some personal viewpoints: v-2O{^n
1. there are no shear studs/keys behind the walers, but the shear forces along the axial direction of waler is very big on the diagonal location. ,g%2-#L%
2. It seems there are no preloading-jacks on the diagonal struts. they should be preloaded. &AH@|$!E
3. effective length of the diagonal struts are too big. as the poster above has said there should be some kingposts and runnerbeams to support the struts. 2'tZ9mK
1Qui.],c
king posts are used to support the struts vertically. it will resist the dead load of strut/runnerbeam, live load on the strut(working load), accidental load(if it needs to be accounted for). It is better to analyze the kingpost together with runnerbeam/struts, taking into account of the eccentricity effects. 6rMGlzuRo
L%9DaK
welcome to discuss. }R*[7V9"
