  • 2662阅读
  • 1回复
FLAC中的结构单元函数求助 [复制链接]
离线ssw001
只看楼主 倒序阅读 使用道具 楼主  发表于: 2010-05-08
SEL Support Functions
ND_PTR s_node( S_PTR sp, INT i )
s_node( sp, i )address of node i of the SEL (i in range 1 to s_numnd) where i is the order in nodal-connectivity list. Also see s_conn.
FLT nd_pos( ND_PTR np, INT p, INT dof )
nd_pos( np, p, dof )position p (p ∈ {1,2} denotes current or reference position, respectively; dof-component, dof ∈ {1,2,3}). The reference position is the configuration for which stiffness matrices have been formed and does not change during a small-strain analysis. The current position is updated after each timestep. During a large-strain analysis, the reference position is set equal to the current position during each large-strain update.
FLT sb_force( SB_PTR bp, INT e, INT d )
 sb_force( bp, e, d )force at end e of beamSEL (e ∈ {1,2}; d-component, d ∈ {1,2,3}). These forces are expressed in terms of the beamSEL coordinate system — see the figure below for sign convention.
有没有那个朋友可以解释一下
离线schwein001
只看该作者 1楼 发表于: 2010-07-15
没什么好解释的,不至于帮忙翻译一遍吧
