在做隧道ANSYS简单开挖模拟时,出现了一些问题,望各位前辈给多多指教! E^#|1Kpq
GAtK1%nPD
隧道洞泾假定为1.0m(实际上不可能这么小,仅仅是数值实验),隧洞轴线左右及下部各取10m为边界,施加法向约束。 :#I8Cf
mmr>"`5.
通过APDL命令,改变隧道的轴线埋深,采取全断面一次性开挖,整个荷载步分为两步:第一步计算初始应力场,第二步是杀死 cd*y{Wt
,LWM}L
开挖体单元,计算开挖后引起的地表沉降(位移场,第二步减去第一步),计算结果发现: m'oVqA&
:h*20iP
隧道的轴线埋深越浅,计算得到的地表沉降越小,这与工程实际不符,请问原因何在? Joq9.%7Q
-5kq9Dy\,
以下是我的计算命令流,希望得到高手的帮助啊! 8+v6%,K2
sVaWg?=qs'
{Kd9}CDAZ
Fini H>;km$b +
/clear fx%'7/+
/title,TUNNEL ANALYSIS mkrvWZjZX
/prep7 CG$S?
ET,1,PLANE2 BAg*zYV7
keyopt,1,3,2 M1Od%nz3
<w.V !"!
*SET,R,0.7 )Qb1$%r.
*SET,H,10.0 |PDuvv!.f
*SET,X1,-2*R SU2(XP]5
*SET,Y1,-2*R hFj.d]S
*SET,W1,4*R (al7/EhY
*SET,H1,4*R R 5bt~U
^=E4~22q
*SET,X2,-10.0 DV*8Mkzg
*SET,Y2,H-20.0 j\!zz
*SET,W2,20.0 RAXqRP,iw
*SET,H2,20.0 !0 *=z~
CYL4,0,0,0,45,R,405,0
6bo,x
BLC4,X1,Y1,W1,H1 =EsKFt"
BLC4,X2,Y2,W2,H2 T?^AllUZQR
AOVL,1,2,3 B;hc|v{(
NUMCMP,ALL SX/yY
NUMMRG,ALL,,,,LOW 0%`\8
LANG,11,8,90,, = ?vk n
LANG,11,7,90,, q;tsA"l
LANG,10,7,90,, f1hi\p0q
LANG,10,6,90,, (fm\kV
LANG, 9,6,90,, ldanM>5
LANG, 9,5,90,, = J).(E89
LANG,12,5,90,, >sPu*8D40a
LANG,12,8,90,, 1\kOjF)l
L,1,7 tN";o\!}
L,2,8 J
A4'e@
L,3,5 fcD$km
L,4,6 5|S|HZ8G
NUMCMP,ALL u%VO'}Gz
NUMMRG,ALL,,,,LOW qV9`
FLST,3,4,4,ORDE,2 f![x7D$
FITEM,3,29 `S{< $:D
FITEM,3,-32 k[y{&f,
ASBL,2,P51X burEo.=
FLST,3,8,4,ORDE,8 6~;fj+S
FITEM,3,14 q,$UKg#i
FITEM,3,16 a5L#c=
FITEM,3,18 wC'KI8-
FITEM,3,20 :]=Y1*L\)
FITEM,3,22 ZUAWSJ,s
FITEM,3,24 _6^ vxlF
FITEM,3,26 sB-c'`,w`
FITEM,3,28 7b:oz3 ?PI
ASBL, 3,P51X (3{'GX2c
NUMCMP,ALL |C7GI[P
NUMMRG,ALL,,,,LOW =u${2=
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!初始参数 S)@R4{=e"V
MP,EX,1,3.0E6 ?ti7iBz?
MP,PRXY,1,0.33 >:Xzv
MP,DENS,1,1900.0 } 9<aX
Y,
TB,DP,1 HBo^8wN
TBDATA,1,2.4E4,13.6,0 eV1O#FLbi
!+9H=u
MP,EX,2,3.0E6 H :d{Sru
MP,PRXY,2,0.33 NVeb,Pf
MP,DENS,2,1900.1 4#;rv$
TB,DP,2 i+Ob1B@w
TBDATA,1,2.4E4,13.6,0 T!(I\wz;Bo
@Eqc&v!O
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!剖分单元 vlp]!7v
type,1 g%1!YvS3v
MAT,1 PIB|&I|p
lsel,S,line,,1,8,1 91mXv Q:u
lsel,A,line,,15,27,4 V |#B=W
Lesize,ALL,,,4,,,,,0 Xdq2 .:\
lsel,S,line,,29,32,1 Qaq{UW
Lesize,ALL,,,3,,,,,0 T1\Xz-1
7$,["cJX
lsel,S,line,,9,13,2 }_@cqx:n^
lsel,A,line,,18,20,2 L>xcgV7
lsel,A,line,,21 i*W8_C:S
lsel,A,line,,26,28,2 [UR+G8X21m
Lesize,ALL,,,10,,,,,0 w v9s{I{P
lsel,S,line,,10 5}e-\:J>B
lsel,A,line,,22 e%(zjCA
lsel,A,line,,24,25,1 ~;wSe[
Lesize,ALL,,,20-H-2*R,,,,,0 ~9h6"0K!
lsel,S,line,,12,14,2 1K09iB
lsel,A,line,,16,17,1 XrFyN(p
Lesize,ALL,,,H-2*R,,,,,0 8T$:^HW
asel,s,area,,2,13,1 zP
rT0
amesh,all gC<\1AIu
JWlH(-U4|
type,1 [)Xu60?Q
MAT,2 Ud`V"X
asel,s,area,,1 pWbzBgM?nU
amesh,all p^5B_r:
nummrg,all,,,,low iDp]lu
numcmp,all xm/v:hl=
E
Jq=MP
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!计算初始应力场 }@SZ!-t%rD
/solu H6bomp"
antype,static ruB&&C6)v
deltim,0.1,0.05,0.2 V1xpJ
autots,on !使用自动时间步 sZ]O&Za~
pred,on !打开时间步长预测器 6\OSIxJZF
lnsrch,on !打开线性搜索 mZ ONxR6q$
nlgeom,on !打开大位移效果 &"Ua"H)
nropt,full !设定牛顿-拉普森选项 N!9DZEcm
cnvtol,f,,0.02,0 (@uQ>dR:
Nsel,s,loc,x,-10 ^dYFFKQ
Nsel,a,loc,x,10 g0cCw2S
D,all,,,,,,UX,,,,, ZJ=-cE2n
Nsel,s,loc,y,H-20 UyD=x(li
D,all,,,,,,Uy,,,,, H Y.,f_m
time,1 H,:Cg:E/^
acel,,10 <4C`^p
nsel,all b;9v.MZ4>g
esel,all `$G7Ia_ $]
allsel,all ogip#$A}3
solve XRJ<1w:
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!开挖 o=q
N+-N
time,2 ;T-i+_
esel,s,type,,2 {~b]6}O
ekill,all kOFEH!9&
nsel,all vb{&T<
esel,all scJ`oc:<J
allsel,all i ,4
solve \dbpCZ
fini (<itE3P
Vu^J'>X
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!地表沉降 ]/JE#
!/POST1 +qD4`aI
!LCDEF,1,1,, g]X4)e]
!LCDEF,2,2,, o
PR^Z
pt
!LCASE,2, oel3H5Nz
!LCOPER,SUB,1, ,2, K
,f 1c}
!Nsel,s,loc,Y,H _o' jy^
!PLVECT,U, , , ,VECT,ELEM,ON,0 #s(B,`?N
!PLNSOL, U,Y, 0,1.0 W{1=O)w
<W|{zAyv
Fl(+c0|kT
]rZ"5y
W\N-~9UA
