Private Sub CommandButton1_Click() Ve 3 ;
Form1.Hide n(ir[w#,]"
Dim a() )]6hy9<
Dim txt As String n{5NNV6
Dim point1 As Variant 9.OA, 6
Dim point2 As Variant m?CZQq,
Dim gc As String ]/2T\w.<
Do P
}7zE3V
point1 = ThisDrawing.Utility.GetPoint(, vbCrLf & "点的坐标:") IVvtX}
point2 = ThisDrawing.Utility.TranslateCoordinates(point1, acWorld, acUCS, False) vsyWm.E
If point2(0) = "0" And point2(1) = "0" Then -yH,5vD
Exit Do |F$BvCg
End If $K}DB N; 4
n = n + 1 (c\hy53dP
ReDim Preserve a(1 To 4 * n) 8F5|EpB9M
If Check1.Value Then 2a=sm1?
txt = ThisDrawing.Utility.GetString(0, vbCrLf & "点号:") 'xK.UI
a(4 * n - 3) = txt D)b}f`
Else o+ O}Te
a(4 * n - 3) = n s'HD{W`
End If [:;# ]?
Yc Q=vt{
If Check2.Value Then C"uahP[Y
gc = ThisDrawing.Utility.GetString(0, vbCrLf & "点的高程:") K`%tGVY
a(4 * n) = gc s}5+3f$f
Else j6:7AH|!)2
a(4 * n) = 0 uXZg1F)
End If K >tf,
a(4 * n - 2) = point2(0) [3/VCYje
a(4 * n - 1) = point2(1) &m^@9E)S/
Loop wFS2P+e;X
CommonDialog1.ShowSave KM,|} .@:
Open CommonDialog1.FileName For Output As #1 fC-P.:F#I
For i = 1 To n v1G"3fy9
a(4 * i - 2) = Format(a(4 * i - 2), "0.000") wEft4o
a(4 * i - 1) = Format(a(4 * i - 1), "0.000") 0JyVNuHn
Print #1, a(4 * i - 3) & "," & a(4 * i - 2) & "," & a(4 * i - 1) & "," & a(4 * i) 'o4p#`R:8
Next HM[klH]s=
Close #1 r`'y?Bra;
]1`g^Z@ 0
R=)55qu
~W0(1#
i
End Sub
