  • 2773阅读
[国内文献]同济大学硕士论文-盾构法隧道管片接头的理论研究及应用 [复制链接]
离线flyw2002
只看楼主 倒序阅读 使用道具 楼主  发表于: 2009-12-21
盾构法隧道管片接头的理论研究及应用.rar (4905 K) 下载次数:113 同济大学硕士论文-盾构法隧道管片接头的理论研究及应用
离线wjfhndk
只看该作者 1楼 发表于: 2009-12-21
好资料,下了学习学习,感谢楼主贡献。
离线tunnel006
只看该作者 2楼 发表于: 2009-12-22
好资料,谢谢楼主
离线guof2007
只看该作者 3楼 发表于: 2010-03-22
刚接触,学习一下
离线lvpqvl
只看该作者 4楼 发表于: 2010-05-22
盾构法隧道管片接头的理论研究及应用
这个文章不错
离线wenzhanzhen
只看该作者 5楼 发表于: 2010-10-18
During the construction of shie ld tunnels,support pressure is usually applied at the work face to prevent
excessive tunneling—induced soil movement or collapse.However,the selection and control of appropriate support
pressure is difficult due to variation of soil conditions and uncerlainty in construction.Support pressure should be
controlled SO that it is not SO low as to cause face collapse and not SO high as to induce ground hogging.Numerical
simulation is employed to study how the soil parameter and ground water affect the support pressure,and to give the
proper support pressure at the excavation face in a case study.
Keywords:shield tunnel;excavati‘on face;numerical solution;support pressure
