  • 3426阅读
  • 8回复
(新手求助)plaxis计算深基坑的问题 [复制链接]
离线duqinglei
只看楼主 倒序阅读 使用道具 楼主  发表于: 2009-06-11
本小虾因毕业设计而需要学习plaxis软件计算深基坑的施工过程,主要的工作是通过plaxis对一个基坑采用两种水压的考虑方法看看有什么不同,这是基坑的相关数据(这个是勘察报告里面的)
v\:* {behavior:url(#default#VML);}o\:* {behavior:url(#default#VML);}w\:* {behavior:url(#default#VML);}.shape {behavior:url(#default#VML);}         Normal  0        7.8 磅  0  2    false  false  false    EN-US  ZH-CN  X-NONE        <!-- /* Font Definitions */ @font-face    {font-family:宋体;    panose-1:2 1 6 0 3 1 1 1 1 1;    mso-font-alt:SimSun;    mso-font-charset:134;    mso-generic-font-family:auto;    mso-font-pitch:variable;    mso-font-signature:3 135135232 16 0 262145 0;}@font-face    {font-family:"Cambria Math";    panose-1:2 4 5 3 5 4 6 3 2 4;    mso-font-charset:0;    mso-generic-font-family:roman;    mso-font-pitch:variable;    mso-font-signature:-1610611985 1107304683 0 0 159 0;}@font-face    {font-family:Calibri;    panose-1:2 15 5 2 2 2 4 3 2 4;    mso-font-charset:0;    mso-generic-font-family:swiss;    mso-font-pitch:variable;    mso-font-signature:-1610611985 1073750139 0 0 159 0;}@font-face    {font-family:"\@宋体";    panose-1:2 1 6 0 3 1 1 1 1 1;    mso-font-charset:134;    mso-generic-font-family:auto;    mso-font-pitch:variable;    mso-font-signature:3 135135232 16 0 262145 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal    {mso-style-unhide:no;    mso-style-qformat:yes;    mso-style-parent:"";    margin:0cm;    margin-bottom:.0001pt;    text-align:justify;    text-justify:inter-ideograph;    mso-pagination:none;    font-size:10.5pt;    mso-bidi-font-size:11.0pt;    font-family:"Calibri","sans-serif";    mso-fareast-font-family:宋体;    mso-bidi-font-family:"Times New Roman";    mso-font-kerning:1.0pt;}.MsoChpDefault    {mso-style-type:export-only;    mso-default-props:yes;    mso-bidi-font-family:"Times New Roman";    mso-bidi-theme-font:minor-bidi;} /* Page Definitions */ @page    {mso-page-border-surround-header:no;    mso-page-border-surround-footer:no;}@page Section1    {size:612.0pt 792.0pt;    margin:72.0pt 90.0pt 72.0pt 90.0pt;    mso-header-margin:36.0pt;    mso-footer-margin:36.0pt;    mso-paper-source:0;}div.Section1    {page:Section1;}--> /* Style Definitions */ table.MsoNormalTable    {mso-style-name:普通表格;    mso-tstyle-rowband-size:0;    mso-tstyle-colband-size:0;    mso-style-noshow:yes;    mso-style-priority:99;    mso-style-qformat:yes;    mso-style-parent:"";    mso-padding-alt:0cm 5.4pt 0cm 5.4pt;    mso-para-margin:0cm;    mso-para-margin-bottom:.0001pt;    mso-pagination:widow-orphan;    font-size:10.5pt;    mso-bidi-font-size:11.0pt;    font-family:"Calibri","sans-serif";    mso-ascii-font-family:Calibri;    mso-ascii-theme-font:minor-latin;    mso-hansi-font-family:Calibri;    mso-hansi-theme-font:minor-latin;    mso-font-kerning:1.0pt;}table.MsoTableGrid    {mso-style-name:网格型;    mso-tstyle-rowband-size:0;    mso-tstyle-colband-size:0;    mso-style-priority:59;    mso-style-unhide:no;    border:solid black 1.0pt;    mso-border-themecolor:text1;    mso-border-alt:solid black .5pt;    mso-border-themecolor:text1;    mso-padding-alt:0cm 5.4pt 0cm 5.4pt;    mso-border-insideh:.5pt solid black;    mso-border-insideh-themecolor:text1;    mso-border-insidev:.5pt solid black;    mso-border-insidev-themecolor:text1;    mso-para-margin:0cm;    mso-para-margin-bottom:.0001pt;    mso-pagination:widow-orphan;    font-size:10.5pt;    mso-bidi-font-size:11.0pt;    font-family:"Calibri","sans-serif";    mso-ascii-font-family:Calibri;    mso-ascii-theme-font:minor-latin;    mso-hansi-font-family:Calibri;    mso-hansi-theme-font:minor-latin;    mso-font-kerning:1.0pt;}
1土层主要物理力学参数
         层号
土层名称
厚度
/m
  γs
  /KN.m3
c
/KPa
φ
/o
K
/m.s-1
Es12
/MPa
   eq \o\ac(,1)1
杂填土
2.84
18.9
3.5E-06
9.12
   eq \o\ac(,2)2-1
砂质粉土
2.55
18.9
4.5E-06
10.47
   eq \o\ac(,2)2-3
砂质粉土
7.35
19.2
18
4.5E-06
11.04
   eq \o\ac(,2)2-5
砂质粉土夹粉砂
2.50
19.3
5.0E-06
10.11
   eq \o\ac(,2)2-6
砂质粉土
4.40
19.3
1.0E-06
11.22
   eq \o\ac(,2)2-7
砂质粉土夹粉砂
3.05
19.3
18
18
6.0E-06
8.17
淤泥质粘质粉土
2.55
18.3
6.0E-06
11.09
   eq \o\ac(,6)6-1
粉质粘土
1.60
19.2
55
5.0E-09
3.59
   eq \o\ac(,6)6-2
粉质粘土
2.10
19.9
65
1.0E-09
6.42
   eq \o\ac(,6)6-3
粉质粘土夹粉质粉土
3.00
20.0
58
1.0E-09
6.59
   eq \o\ac(,8)8-1
中细砂
3.60
18.7
25
22
1.0E-08
9.3
   eq \o\ac(,8)8-3
圆砾夹卵石
5.40
20.0
25
22
1.0E-04
13.8
开挖的降水方案是基坑开挖时坑内降水,坑外不降水考虑,桩体采用钻孔咬合灌注桩1m径咬合25cm,桩入土深度27m,基坑开挖深度15.5m考虑.在基坑内设置5道水平支撑,支撑采用那个钢管称609@16,
小虾建立按水位线模型中,开挖步计算水压时候的水位线方法是设置一个一般潜水位在1.0m的位置,然后基坑开挖区内的土体采用类组水位线,开挖完的土体采用dry cluster选项,也就是某个计算步中只有两条水位线例如(0,39)-(30,39);(30,25-40).按照这样的计算方法计算出来的桩的水平位移有60多公分,这样的结果个人觉得是不正确的,所以求知识望高人指导,小生不胜感激.
桩是采用plate来模拟,内支撑是采用锚定杆模拟的,土体的参数数据是按照这张图表所给出来的结果.相同的参数,我用地下水渗流计算模拟出来的结果就是只有50几毫米的,这和实际情况比较符合.
求达人指点迷津哈.
离线duqinglei
只看该作者 1楼 发表于: 2009-06-11
哦,对了,土体模型选用的是莫尔-昆仑模型,土体我们老师说设置成排水的.
离线yishuweishui
只看该作者 2楼 发表于: 2009-06-11
土的模量取的是压缩模量的几倍?  界面单元在抽水时要打开,起隔断水流的作用。
强极则辱,情深不寿
离线duqinglei
只看该作者 3楼 发表于: 2009-06-12
土的模量取了压缩模量的2倍,用5倍模量计算的时候在最后一步即基坑最后一道支撑安装好之后开挖到基坑底面时候,土体破坏的说.
界面单元我一直是打开的,默认界面是不透水的.
离线xz1h-004
只看该作者 4楼 发表于: 2009-06-12
多少事,
从来急;
天地转,光阴迫。
一万年太久,
只争朝夕
离线lzx761
只看该作者 5楼 发表于: 2009-06-18
你的连续墙变形下面比上面打那么多!?你用摩尔库伦可能是引发这个问题的原因。
加我qq:75718651
我们进一步交流。
使自己年轻是最大的智慧
离线zsf512
只看该作者 6楼 发表于: 2009-07-03
离线ruanqingsong
只看该作者 7楼 发表于: 2011-04-23
为二位二位
离线sosgooddj
只看该作者 8楼 发表于: 2011-04-27
围观
