  • 2826阅读
[求助]为什么自重应力场这么混乱? [复制链接]
离线51200605
只看楼主 倒序阅读 使用道具 楼主  发表于: 2009-10-20
后处理中,发现自重应力场很混乱,明显有问题,见图。 8T}Dn\f
请问高人如何解决?万分感谢! DSL3+%KF#
命令如下: Xz\X 8I
finish N?><%fra
/CLEAR,start ~'VVCtA
/fILEname,slope analysis nUScDb2|
/units,si $ 9 k5a
/pnum,kp,1 3"LT''
/pnum,line,1 mu$rG3M
/number,0 (7w95xI
/PREP7 nQ08(8
*afun,deg Wiere0 2*
!定义单元类型 CS\8ej}y
et,1,solid45 9T%b#~?3P
!定义材料属性 0 `$fs.4c
!边坡围岩材料1的属性 EnP>
mp,ex,1,6e7 04#<qd&ob@
mp,nuxy,1,0.29 >9,:i)m_
mp,dens,1,23 h.4FY<
tb,dp,1 Nn-EtM0w
tbdata,1,3e4 DA^!aJ6iF
tbdata,2,30 yM# %UeZ\
tbdata,3,0 dfWtLY
!边坡围岩材料2的属性 Ib2n Bg>j
mp,ex,2,5e7 VU;98
mp,nuxy,2,0.21 =k##*%
mp,dens,2,23.5 n*rXj{Kt
tb,dp,2 .Z(Q7j^
tbdata,1,5e4 ,*Wp$
tbdata,2 %hi]oz
tbdata,3,0 GsU.Lkf
!边坡围岩材料3的属性 iiv`ji
mp,ex,3,7e8 Xh@;4n
mp,nuxy,3,0.34 q+{yv
mp,dens,3,25.1 }#phNn6
tb,dp,3 V<Co!2S
tbdata,3,5e5 ?$.x%G+
tbdata,2,40 `Ln1g@
tbdata,3,0 }%`f%/
!边坡围岩材料4的属性 p Cgm!t?/
mp,ex,4,1.5e9 ZDx1v_xr
mp,nuxy,4,0.3 jKb4d9aX
mp,dens,4,24.8 N14Q4v-*x
tb,dp,4 F0ylJ /E
tbdata,4,8e4 Qb8Z+7
tbdata,2,40 2[i(XG{/
tbdata,3,0  3 EOuJ
!创建边坡模型线 lu;gmWz
k,1,101.95,69.87, %|B$y;q^3
k,2,103.17,55.92 +zZ]Txb(
k,3,103.77,49.01 iHeu<3O
k,4,104.57,39.96 +Ou<-EQV
k,5,105,35 g1I8_!}~
k,6,140,35 p<c1$O*
k,7,140,0 J+l#!gk$!
k,8,105,0 d#|%h] 6
k,9,0,0 G6pR?K+
k,10,0,35 ;E0x#JUrw
k,11,0,49.11 {hVc,\A
k,12,0,63.68 C=(~[Y
k,13,0,66.77 8\rAx P}=
k,14,0,69.87 't+'rG6x
l,1,2 8^!ib/@v"
l,2,3 V\=%u<f
l,3,4 {m/KD 'b_
l,4,5 L~*nI d
l,5,6 5I[6 "o0
l,6,7 5? *Iaw
l,7,8 B/dJj#
l,8,9 '#lc?Y(pJ2
l,9,10 85BB{ T;
l,10,11 )!=fy']
l,11,12 V$bq|r
l,12,13 \-D[C+1(
l,13,14 /$^SiE+N
l,14,1 ]l^" A~va
l,13,2 <K <|G
l,12,3 FTu<$`!1L
l,11,4 +>Pq]{Uf1j
l,10,5 ='6@^6y
l,5,8 UaBNoD
!创建边坡面模型 WF-^pfRq~
al,14,1,15,13 Kh{_BdN
al,15,2,16,12 r=#v@]z B
al,16,3,17,11 pV*d"~T
al,17,4,18,10 vHN/~k#
al,18,19,8,9 T;v^BVn
al,5,6,7,19 3`Dyrj#!
vext,1,6,1,,,35,,, `KUL 4) g~
vsel,s,volu,,1 x LGMN)@r
vatt,1,1,1 vdd>\r)v
vsel,s,volu,,2 \`W8#fob
vatt,2,2,1 _ME?o
vsel,s,volu,,3 lL&p?MUp
vatt,3,3,1 ]CX^!n
vsel,s,volu,,4,6,1 x\pygzQ/
vatt,4,4,1 7%W@Hr,%F
allsel #M<u^$Jz
!划分网格 h<i.Z7F;tj
mshkey,1 mh35S!I3I^
mshape,1,2D ~?B\+6<V
vmesh,all |-xKH.'n
!固定面11,15,19,23,26,27,30,31 {BZ0x2
da,11,all f!G%$?]
da,15,all rEoOv
da,19,all !, {-q)'D
da,23,all :3D[~-/S
da,26,all l"%WXi"X
da,27,all ^_/gM[H.
da,30,all ]W7&ZpF
da,31,all O@>{%u
!施加重力 Y#FSU# a$<
allsel,all Hk?E0.
acel,,9.8,0 -Fc 9mv(H
!进入求解器 {6iHUK
/solu n1)].`
antype,static F6" QsFG
nusubst,100 gF\ac%9
pred,on :Yn{:%p
nropt,full 7e /Kh)5G
nlgeom,on pIY3ft\
insrch,on =Ds&ArG
outres,all,last CJ[e^K{
cnvtol,f,,0.005,2,0.5  !力收敛准则设定 W=4|ahk$
cnvtol,u,,0.05,2,1     !位移收敛准则设定 EGj zjuJu{
allsel +f,I$&d.V
solve 02C;
save OT#foP
finish :|Bzbn=N2
/post1  !进入后处理 R^rA.7T
set,last PMe3Or@
plesol,s,y @'"7[k!y;
!plesol,u,y,0,1 *}Rd%'
!plesol,s,xy,0,1 le2 v"Y
!plesol,epto,xy,0,1 7eG@)5Uy
!pldisp,1                                      !绘制边坡模型变形图 <Ys7`e6eY
!plesol,u,x                                    !绘制边坡模型水平方向位移云图 h([qq<Lzs
!plesol,eppl,eqv                               !绘制边坡模型塑性应变云图 KJ_L>$ ]*
离线51200605
只看该作者 1楼 发表于: 2009-10-20
自己顶个,等待高人!
离线lijunli1995
只看该作者 2楼 发表于: 2009-10-20
是不是密度的单位拟弄错了 Co`:D
怎么那么小
robert li
离线lijunli1995
只看该作者 3楼 发表于: 2009-10-20
你这都收敛不了呀
robert li
离线lijunli1995
只看该作者 4楼 发表于: 2009-10-20
finish                                     P> ~Lx
/CLEAR,start                           tfjbG;R
/fILEname,try                   uQkQ#'e|
/units,si                                 ]v.Yt/&C{
/pnum,kp,1                                 >Yfo $S_
/pnum,line,1                             sJ|IW0Mr
/number,0                               sE0,b
/PREP7                                     #}xPOz7:
*afun,deg                                 O9Yk5b;
!定义单元类型                             rH[Eh8j,
et,1,solid45                               "H}ae7@
!定义材料属性                               A{Q~@1
!边坡围岩材料1的属性                       #DcK{|ty
mp,ex,1,6e7                               QM'>)!8
mp,nuxy,1,0.29                             cQh=Mri]
mp,dens,1,23                               1 w9Aoc
tb,dp,1                                   HA. O"A8`
tbdata,1,3e4,30,0                                                             6/Z 8/PL
!边坡围岩材料2的属性                     / !A&z4;D
mp,ex,2,5e7                               qGie~S ##
mp,nuxy,2,0.21                             ^7C,GaDsn
mp,dens,2,23.5                             y |Tv;v1L
tb,dp,2                                   &XSe&1
tbdata,1,5e4,0,0                                                               s4>xh=PoJ
!边坡围岩材料3的属性                     c1StA
mp,ex,3,7e8                               yj9 Ad*.
mp,nuxy,3,0.34                               'Y5=A!*@tf
mp,dens,3,25.1                             +ID% (:
tb,dp,3                           62#8c~ dL
tbdata,1,5e5,40,0                                                               ~T&X#i
!边坡围岩材料4的属性                       =4 W jb
mp,ex,4,1.5e9                             dZ\T@9+j+
mp,nuxy,4,0.3                             UFUm-~x`
mp,dens,4,24.8                             LY!.u?D`P
tb,dp,4                                   rE\.[mFI
tbdata,1,8e4,40,0                                                           iD2>-yf
!创建边坡模型线 5                           Fprhu;h
k,1,101.95,69.87                           hj[sxC>z5
k,2,103.17,55.92             6 i]B8Ziq{
k,3,103.77,49.01                         Y+"Gx;F>
k,4,104.57,39.96                         #^q@ra
k,5,105,35                               "`5BAv;u
k,6,140,35                               ="]y^&(L(
k,7,140,0                               [Kd"M[1[ <
k,8,105,0                                   m ,TYF
k,9,0,0                                   `Dv &.
k,10,0,35                                   ooT~R2u
k,11,0,49.11                               5va ;Ol4
k,12,0,63.68                               IF|%.%I$!U
k,13,0,66.77                               FBrJVaF
k,14,0,69.87                               KT8]/T`U
l,1,2                                   )F:UkS
l,2,3                                   &qZ:"k
l,3,4                                   !_h<w?)
l,4,5                                   '8fL)Zk
l,5,6                                   }Yp]A
l,6,7                                   D]d2opBLj
l,7,8                                   mC84fss
l,8,9                                   fh e%5#3
l,9,10                                     kk3G~o +
l,10,11                                 2graLJ?9Z
l,11,12                                 S;S_<GX
l,12,13                                 9_pOV%Qs
l,13,14                                 JC4Z^/\.
l,14,1                                   P87qUC
l,13,2                                   <(caY37o6)
l,12,3                                   CB?,[#r5f
l,11,4                                   #:/-8Z(0
l,10,5                       ,T7(!)dR
l,5,8                                     tNCKL. yU
!创建边坡面模型                         L!kbDbqn
al,14,1,15,13                     i- r y5x
al,15,2,16,12                     mKBPIQ+ZS
al,16,3,17,11                     $ -f(.S
al,17,4,18,10                     1PT0<C-
al,18,19,8,9                    [T#9#3
al,5,6,7,19                               P3V }cGZ
vext,1,6,1,,,35,,,                           D~%h3HM
vsel,s,volu,,1                             }L|XZL_Jo#
vatt,1,1,1                                 pw1&WP&?3
vsel,s,volu,,2                           7 *HBb-
vatt,2,2,1                                 {NV=k%MTmi
vsel,s,volu,,3                             D i #Em[
vatt,3,3,1                                 1 *$-.
vsel,s,volu,,4,6,1                         gnU##Km|
vatt,4,4,1                           R~(_m#6`:
allsel,all                                     +4k7ti1Qb
!划分网格                                   uJ/ &!q<3
mshkey,1                                 GZ/vUe
mshape,1,3D                               lF!Iu.MM 9
vmesh,all                                     '>r"+X^W
da,11,all                                 WhR'MkfL
da,15,all                                 )L:p.E
da,19,all                                 I`EgR?5 `
da,23,all                                 u< .N\/
da,26,all                                 ]}dAm S/
da,27,all                                 ;]SP~kG
da,30,all                                 h`/1JjP
da,31,all                                 R8R,!3 N
!施加重力                                 l&v&a!EU
allsel,all                               gNzamorv[
acel,,9.8,0                               ZNG{:5u,
!进入求解器                               \+sP<'~M
/solu                                     x)o`w"]al
antype,static Mhze !!
nlgeom,on                             `oo(\O7t=
nsubst,500,500,200        I?i,21:5
cnvtol,f,,0.005,2,0.5  !力收敛准则设定     G G[$-
cnvtol,u,,0.05,2,1     !位移收敛准则设定 F#Xzh Ds
allsel
robert li
离线lijunli1995
只看该作者 5楼 发表于: 2009-10-20
材料3和4定义错误,应该是TBDATA,1,.....不是TBDATA,3 Iw) 'Yyg
定义子步出错,命令流就是错的
robert li
离线lijunli1995
只看该作者 6楼 发表于: 2009-10-21
给你改了半天也没回来看 k/V:QdD Sb
更没有感谢 BA|*V[HBE
FENT
robert li
