  • 2988阅读
[求助]Help:How to decide the properties for Flowable fill? [复制链接]
离线mano
只看楼主 倒序阅读 使用道具 楼主  发表于: 2007-08-27
Flowable fill is control low strength material(CLSM) G(t&(t`[
$v"CQD
This material is  backfiledl behind retaining wall. Modelled by PLAXIS: .SSPJY(
w6^TwjjZ$
Undrained condition, M-C model. d(| 4 +^>
(Fq]y5
How about the Poisson's ratio(effective value) and Young's Modulus? /sPa$D
(just the general value) HW"5MZ8E
WE-+WC!!:
Thanks,
离线geofem
只看该作者 1楼 发表于: 2007-08-27
Miu=0.49,undrained material vy>(?[
E=1.0Mpa~2.5Mpa,depends on the water content ,void ratio, and depth of the backfill.
ZSOIL2D/3D QQ群:68722113
岩土工程数值分析开发平台,共享、开放、合作、提高。
离线mano
只看该作者 2楼 发表于: 2007-08-28
Thanks, n^l5M^.
If I need input the effective poisson's ratio for drained condition, [?g}<fa
what's value for this(u')?
离线geofem
只看该作者 3楼 发表于: 2007-08-28
Plaxis recommend miu=0.25 for effective state. %0 U@k!lP
PS: HS model, you can see the default miu of advanced settings.
离线daniellb1023
只看该作者 4楼 发表于: 2007-08-28
may i know, if the poisson ratio is high, the soil displacement will be smaller or larger? HPo><u
zhyf}Ta'
thanks.....
