我也是遇到这个问题,提示
“ SEVERITY : ABORT
ERROR CODE: /DIANA/SO/SO41/0071
ERRORMSG.A: Insufficient memory for the linear solver. Try to use a linear solution method
that uses less memory. In order of decreasing memory usage:
GENEL - ILU - DIAGON.
Also substructuring may help to decrease the memory usage.
DIANA-JOB ABORTED”
查看书本,我出现的问题是说内存不足,不知道有没有什么办法可以解决的
