  • 4870阅读
  • 1回复
请教:哪位用ansys的link8算过问题啊? 轴力老是为0. [复制链接]
离线tsssjl
只看楼主 倒序阅读 使用道具 楼主  发表于: 2009-10-31
哪位用ansys的link8算过问题啊? link8模拟的横向连接杆
提取的轴力老是为零,杆变形后明显被拉长了
命令流如下:
/cle
*set,x5,1800000000
*set,y5,170000000
*set,x4,1800000000
*set,y4,180000000
*set,x3,1800000000
*set,y3,200000000
*set,x2,1800000000
*set,y2,180000000
*set,x1,1800000000
*set,y1,170000000
*set,k4,108000000
/PREP7
ET,1,BEAM4
et,2,link8                                             !定义link8单元
SECTYPE, 1, BEAM, I, ganggong, 0                       !*定义1号工字形截面*
SECOFFSET, CENT                                        !*截面质心不偏移*
SECDATA,0.1,0.1,0.2,0.0114,0.0114,0.007,0,0,0,0          !*1号截面参数*
R,1,0.0035578,0.0000237,0.00000158,0.1,0.2,0,            !设置实常数,编号,截面面积,IZZ(水平轴),IYY,Z轴方向厚度,Y轴方向厚度,转动
r,2,379.94e-6                                   !定义link8单元的面积
et,3,combin14
r,3,k4                 !设置地层反力弹簧的实常数K,单位Pa
!定义弹簧单元
et,4,combin14
et,5,combin14
et,6,combin14
et,7,combin14
et,8,combin14
                 !设置X方向约束弹簧的实常数K,单位Pa
r,4,x1
r,5,x2
r,6,x3
r,7,x4
r,8,x5
et,9,combin14   !y方向弹簧
et,10,combin14
et,11,combin14
et,12,combin14
et,13,combin14
                !设置y方向约束弹簧的实常数K,单位Pa
r,9,480e6
r,10,470e6
r,11,460e6
r,12,450e6
r,13,500e6
mp,EX,1,200e9       !材料特性(钢拱、杆件、弹簧)
mp,PRXY,1,0.3
mp,DENS,1,7850
!建立几何建模
k,1,100,100,0     !创建第一榀各关键点
k,2,93.544,97.621,0
k,3,100,106.88,0
k,4,106.456,97.621,0
larc,2,3,1,6.88
larc,3,4,1,6.88
k,101,100,100,1     !创建第二榀各关键点
k,102,93.544,97.621,1
k,103,100,106.88,1
k,104,106.456,97.621,1
larc,102,103,101,6.88
larc,103,104,101,6.88
k,201,100,100,2     !创建第三榀各关键点
k,202,93.544,97.621,2
k,203,100,106.88,2
k,204,106.456,97.621,2
larc,202,203,201,6.88
larc,203,204,201,6.88
k,301,100,100,-1
k,302,93.544,97.621,-1
k,303,100,106.88,-1
k,304,106.456,97.621,-1
larc,302,303,301,6.88
larc,303,304,301,6.88
k,401,100,100,-2
k,402,93.544,97.621,-2
k,403,100,106.88,-2
k,404,106.456,97.621,-2
larc,402,403,401,6.88
larc,403,404,401,6.88
!设置单元网格
lesize,1,,,22
lesize,2,,,22
lesize,3,,,22
lesize,4,,,22
lesize,5,,,22
lesize,6,,,22
lesize,7,,,22
lesize,8,,,22
lesize,9,,,22
lesize,10,,,22
!划分网格
type,1
mat,1
real,1
lmesh,all
type,2                 !形成杆件单元
mat,1
real,2
e,93,48
*repeat,21,1,1
e,48,3
*repeat,21,1,1
e,3,138
*repeat,21,1,1
e,138,183
*repeat,21,1,1
e,135,90
*repeat,21,-1,-1
e,90,45
*repeat,21,-1,-1
e,45,180
*repeat,21,-1,-1
e,180,225
*repeat,21,-1,-1
e,92,47
e,47,2
e,2,137
e,137,182
!添加地层弹簧单元
!psprng,节点号,tran(径向施加弹簧),弹簧K值(需要根据地层抗力折算),1(一个长度)
type,3
mat,1
real,3
local,1000,1,100,100,0
csys,1000
*do,i,1,45
psprng,i,tran,k4,1
*enddo
local,1001,1,100,100,1
csys,1001
*do,i,46,90
psprng,i,tran,k4,1
*enddo
local,1002,1,100,100,2
csys,1002
*do,i,91,135
psprng,i,tran,k4,1
*enddo
local,1003,1,100,100,-1
csys,1003
*do,i,136,180
psprng,i,tran,k4,1
*enddo
local,1004,1,100,100,-2
csys,1004
*do,i,181,225
psprng,i,tran,k4,1
*enddo
csys,0
!设施X向支座弹簧
type,4
mat,1
real,4
psprng,1,tran,x1,-1,0,0,,
psprng,24,tran,x1,1,0,0,,
type,5
mat,1
real,5
psprng,46,tran,x2,-1,0,0,,
psprng,69,tran,x2,1,0,0,,
type,6
mat,1
real,6
psprng,91,tran,x3,-1,0,0,,
psprng,114,tran,x3,1,0,0,,
type,7
mat,1
real,7
psprng,136,tran,x4,-1,0,0,,
psprng,159,tran,x4,1,0,0,,
type,8
mat,1
real,8
psprng,181,tran,x5,-1,0,0,,
psprng,204,tran,x5,1,0,0,,
!设施Y向支座弹簧
type,9
mat,1
real,9
psprng,1,tran,y1,0,-1,0,,
psprng,24,tran,y1,0,-1,0,,
type,10
mat,1
real,10
psprng,46,tran,y2,0,-1,0,,
psprng,69,tran,y2,0,-1,0,,
type,11
mat,1
real,11
psprng,91,tran,y3,0,-1,0,,
psprng,114,tran,y3,0,-1,0,,
type,12
mat,1
real,12
psprng,136,tran,y4,0,-1,0,,
psprng,159,tran,y4,0,-1,0,,
type,13
mat,1
real,13
psprng,181,tran,y5,0,-1,0,,
psprng,204,tran,y5,0,-1,0,,
!加Z向约束,加载,求等效节点荷载
/sol
nsel,s,node,,1,181,45                   !加Z向节点约束
nsel,a,node,,24,204,45
d,all,uz,0
allsel
acel,0,10,0          !施加重力加速度
allsel                 !施加节点等效荷载(根据围岩压力用EXCEL计算出来的)
f,    1    ,fx,    20052.295893/3
*repeat,5,45,0
f,    3    ,fx,    40587.718035/3
*repeat,5,45,0
f,    4    ,fx,    41397.02104/3
*repeat,5,45,0
f,    5    ,fx,    41889.932123/3
*repeat,5,45,0
f,    6    ,fx,    42062.684072/3
*repeat,5,45,0
f,    7    ,fx,    41913.956588/3
*repeat,5,45,0
f,    8    ,fx,    41444.886315/3
*repeat,5,45,0
f,    9    ,fx,    40659.058335/3
*repeat,5,45,0
f,    10    ,fx,    39562.47862/3
*repeat,5,45,0
f,    11    ,fx,    38163.52813/3
*repeat,5,45,0
f,    12    ,fx,    36472.89891/3
*repeat,5,45,0
f,    13    ,fx,    34503.51226/3
*repeat,5,45,0
f,    14    ,fx,    32270.419825/3
*repeat,5,45,0
f,    15    ,fx,    29790.688865/3
*repeat,5,45,0
f,    16    ,fx,    27083.271705/3
*repeat,5,45,0
f,    17    ,fx,    24168.860695/3
*repeat,5,45,0
f,    18    ,fx,    21069.730325/3
*repeat,5,45,0
f,    19    ,fx,    17809.56681/3
*repeat,5,45,0
f,    20    ,fx,    14413.28721/3
*repeat,5,45,0
f,    21    ,fx,    10906.84875/3
*repeat,5,45,0
f,    22    ,fx,    7317.050685/3
*repeat,5,45,0
f,    23    ,fx,    3671.32941/3
*repeat,5,45,0
f,    2    ,fx,    0
*repeat,5,45,0
f,    25    ,fx,    -3673.544105/3
*repeat,5,45,0
f,    26    ,fx,    -7319.019365/3
*repeat,5,45,0
f,    27    ,fx,    -10908.559655/3
*repeat,5,45,0
f,    28    ,fx,    -14414.73236/3
*repeat,5,45,0
f,    29    ,fx,    -17810.7419/3
*repeat,5,45,0
f,    30    ,fx,    -21070.63448/3
*repeat,5,45,0
f,    31    ,fx,    -24169.49675/3
*repeat,5,45,0
f,    32    ,fx,    -27083.64596/3
*repeat,5,45,0
f,    33    ,fx,    -29790.81098/3
*repeat,5,45,0
f,    34    ,fx,    -32270.30261/3
*repeat,5,45,0
f,    35    ,fx,    -34503.1715/3
*repeat,5,45,0
f,    36    ,fx,    -36472.35319/3
*repeat,5,45,0
f,    37    ,fx,    -38162.798415/3
*repeat,5,45,0
f,    38    ,fx,    -39561.58801/3
*repeat,5,45,0
f,    39    ,fx,    -40658.03203/3
*repeat,5,45,0
f,    40    ,fx,    -41443.75095/3
*repeat,5,45,0
f,    41    ,fx,    -41912.739848/3
*repeat,5,45,0
f,    42    ,fx,    -42061.414707/3
*repeat,5,45,0
f,    43    ,fx,    -41888.639244/3
*repeat,5,45,0
f,    44    ,fx,    -41395.733806/3
*repeat,5,45,0
f,    45    ,fx,    -40586.465574/3
*repeat,5,45,0
f,    24    ,fx,    -20051.681983/3
*repeat,5,45,0
f,    1    ,fy,    21057.88552/2
*repeat,5,45,0
f,    3    ,fy,    36280.811236/2
*repeat,5,45,0
f,    4    ,fy,    24494.544842/2
*repeat,5,45,0
f,    5    ,fy,    12521.069935/2
*repeat,5,45,0
f,    6    ,fy,    451.8981695/2
*repeat,5,45,0
f,    7    ,fy,    -11620.727391/2
*repeat,5,45,0
f,    8    ,fy,    -23604.537256/2
*repeat,5,45,0
f,    9    ,fy,    -35407.940847/2
*repeat,5,45,0
f,    10    ,fy,    -46940.7263/2
*repeat,5,45,0
f,    11    ,fy,    -58114.750026/2
*repeat,5,45,0
f,    12    ,fy,    -68844.610505/2
*repeat,5,45,0
f,    13    ,fy,    -79048.300847/2
*repeat,5,45,0
f,    14    ,fy,    -88647.835583/2
*repeat,5,45,0
f,    15    ,fy,    -97569.846761/2
*repeat,5,45,0
f,    16    ,fy,    -105746.14459/2
*repeat,5,45,0
f,    17    ,fy,    -113114.23882/2
*repeat,5,45,0
f,    18    ,fy,    -119617.81615/2
*repeat,5,45,0
f,    19    ,fy,    -125207.17034/2
*repeat,5,45,0
f,    20    ,fy,    -129839.58298/2
*repeat,5,45,0
f,    21    ,fy,    -133479.64916/2
*repeat,5,45,0
f,    22    ,fy,    -136099.54813/2
*repeat,5,45,0
f,    23    ,fy,    -137679.25697/2
*repeat,5,45,0
f,    2    ,fy,    -138204.79489/2
*repeat,5,45,0
f,    25    ,fy,    -137674.43673/2
*repeat,5,45,0
f,    26    ,fy,    -136094.17481/2
*repeat,5,45,0
f,    27    ,fy,    -133473.82598/2
*repeat,5,45,0
f,    28    ,fy,    -129833.41633/2
*repeat,5,45,0
f,    29    ,fy,    -125200.76738/3
*repeat,5,45,0
f,    30    ,fy,    -119611.28323/2
*repeat,5,45,0
f,    31    ,fy,    -113107.68133/2
*repeat,5,45,0
f,    32    ,fy,    -105739.66491/2
*repeat,5,45,0
f,    33    ,fy,    -97563.543025/2
*repeat,5,45,0
f,    34    ,fy,    -88641.80105/2
*repeat,5,45,0
f,    35    ,fy,    -79042.622595/2
*repeat,5,45,0
f,    36    ,fy,    -68839.36846/2
*repeat,5,45,0
f,    37    ,fy,    -58110.01612/2
*repeat,5,45,0
f,    38    ,fy,    -46936.56345/2
*repeat,5,45,0
f,    39    ,fy,    -35404.402435/2
*repeat,5,45,0
f,    40    ,fy,    -23601.666775/2
*repeat,5,45,0
f,    41    ,fy,    -11618.557755/2
*repeat,5,45,0
f,    42    ,fy,    453.34518/2
*repeat,5,45,0
f,    43    ,fy,    12521.783395/2
*repeat,5,45,0
f,    44    ,fy,    24494.52505/2
*repeat,5,45,0
f,    45    ,fy,    36280.069935/2
*repeat,5,45,0
f,    24    ,fy,    21057.336625/2
*repeat,5,45,0
/sol
allsel,all
SOLVE
/post1
ALLSEL
esel,s,type,,2  !选取杆单元
eplot
plnsol,u,sum
prnsol,dof
etable,s-axis,ls,1           !显示轴力
smult,n-axis,s-axis,,2e-4,1
pretan,n-axis
plls,n-axis,n-axis,1,0
离线chenweiwei
只看该作者 1楼 发表于: 2012-03-07
