232 deg C
K%.t%)A_3 LGh# HDi_|{2^ Size - 0 0.04 to 0.07 0.031 5.25 Size - 1 1/16 (0.063) 0.0625 9.75 Size - 2 1/8 (0.125) 0.1875 18 Size - 3 3/16 (0.188) 0.4375 11.5
"cwvx8un f"-3'kqo GJ\bZ"vDo -54 deg C
/$d#9Uv PDpuHHB GY rUB59 Location:Home> Home
4(? Z1S Products
cTja<*W^xv Services
KFBBqP Machining
{nMCU{*k References
soOfk!b Customer Support
o'_eLp Company Info Products> All Products
GdM|?u&s" Mass Spec
Mtaky=l8~I Gas Chrom
,&iEn}xG7i Liquid Chrom
/b]+RXvxj Thermal Desorption
e$`;z%6y Vacuum Systems
$\#wsI( Laboratory & Cleaning
=5O&4G`} Software
DfjDw/{U3L Print Catalog 2008-2009 Vacuum Systems> All Vacuum Systems
NC3XJ
4 Vacuum Pumps
A;TNR Diffusion Pumps
=j%ORD[ Turbo Pump Repair Kits
O[8wF86R Fluids and Oils
)}J}d) Hose
gm$<U9L\v Gaskets
; EsfHCi) O-Rings
m~tv{#Y Fittings
I@kMM12>c Gauges & Controllers
8iPA^b|sz{ Traps
z
$iI Filters
\0;EHB Apiezon
&hEkm Parts
!KtP> `8 Repair
a+B3`6 Catalog Section F: Vacuum Supplies Gaskets> All Gaskets
xB_78X1 Gold
=)f.Yf|A* Copper
zG7y$\A O-Rings
swg*fhJFB Gold/Silver-Tin Material
MSb0J ` Accessories for Gasket Fabrication O-Rings> All O-Rings
%<>|cO Viton® and Kalrez®
F6ZL{2$k@ Buna-N
h^f?rWD:nz Silicone
x|*m ok PTFE
?NxaJ^ Gold, Platinum,
lidou, Silver/Tin
Xc9NM1bp= Metric O-Rings
0?''v>% O-Ring Kits
0pBG^I`_ Gold Foil and Gasket Material Contact Us O-Rings By Material
CN6b982& Viton®
;?{OX Buna-N
?'si^N Silicone
C_ W%]8u PTFE
f9HoQDFsM Kalrez®
fM3ZoH/ Gold, Platinum, Silver/Tin Other
RijFN.s Metric O-Rings
R=C+] Sheet Stock - Viton®, PTFE, and Silicone
g6H` uO O-Ring Kits Material for O-Rings Gold Foil and Gasket Material
brdY97s4 Viton, PTFE and Silicone Sheet Material
Dc3bG@K*G BSY7un+`: 450 deg F
b~;M&Y nu X`>Oy |~+bbN|b 260 deg C
`pXPF}T p[%B#(]9, wc ;^C?PX ]YUst]gu3 Y+C6+I<3 t?FPmbjv 260 deg C
0BN=>]V~j7 eMjW^-RgE5 lrmz'M' ,[u.5vC Each type has its advantages and disadvantages as listed in the chart
~,{nBp9* below, and the type required depends on the O-Ring application. Of the
v"sN
K various types of O-Rings available from SIS, Viton® is the most popular
Ku8qn\2" for mass spectrometers and other laboratory instruments. This is due to
QaLVIsnfN Viton®'s high temperature stability and good resistance to chemicals and
5ZjM:wrF| ozone.
RCMO?CBe Gold gaskets are used to make high vacuum and high temperature seals
/<\do 1 on vacuum flanges.
V7?Pv
Q 2SYV2 Cp]q>lM" uXdR-@80* -65 deg F
mSp;(oQ O/ZyWT A[Vhy;xz Sizes
30QQnMH3 #Qd"d3QG Gu%}B@ 4^ (y?`|=G-xT O-Ring
y<)q;fI7 Types Available
b(_PV#@$ 5xc-MkIRL -P'c0I9z eSSv8[u Bz6Zy)&sAL Dia
meter (in.)
b$}@0 G:;(, IJ6&*t
wT t8B==% Comparision of O Materials Used in the Construction
~ym-Szo of O-Rings
&Fl*, :2MHx}]il 1y.!x~Pi, y73@t$| 288 deg C
_UUp+Hz lLZ?&z$ sX]ru^F3 550 deg F
C6c]M@6 @W!cC#u Ok_)C+o rY(^6[ ! \E,Fe:/g 150 deg C
#}zL?s^G fYgX|#Me K[i|OZWu -110 deg F
_pR7sNe V u/4|Akui Minimum Inside
CfjVx x2z%J,z@4 >=ng? Dia
meter (in.)
.8Gmy07 A@OSh6/{h M-NY&
