3.7 Reduction of negative skin friction TFBYY{Y
Provide dummy casing or sleeve around ^{),+S
pile to prevent direct contact with [yO=S0 e
settling soil aXRv}WO$>k
Predrill oversized hole through soft soil _aVJ$N.
prior to pile installation (hole filled with /)sDnJ1r
bentonite slurry) /0Z|+L9Jo
Use of slender pile section in soft soil N YCj; ,V
layers [?;`x&y~y
Electro-osmosis gsnP!2cR
Current applied between pile (cathode) and =hJfL}&O3
an anode causes migration of pore A;odVaH7
pressure towards pile u8|@|t
Reduce effective stress and hence negative v2IEJ
skin friction *y)4D[
z-
Very good effect on silty soils A ?#]s
Bitumen coating (see next slide) 4BHtR017r
If magnitude of negative skin friction is too large, the 5i^ `vmK
pile may be coated with bitumen (above neutral \M+MDT&
plane) to reduce the negative skin friction (up to 90%
reduction reported). \|v `l{
N2ni3M5v
in practice, the bitumen coating methods have been widely used.
