  • 2212阅读
Plaxis 3D foundation 的问题请教(2) [复制链接]
离线kissme
只看楼主 倒序阅读 使用道具 楼主  发表于: 2010-03-23
In this way a 3D mesh, composed of 15-noded wedge elements is
formed. Where needed extra element levels are automatically introduced, so that the size of the elements in y-direction is about equal to the average element size defined for the 2D mesh. If multiple boreholes are used and not all layers are present in all boreholes,so-called degenerated elements will be introduced, to deal with the transition between the various layers.
请教Where needed extra element levels are automatically introduced, so that the size of the elements in y-direction is about equal to the average element size defined for the 2D mesh.怎么理解?谢谢回复,在此表示感谢~~~
离线kissme
只看该作者 1楼 发表于: 2010-03-23
大家帮帮忙啊,答得好的我送鲜花以表感谢!
离线阿狂
只看该作者 2楼 发表于: 2010-03-24
所需的额外的元素尺寸是自动引进的,y 方向元素的尺寸等于为二维网格定义的平均大小。
共鲜花(kissme) 谢谢回答,很清晰!条评分
狂--继续天天向上
离线kissme
只看该作者 3楼 发表于: 2010-03-24
回 2楼(阿狂) 的帖子
谢谢回答,很清晰! 给你送花啦~~~~
