  • 14978阅读
  • 102回复
[资料共享]离散元数值计算软件UDEC3.1学习资料(中文) [复制链接]
离线xiangpeng811
只看楼主 倒序阅读 使用道具 楼主  发表于: 2009-11-29
关键词: 软件计算方法
1  引  言......................................................... 1 gUpb4uN
""1^k2fj
1.1
总 论................................................................ 1 3plzHz,x
{FIXc^m'
1.2
与其他方法的比较..................................................... 2 }f8Uc+
%d>=+Ds[
1.3
一般特性............................................................. 2 u#V5?i
a(9L,v#?
1.4
应用领域............................................................. 3 7_mw%|m6@
_',prZ*
开始启动....................................................... 4 &b?LP]
nM-h&na{s
2.1
安装和启动程序....................................................... 4 =}v}my3y"
'eJ+JM<0%
2.1.7
内存赋值......................................................... 4 L2pp6bW
DiEluA&w9
2.1.9
运行UDEC........................................................ 5 PG_0\'X)/w
c=L2%XPP
2.1.10
安装测试程序.................................................... 5 ?}RSwl
Jnna$6G)B
2.2
简单演示-通用命令的应用............................................. 5 6C]1Q.f;
Nv/v$Z{k
2.3
概念与术语........................................................... 6 3'c0#h@VD
 y7$iOR
2.4 UDEC
模型:初始块体的划分............................................. 8 N\#MwLm
&znQ;NH#
2.5
命令语法............................................................. 9  k7>|q"0C
KA){''>8
2.6 UDEC
应用基础......................................................... 10 ^H2-RBE#
B,K>rCZ/
2.6.1
块体划分......................................................... 10 z[cyA.
FcRW;e8-
2.6.2
指定材料模型..................................................... 16 f~d d3m('
@:U+9[
2.6.2.1
块体模型..................................................... 16 @H7Wb}
YE=q:Bv
2.6.2.2
节理模型..................................................... 17 'C:>UlzLy
qd#sY.|1
2.6.3
施加边界条件和初始条件........................................... 19 ;IVDr:
p"FW&Q=PN
2.6.4
迭代为初始平衡................................................... 21 8ZKo_I\
B|4X}*@SX
2.6.5
进行改变和分析................................................... 24 ~d%Pnw|
hlJq-*6'
2.6.6
保存或恢复计算状态............................................... 25 FFH_d <q
PB/IFsJ
2.6.7
简单分析的总结................................................... 25 NDs!a
Qum9A
2.8
系统单位............................................................. 26 9P~\Mpk
Bnb#{tL
用UDEC求解问题................................................. 27 +H9>A0JF
u)V#S:9]
3.1
一般性研究........................................................... 27 OnF3lCmu
t@R ?Rgu3
3.1.1
第1步:定义分析模型的对象....................................... 28 nD)K}4
'{J&M|<A
3.1.2
第2步:产生物理系统的概念图形................................... 28 .GsO.#p{
;B?DfWX
3.1.3
第3步:建造和运行简单的理想模型................................. 28 v|Yh w
zD(`B+
3.1.4
第4步:综合特定问题的数据....................................... 29 &g.+V/<[
H~+l7OhV
3.1.5
第5步:准备一系列详细的运行模型................................. 29 3$m4q`J
a_ `[Lj
3.1.6
第6步:进行模型计算............................................. 29 2Ri{bWi
GF>'\@Th
3.1.7
第7步:提供结果和解释........................................... 30 /}PF\j9#4
7G\\{
3.2
产生模型............................................................ 30 @*qz(h]\
g"?Y+j
3.2.1
确定UDEC模型合适的计算范围...................................... 30 L dm?JrU
59%tXiO
3.2.2
产生节理......................................................... 32 d8m6B6 CW
kH4Ai3#g
3.2.2.1
统计节理组生成器........................................... 32 FRS>KO=3
CMCO}#
3.2.2.2 VORONOI
多边形生成器....................................... 34 Q<KvBgmT
)@L'wW
3.2.2.3
例子....................................................... 34 zj/!In
Wt=|
3.2.3
产生内部边界形状................................................. 35 )E,\H@A
+\|Iu;w
3.3
变形块体和刚体的选择................................................ 38 y-j\zK
VH(S=G5Yb
3.4
边界条件............................................................ 42 >j'ZPwj^
T[sDVkCbxf
3.4.1
应力边界......................................................... 42 QR Ei7@t
:k3Nt5t!
3.4.1.1
施加应力梯度............................................... 43 5Pd"h S
1XnZy5fEo
3.4.1.2
改变边界应力............................................... 44 .9"Y_/0
e89Xb;;w
3.4.1.3
打印和绘图................................................. 44 aS pWsT
CWNx4)ZGw
3.4.1.4
提示和建议................................................. 45 +=mkCU
^ mS o1?<
3.4.2
位移边界......................................................... 46 :^fcC[$K
|6(ZD^w
3.4.3
真实边界-选择合理类型........................................... 46 "7v@Rye
Nof3F/2 N&
3.4.4
人工边界......................................................... 46 >zhO7,=,
7\9>a
3.4.4.1
对称轴..................................................... 46 }t ;(VynV)
66'?&Xx'
3.4.4.2
截取边界................................................... 46 C%U`"-%n@7
:J :, m
3.4.4.3
边界元边界................................................. 49 BWM YpZom
~,BIf+ \XF
3.5
初始条件............................................................ 50 Oer^Rk
:sP!p`dl
3.5.1
在均匀介质中的均匀应力:无重力................................... 50 .>mr%#p
}j^\(2
3.5.2
无节理介质中具有梯度变化的应力:均匀材料......................... 51 sL@U
F P>)&3>_
3.5.3
无节理介质中具有梯度变化的应力:非均匀材料....................... 51 sPpsq
.'rW.'Ft
3.5.4
具有非均匀单元的密实模型......................................... 52 ]Lm9^q14m
8Y_ol#\L
3.5.5
随模型变化的初始应力............................................. 53 )DeA} e ?F
Vg>(  Y,
3.5.6
节理化介质的应力................................................. 54 H.W E6
gF0q@My~
3.5.7
绘制应力等值线图................................................. 55 ' /$d0`3B>
}>'PT -
3.6
加载与施工模拟...................................................... 57 ,N e;kI
]_8qn'7
3.7
选择本构模型........................................................ 62 S3@ |Q\*r
i@B[ eta
3.7.1
变形块体材料模型................................................. 63 TU GNq
gCN$}
3.7.2
节理材料模型..................................................... 64 EM/@T}
Qed.4R:o
3.7.3
合理模型的选择................................................... 65 Cz W:L&t
\MmI`$
3.8
材料性质............................................................ 71 G <uyin>
"d$m@c
3.8.1
岩块性质......................................................... 71 GQl$yZaK{
VB?O hk]<
3.8.1.1
质量密度................................................... 71 $ KRI'4
^kgBa27
3.8.1.2
基本变形性质............................................... 71 y8 KX<2s1
.-IkL |M
3.8.1.3
基本强度性质............................................... 72 KMV=%o
!Yw3 d
3.8.1.4
峰后效应................................................... 73 hTM[8 ~<^
TD9;kN1`
3.8.1.5
现场性质参数的外延......................................... 77 ~O]]N;>72"
8-lOB
3.8.2
节理性质......................................................... 80 7 As|Ns`
5 gv/Pq&
3.9
提示和建议.......................................................... 81 v9D22,K-
oX DN+4ge
3.9.1
节理几何形状的选择............................................... 81 `KCh*i
)6w}<W*1E
3.9.2
设计模型......................................................... 81 Da v PYg
}#qGqY*@LK
3.9.3
检查模型运行时间................................................. 82 oh KCdT~
V%_4%
3.9.4
对允许时间的影响................................................. 82 &E4 0* (C
(lGaPMEU}
3.9.5
单元密度的考虑................................................... 83 8>.J1C
N,f4*PQ
3.9.6
检查模型响应..................................................... 83 {XW Z<OjG
Hsihytdj
3.9.7
检查块体接触..................................................... 83 k~/>b~ .c
!j\" w p
3.9.8
应用体积模量和剪切模量........................................... 83 581e+iC~<H
:gB[O>'<m
3.9.9
选择阻尼......................................................... 84 js8{]04y
!TP@- X;
3.9.10
给块体和节理模型指定模型和赋值.................................. 84 H{AMZyV0/d
yY&3p1AxW]
3.9.11
避免圆角误差.................................................... 85 PI~1GyJr@;
zOSs[[
3.9.12
接触嵌入........................................................ 85 [b/k3&O'
rC7``#5
3.9.13
非联结块体...................................................... 86 eh,~F
d~?X/sJ t
3.9.14
初始化变量...................................................... 86 H> '>3]G
(s1k$@d
3.9.15
确定坍塌荷载.................................................... 86 (^5 7UmFv]
|8.(XsN
3.9.16
确定安全系数.................................................... 86 =1u@7Bh
t2V0lyeL
3.10
解 释.............................................................. 88 sz9G3artK&
\y88d4zX
3.10.1
不平衡力........................................................ 88 <97d[/7i
a3VM '
3.10.2
块体/网格结点的速度............................................. 88 Sje wuIi1
h8Xg`C\
3.10.3
块体破坏的塑性指标.............................................. 89 7;tJK^J`
) gzR=9l
3.11
模拟方法........................................................... 89 !bD@aVf?5
uU> wg*m
3.11.1
有限数据系统模拟................................................ 89 p[@5&_u(z
RC^9HuR&
3.11.2
混沌系统的模拟.................................................. 90 < n:}kQTT
5|I[>Su
附件: UDEC3.1学习资料.rar (1229 K) 下载次数:1169
贡献,共享
离线fennpig
只看该作者 1楼 发表于: 2009-11-29
找了很久,好东西,支持楼主!下载学习学习!
离线sjzdh01
只看该作者 2楼 发表于: 2009-11-29
下载学习学习,谢谢楼主提供的资料
离线55709673
只看该作者 3楼 发表于: 2009-11-29
这个支持一下
离线icehydegackt
只看该作者 4楼 发表于: 2009-11-29
节理的部分我有点儿搞不清楚
离线gggggg007
只看该作者 5楼 发表于: 2009-12-04
好东西,支持楼主!下载学习学习!
离线creec2009
只看该作者 6楼 发表于: 2009-12-05
好,好,好!正是我正在用的好东东!谢谢分享
资源共享。共同进步!
离线temgy1986
只看该作者 7楼 发表于: 2009-12-06
好东西,学习了
离线baojian
只看该作者 8楼 发表于: 2009-12-06
这个软件不太熟悉
离线xintianyou20
只看该作者 9楼 发表于: 2009-12-07
离线casmit
只看该作者 10楼 发表于: 2009-12-07
谢谢楼主,好资料,学习中。
离线thereisnocat
只看该作者 11楼 发表于: 2009-12-08
楼主太好了 认真学习了 大家多多交流 多多交流
