During the construction of shie ld tunnels,support pressure is usually applied at the work face to prevent $wn0oIuW
excessive tunneling—induced soil movement or collapse.However,the selection and control of appropriate support $U7#3-'
pressure is difficult due to variation of soil conditions and uncerlainty in construction.Support pressure should be (AX$Svw
controlled SO that it is not SO low as to cause face collapse and not SO high as to induce ground hogging.Numerical -$X4RS
simulation is employed to study how the soil parameter and ground water affect the support pressure,and to give the 3/PvH E{R
proper support pressure at the excavation face in a case study. h#c7v!g
Keywords:shield tunnel;excavati‘on face;numerical solution;support pressure
