd 270 ori 0 0 0 range x 0 9 y 0 50 z 8 20 qPUACuF'
gen zon reflect dip 90 dd 270 ori 0 0 0 range x 0 9 y 0 50 z -8 -20 #Q_<eo%lI*
gen zon reflect dip 90 dd 270 ori 0 0 0 range x 9 45 y 0 50 z -20 20 P@n
rcgM.
gen zon brick p0 -45 0 -20 p1 -45 0 -40 p2 -45 50 -20 p3 45 0 -20 & H15!QxD#
size 5 20 6 rat 1.1 1 1 group 围岩4 \k6OP
save tun_model.sav &`>dY
/Y
假设围岩岩体符合mohr-coulomb本构模型,给围岩赋参数命令流如下, 4\ )WMP
; mohr-coulomb model p<Tg}fg
model mohr MIZ!+[At
def derive $:-C9N29
s_mod1=E_mod1/(2.0*(1.0+p_ratio1)) [xGL0Z%)t
b_mod1=E_mod1/(3.0*(1.0-2.0*p_ratio1)) ,,IK}
s_mod2=E_mod2/(2.0*(1.0+p_ratio2)) .{bT9Sc5
b_mod2=E_mod2/(3.0*(1.0-2.0*p_ratio2)) "]'W^Fg
end ?vF8 y;Jh
set E_mod1=0.6e9 p_ratio1=0.27 E_mod2=0.8e9 p_ratio2=0.26 dvY3=~'
derive (r'NB
prop bulk b_mod1 shear s_mod1 cohe 1.8e6 tens 0.8e6 fric 30 range z 4.5 20 sT<h+[2d
prop bulk b_mod2 shear s_mod2 cohe 2.8e6 tens 1.0e6 fric 35 range z -40 4.5 kDE:KV<"c
ini dens=2300 wa&:86~l?
set grav 0 0 -10 ,m7Z w_.
; boundary and initial conditions -cZuP7oA
apply szz -1.4e6 range z 19.9 20.1 EL2z&
fix z range z -40.1 -39.1 z5<&}Vh;P
fix x range x -45.1 -44.9 2JeEmG9
fix x range x 44.9 45.1 (5y*Btd=
fix y range y 49.9 50.1 [!} uj`e
hist unbal A] o3MoSt
hist gp xdis 6.0,0,0 @^-f+o
hist gp zdis 0,0,5 8F)9.s,*
hist gp xdis 6.0,50,0 }095U(@
hist gp zdis 0,50,5 &?y|Pn
plot hist 3 ov\%*z2=
solve |\"%Dy[m
save tun_nature.sav Q'ib7R;V,
对后面计算而言,模型建立时岩体在开挖前认为位移已经终了,因此需要对位移进行“清零”,而应力可以保留。假设隧道先开挖上断面,中间不设支护,直到进尺50m,那么此时位移和应力的分布情况可用如下命令流 ww%4MHPp8
ini xdis=0 ydis=0 zdis=0 Zw/??Tq b
plot re QZO<'q`L
model null range group 原岩 4
BNbS|?vV
model null range group 二次衬砌 +:c}LCI9<
model null range group 初期支护 ~U1: 0
set large ,g|ht%"
hist unbal K&=6DvfR
plot hist 3 :,/
\E
solve ]^a{?2ei
save tun_ext1.sav XC390t
如果在开挖后适时对隧道进行锚喷混凝土初期支护,该命令流如下: |qf9-36
restore tun_nature.sav y|9 LtQ
ini xdis=0 ydis=0 zdis=0 *l0i}"T^_
plot re @}+B%R
model null range group 初期支护 GIR12%-EO
model null range group 二次衬砌 -wNhbV2
model null range group 原岩 ^;\6ju2
step 100 o@} qPvt0
hist unbal Kl(u~/=6
plot hist 3 ;t@^Z_z,CR
mo el range group 初期支护 ~aL?{kb+
prop bulk 1.33e9 shear 0.8e9 cohe 2.2e6 tens 1.2e6 fric 32 range z 4.5 7.0 x -7.0 7.0 d)$seZB
prop bulk 10.9e9 shear 8.9e9 dens 2500 range group 初期支护 bOV]!)o
set large t)(>E'X
x
solve Nii5},
save tun_ext2.sav
