" H~<wAer,Op
Some points you may concern: e $5s],,n
'(:R-u!pp
1) M-C model, undrained condition, effective stress analysis: j;rxr1+w
In this case, the plasticity can be predicted as usual; z\IZ5'
~r]$(V n
2)M-C model, undrained condition, total stress analysis: >&qaT*_g
(n{!~'3
In this case, there is not effective stress calculation due to no pore pressure generated. /P{'nI
^6,}*@
The total stress analysis plasticity occurs as soon as the total stresses reach the failure NjA\*M9
L-3wez;hm
criterium while with an effective stresses analysis plasticity occurs when the effective stresses xO
1uHaL
Ac,bf 8C
reach the failure criterium. $)O\i^T
49#?I:l
The latter is of course more realistic; only the effective stresses determine plasticity, not the water pressures. 41XXL$
wB*}XJah
In other words, using total stress analysis is only correct when the calculation is elastic. But this case is not very often in reality. M<)Vtn
IC. R4-
Suggestion: Try to use effective stress analysis when it is undrained condition (typically, there is option for this in PLAXIS)." 5sMyH[5zY
u7u1lx>S
"1) M-C model, undrained condition, effective stress analysis: iEBxBsz_
In this case, the plasticity can be predicted as usual;" +Kg3qS"
2)M-C model, undrained condition, total stress analysis: e]d\S]5
k*T&>$k}^
In this case, there is not effective stress calculation due to no pore pressure generate hniTMO
qQ<7+z<4KP
THESE STATEMENT DO NOT MAKE SENSE TO ME.
